IrTrans does not send/learn commands
    Fehler: IrTrans does not send/learn commands
    (my apologies I'm writing this in English - feel free to respond in German).
    I'm trying to connect my IRTrans with Edomi.
    I have adapted edomi.ini to enable the IRTrans module and to specify the IP address.
    I believe I have done it correctly, because I am able to reboot the IRTrans from Edomi.
    However, I am unable to learn and IR command.
    In "Konfiguration" => "IR-Befehle" I create a new command and click "Lernen". The outcome is always "Timeout oder fehler".
    When I learn a command via the IRTrans software, it works fine.
    I also tried to copy/paste an IR command from a generated REM file (see attach).
    I have pasted IR code "0103033003210" in Edomi's field "IR Code". Nothing happens when I send the code.
    What am I doing wrong?
    Hast Du das Modul in der Konfiguration auch eingestellt? IP....Port usw.
      Sending an IR Code is quite easy if you have the code in your irtrans database ...
      try to send a http request .. i don't know the url out of my mind.. but its like
      http://irtransip&remote&command
      look in your manual..
        Have you tried to activate the Button "Raw/Binär Modus"?
        You can activate it even it looks like it's grayed out. That worked for me.
          so,
          thats my config:
          works well...
            Thanks for the replies!
            I think I did the proper configurations in edomi.ini:
            # Modul: IRtrans
            #    Aktiviert oder deaktiviert das Modul "IRtrans" (Konfiguration des Moduls erforderlich!)
            #    true = aktiviert
            #    false = deaktiviert
            global_irGatewayActive=true
            # Modul-Konfiguration: IRtrans
            # IRtrans: IP-Adresse
            global_irIp='192.168.3.14'
            # Telnet/UDP-Port
            #    Port zur Kommunikation mit dem IRtrans.
            global_irPort=21000
            # Maximale Wartezeit beim Anlernen eines IR-Codes
            #    Innerhalb dieser Zeit muss während des Anlernens ein IR-Code empfangen werden.
            #    1..oo = Wartezeit in Sekunden
            global_irTimeout=5
            I played around with the buttons "Long-IR code", "RAW/Binär Modus", without success.
            Maybe I should indeed not configure an "IF-befehl" but an HTTP-GET request. This seems to work fine:
            http://192.168.3.14/send.htm?remote=telenet&command=on
            But I wonder, why does Edomi have the build-in IR-module then? Any advantages?
