1Home Server Pro - Connecting with Security INIM PrimeLan (KNX integration on PrimeStudio) - Door/windows sensors and Alarm Armed/Disarmed
    Hi
    I have 1Home Server Pro gateway working, but when i connect everything, PrimeLan takes one tunnel from 1home server pro (that i specify) and after i upload settings from primestudio to Primelan, everything works and status are updated ok. On 1Home Server Pro, i clearly see the communication when i open a door going through the specified tunnel.
    Problem: After a few hours of no activity (open/close), when i do an action, it appears on 1homeServer knx traffic as 0.0.0.0, where the tunnel address should be, like it simply disappeared. And no status updates. Then, if i choose another tunnel and upload it again, it starts working again.
    Any of you had this problem? Anyway i can fix it (withough putting a KNX interface between the two)?
    Thank you so much
