Ohne entsprechende Anpassungen wird das wohl nicht mehr funktionieren
###[DEF]###
[name = Tesla API]
[e#1 = Autostart #init=1]
[e#2 = Username-Tesla Account]
[e#3 = Passwort-Tesla Account]
[e#9 =---Kommandos-- ]
[e#10 = wakeup]
[e#11 = lock doors]
[e#12 = unlock doors]
[e#13 = Set Charge Limit %]
[e#14 = Set Charge Limit to max]
[e#15 = Set Charge Limit to standard]
[e#16 = Start Charging]
[e#17 = Stop Charging]
[e#18 = Honk]
[e#19 = Ladeklappe öffnen]
[e#29 = read after write #init=1]
[e#30 = debug]
[e#31 = PollInterval in s #init=100]
[a#1 = Aktiv]
[a#2 = charge_limit_soc]
[a#3 =charge_limit_soc_std]
[a#4 =charge_limit_soc_min]
[a#5 = charge_limit_soc_max]
[a#6 =charge_limit_soc_std]
[a#7 = charge_to_max_range]
[a#8 = battery_range]
[a#9 = est_battery_range]
[a#10 = ideal_battery_range]
[a#11 = battery_level]
[a#12 = charger_voltage]
[a#13 = time_to_full_charge]
[a#14 = charge_port_door_open]
[a#15 = charge_current_request]
[a#18 = shift_state]
[a#19 = speed]
[a#20 = power]
[a#21 = native_latitude]
[a#22 = native_longitude]
[a#23 = heading]
[a#26 = autopark_state_v2]
[a#27 = homelink_nearby]
[a#28 = locked]
[a#29 = odometer]
[a#30 = vehicle_name]
[a#33 = Vehicle_ID]
[a#34 = Daemon Aktiv]
[a#35 = Debug]
[v#100 = 0.1 ]
[v#101 = 19510010 ]
[v#102 = 'Tesla ' ]
[v#103 = 0 ]
[v#104 = 0 ]
[v#105 = 0 ]
[v#106 = 0 ] Debug-Level wird über E30 gesetzt
[v#107 = 0 ] wird zusammengesetzt
[v#108 = 0 ] Array mit Loglevelnamen
###[/DEF]###
###[HELP]###
Tesla Anbindung über Tesla Account
E29 Read after write, wenn 1 wird direkt nach ausführen eines Kommandos nochmals abgefragt
###[/HELP]###
###[LBS]###
function LB_LBSID($id) {
if ($E=logic_getInputs($id)) {
if (logic_getStateExec($id)==0){
if ( $E[1]['value'] ){
logic_setVar($id,106,$E[30]['value']); //loglevel
$version = logic_getVar($id, 100);
$lbsNo = logic_getVar($id, 101);
$logName = logic_getVar($id, 102) . "-LBS$lbsNo";
$logName = preg_replace('/ /', '_', $logName);
logic_setVar($id,107,$logName); // V#107 mit Logname belegen
$logLevelNames = array('none','Info','Info ausf.','Debug' );
logic_setInputsQueued($id,$E);
logic_callExec(LBSID,$id);
} else {
###[/LBS]###
###[EXEC]###
require(dirname(__FILE__)."/../../../../main/include/php/incl_lbsexec.php");
set_time_limit(0);
restore_error_handler();
error_reporting(0);
sql_connect();
$cmdInterval=0.5; //Befehlsintervall in Sekunden
$pollMaxInterval=100; //max. Abfrageintervall in Sekunden
$pollInterval=$E[31]['value'];
$pollTimerOld=0;
$cmdTimerOld=0;
try {
$tesla = new Tesla();
$tesla->setClientId("e4a9949fcfa04068f59abb5a658f2bac0a34 28e4652315490b659d5ab3f35a9e");
$tesla->setClientSecret("c75f14bbadc8bee3a7594412c31416f8 300256d7668ea7e6e7f06727bfb9d220");
$tesla->getAccessToken($E[2]['value'],$E[3]['value']);
// if (!isset($token['access_token'])){
// logic_setOutput($id,35,"token kann nicht ermittelt werden");
// break;
$vehicles=($tesla->vehicles());
$vehicle_id= $vehicles['response'][0]['id_s']; //vehicle ID zuweisen
logic_setOutput($id,33,$vehicle_id);
$tesla->setVehicleId($vehicle_id);
#$tesla->setVehicleId("45555003714663208");
#echo "<pre>".htmlentities(print_r($tesla->vehicles()['response'], true))."</pre>";
#echo "<pre>".htmlentities(print_r($tesla->allData(), true))."</pre>";$gui_settings=$tesla->guiSettings();
$test=$tesla->access_test();
if ($test==false){
//keine Verbindung
logic_setOutput($id,35,"HTTP 408 Timeout- starte wakeup");
$tesla->wakeUp();
return;
if ($gui_settings['gui_charge_rate_units']=='km/hr'){
$faktor = 1.60934;
} else {$faktor=1;}
logic_setOutput($id,34,1);
while ( logic_getEdomiState()==1 && (!isEmpty($vehicle_id))) {
$doPoll=false;
$doCmd=false;
if ((getMicrotime()-$pollTimerOld)>=$pollInterval) {
$pollTimerOld=getMicrotime();
$doPoll=true;
if ((getMicrotime()-$cmdTimerOld)>=$cmdInterval) {
$cmdTimerOld=getMicrotime();
$doCmd=true;
if ($doPoll || $doCmd) {
if ($V=logic_getVars($id)) {
//Status-Polling
if ($doPoll) {
$chargeState=$tesla->chargeState();
