Das Skript empfängt vermutlich nur etwas wenn auch ein Event kommt
Anscheinend kann das das Terminal und cURL nicht ?
<?php
$header = array (
'Accept: text/event-stream',
'Authorization: Bearer ##########'
$url = 'https://api.home-connect.com/api/homeappliances/SIEMENS-SX578S06TE-68A40E0021F0/events';
$opts = array (
'http' => array (
'method' => "GET",
'header' => $header
$context = stream_context_create ( $opts );
$fp = fopen ( $url, "rb", false, $context );
while ( 1 ) {
$line = stream_get_line ( $fp, 4096 );
echo $line . "\n";
a:1:{s:4:"data";a:1:{s:14:"homeappliances";a:1:{i:0;a:7:{s:4:"name";s:15:"Geschirrspüler";s:5:"brand";s:7:"SIEMENS";s:3:"vib";s:10:"SX578S06TE";s:9:"connected";b:1;s:4:"type";s:10:"Dishwasher";s:7:"enumber";s:13:"SX578S06TE/01";s:4:"haId";s:31:"SIEMENS-SX578S06TE-68A40E0021F0";}}}}
public function makeRequest($path, $method = 'GET', $params = array(), $put_body = NULL)
{ // $params = URL-args/-parameter für den Zugriff
$ch = curl_init();
$options = self::$CURL_OPTS;
if ($params) {
if (isset($params['access_token'])) {
$options[CURLOPT_HTTPHEADER][] = 'Accept: application/vnd.bsh.sdk.v1+json,text/event-stream';
$options[CURLOPT_HTTPHEADER][] = 'Authorization: Bearer '.$params['access_token'];
unset($params['access_token']);
switch ($method)
case 'GET': // API-call via GET + AUTHENTIFICATION beim Endpoint
$path .= '?'.http_build_query($params, null, '&');
$this->logKlasse('make/get/url ................... '.$path);
$this->logKlasse('make/get/par ................... '.serialize($params));
break;
case 'EVENT': // API-call via GET / EVENT ...
$options[CURLOPT_HTTPHEADER][] = 'Accept: text/event-stream';
$options[CURLOPT_HTTPHEADER][] = 'Cache-Control: no-cache';
$this->logKlasse('make/event/par ................. '.serialize($params));
break;
case 'POST': // API-call via POST ... Access-Token aus Code + Refresh
$options[CURLOPT_HTTPHEADER][] = 'Content-Type: application/x-www-form-urlencoded';
$options[CURLOPT_POSTFIELDS] = http_build_query($params, null, '&');
$this->logKlasse('make/post/par1 ................. '.serialize($params));
$this->logKlasse('make/post/par2 ................. '.$options[CURLOPT_POSTFIELDS]);
break;
case 'PUT': // API-call via PUT ... Settings + Progams
$options[CURLOPT_URL] = $path;
$options[CURLOPT_HTTPHEADER][] = 'Content-Type: application/vnd.bsh.sdk.v1+json';
$options[CURLOPT_HTTPHEADER][] = 'Content-Length: '.strlen($put_body);
$options[CURLOPT_CUSTOMREQUEST] = 'PUT';
$options[CURLOPT_POSTFIELDS] = $put_body;
$this->logKlasse('make/put/url ................... '.$path);
break;
case 'DELETE': // API-call via DELETE ... Programm beenden
$options[CURLOPT_CUSTOMREQUEST] = 'DELETE';
break;
