switch light from 2 different taster
    Hello
    Sorry again for my Englisch.
    I am sure that my question is so obvious, but i did found the answer, so i need your help.
    I have lamp in the bed room that i like to control it from 2 different switches (by using only one button on each taster: on press off, second press on).
    right now i have to press 2 times in order to change the status of the light (i am using toggle on both taster).
    but i am sure that there is solution to it.
    I try to use the "invert" function on the taster but still i have to press 2 times to change the status of the light.
    what should i send from the taster in order to update the status on/off ?
    is there any option to read first the status of the light and then to send the right value (off or On according to the lamp status)?
    Thanks
    Eyal
    I think that i found the solution:
    i associate the "Value for toggle" to the status of the switch port, and in the value of "switch function" of the taster , i sends "invert".
    is this the right solution ? or there is simpler solution ?
    Thanks
    Eyal
      Hi Eyal!
      Your solution is correct....
      Regards
      Olaf
