Was muss ich in dem genannten LBS (vonjonofe ) eintragen, damit ich die einzelnen Channels übersichtlich aufgelistet bekomm?
Ich habe da nicht wirklich durchgeblickt
{"system":{"time":"1566592861","unit":"C","soc":59,"charge":false,"rssi":31,"online":0},"channel":[{"number":1,"name":"Kanal 1","typ":3,"temp":24.90,"min":10.00,"max":200.00,"alarm":0,"color":"#0C4C88"},{"number":2,"name":"Kanal 2","typ":3,"temp":999.00,"min":10.00,"max":35.00,"alarm":0,"color":"#22B14C"},{"number":3,"name":"Kanal 3","typ":3,"temp":999.00,"min":10.00,"max":35.00,"alarm":0,"color":"#EF562D"},{"number":4,"name":"Kanal 4","typ":0,"temp":999.00,"min":10.00,"max":35.00,"alarm":0,"color":"#FFC100"},{"number":5,"name":"Kanal 5","typ":0,"temp":999.00,"min":10.00,"max":35.00,"alarm":0,"color":"#A349A4"},{"number":6,"name":"Kanal 6","typ":0,"temp":999.00,"min":10.00,"max":35.00,"alarm":0,"color":"#804000"},{"number":7,"name":"Kanal 7","typ":3,"temp":24.60,"min":10.00,"max":50.00,"alarm":0,"color":"#5587A2"},{"number":8,"name":"Kanal 8","typ":0,"temp":999.00,"min":10.00,"max":35.00,"alarm":0,"color":"#5C7148"}],"pitmaster":{"type":["off","manual","auto"],"pm":[{"id":0,"channel":1,"pid":0,"value":0,"set":50.00,"typ":"off","set_color":"#ff0000","value_color":"#000000"}]}}
{"system":{"time":"1566632764","unit":"C","soc":60,"charge":false,"rssi":-55,"online":0},"channel":[{"number":1,"name":"Kanal 1","typ":3,"temp":24.90,"min":10.00,"max":200.00,"alarm":0,"color":"#0C4C88"},{"number":2,"name":"Kanal 2","typ":3,"temp":999.00,"min":10.00,"max":35.00,"alarm":0,"color":"#22B14C"},{"number":3,"name":"Kanal 3","typ":3,"temp":999.00,"min":10.00,"max":35.00,"alarm":0,"color":"#EF562D"},{"number":4,"name":"Kanal 4","typ":0,"temp":999.00,"min":10.00,"max":35.00,"alarm":0,"color":"#FFC100"},{"number":5,"name":"Kanal 5","typ":0,"temp":999.00,"min":10.00,"max":35.00,"alarm":0,"color":"#A349A4"},{"number":6,"name":"Kanal 6","typ":0,"temp":999.00,"min":10.00,"max":35.00,"alarm":0,"color":"#804000"},{"number":7,"name":"Kanal 7","typ":3,"temp":24.60,"min":10.00,"max":50.00,"alarm":0,"color":"#5587A2"},{"number":8,"name":"Kanal 8","typ":0,"temp":999.00,"min":10.00,"max":35.00,"alarm":0,"color":"#5C7148"}],"pitmaster":{"type":["off","manual","auto"],"pm":[{"id":0,"channel":1,"pid":0,"value":0,"set":50.00,"typ":"off","set_color":"#ff0000","value_color":"#000000"}]}}
amis/out||{"1.8.0":19110069,"2.8.0":8518,"3.8.1":1290419,"4.8.1":6253590,"1.7.0":1244,"2.7.0":0,"3.7.0":0,"4.7.0":448,"1.128.0":0}||0||0||0
{"1.8.0":19110124,"2.8.0":8518,"3.8.1":1290419,"4.8.1":6253609,"1.7.0":1250,"2.7.0":0,"3.7.0":0,"4.7.0":453,"1.128.0":0}
