[root@localhost ~]# mysql -u root edomiLive Reading table information for completion of table and column names You can turn off this feature to get a quicker startup with -A Welcome to the MySQL monitor. Commands end with ; or \g. Your MySQL connection id is 324465 Server version: 5.1.73 Source distribution Copyright (c) 2000, 2013, Oracle and/or its affiliates. All rights reserved. Oracle is a registered trademark of Oracle Corporation and/or its affiliates. Other names may be trademarks of their respective owners. Type 'help;' or '\h' for help. Type '\c' to clear the current input statement. mysql> DROP PROCEDURE IF EXISTS mqtt_publish; Query OK, 0 rows affected, 1 warning (0.00 sec) mysql> DROP TRIGGER IF EXISTS mqtt_insert_trigger; ERROR 1146 (42S02): Table 'edomiLive.RAMko' doesn't exist mysql>