logic_setOutput($id,1,$chargeState["charging_state"]);
logic_setOutput($id,2,$chargeState["charge_limit_soc"]);
logic_setOutput($id,3,$chargeState["charge_limit_soc_std"]);
logic_setOutput($id,4,$chargeState["charge_limit_soc_min"]);
logic_setOutput($id,5,$chargeState["charge_limit_soc_max"]);
logic_setOutput($id,6,$chargeState["charge_limit_soc_std"]);
logic_setOutput($id,7,$chargeState["charge_to_max_range"]);
logic_setOutput($id,8,round($faktor *$chargeState["battery_range"]));
logic_setOutput($id,9,round($faktor *$chargeState["est_battery_range"]));
logic_setOutput($id,10,round($faktor *$chargeState["ideal_battery_range"]));
logic_setOutput($id,11,$chargeState["battery_level"]);
logic_setOutput($id,12,$chargeState["charger_voltage"]);
logic_setOutput($id,13,$chargeState["time_to_full_charge"]);
logic_setOutput($id,14,$chargeState["charge_port_door_open"]);
logic_setOutput($id,15,$chargeState["charge_current_request"]);
$drive_state = $tesla->driveState();
logic_setOutput($id,18,intval($drive_state["shift_state"]));
logic_setOutput($id,19,$drive_state["speed"]);
logic_setOutput($id,20,$drive_state["power"]);
logic_setOutput($id,21,$drive_state["native_latitude"]);
logic_setOutput($id,22,$drive_state["native_longitude"]);
logic_setOutput($id,23,$drive_state["heading"]);
$vehicle_state= $tesla->vehicleState();
logic_setOutput($id,26,$vehicle_state["autopark_state_v2"]);
logic_setOutput($id,27,$vehicle_state["homelink_nearby"]);
logic_setOutput($id,28,$vehicle_state["locked"]);
logic_setOutput($id,29,round($faktor*$vehicle_stat e["odometer"]));
logic_setOutput($id,30,$vehicle_state["vehicle_name"]);
//Befehl absetzen
if ($doCmd) {
if ($E=logic_getInputsQueued($id)) {
if ($E[10]['refresh']&& $E[10]['value']==1){$tesla->wakeUp();}
if ($E[11]['refresh']&& $E[11]['value']==1){$tesla->lockDoors() ;}
if ($E[12]['refresh']&& $E[12]['value']==1){$tesla->unlockDoors();}
if ($E[13]['refresh']){$tesla->setChargeLimit($E[13]['value']);}
if ($E[14]['refresh']&& $E[14]['value']==1){$tesla->setChargeLimitToMaxRange();}
if ($E[15]['refresh']&& $E[15]['value']==1){$tesla->setChargeLimitToStandard();}
if ($E[16]['refresh']&& $E[16]['value']==1){$tesla->startCharging();}
if ($E[17]['refresh']&& $E[17]['value']==1){$tesla->stopCharging();}
if ($E[18]['refresh']&& $E[18]['value']==1){$tesla->honkHorn();}
if ($E[19]['refresh']&& $E[19]['value']==1){$tesla->openChargePort();}
if ($E[29]['value']==1){ //Anschliessend gleich wieder lesen
//read after write
$pollTimerOld=0;
if ($E[1]['value']==0) {break;}
logic_setOutput($id,34,0);
usleep(1000*100);
} catch (Exception $e) {
echo 'Exception abgefangen: ', $e->getMessage(), "\n";
sql_disconnect();
class TeslaException extends \Exception {}
class Tesla
protected $apiBaseUrl = "https://owner-api.teslamotors.com/api/1";
protected $tokenUrl = 'https://owner-api.teslamotors.com/oauth/token';
protected $accessToken;
protected $vehicleId = null;
public function __construct(string $accessToken = null)
$this->accessToken = $accessToken;
public function setAccessToken(string $accessToken)
public function access_test()
$d=$this->sendRequest('/data_request/charge_state');
return $d['response'];
public function allData() #: array
$d=$this->sendRequest('/data');
public function vehicles()
return $this->sendRequest('/vehicles');
public function setVehicleId($vehicleId)
$this->vehicleId = $vehicleId;
public function setClientId($clientId)
putenv('TESLA_CLIENT_ID=' . $clientId);
public function setClientSecret($clientSecret)
putenv('TESLA_CLIENT_SECRET=' . $clientSecret);
public function mobileEnabled() # : bool
$d=$this->sendRequest('/mobile_enabled');
public function chargeState() # : array
public function climateState() # : array
$d=$this->sendRequest('/data_request/climate_state');
public function driveState() # : array
$d=$this->sendRequest('/data_request/drive_state');
public function guiSettings() # : array
$d=$this->sendRequest('/data_request/gui_settings');
public function vehicleState() # : array
$d=$this->sendRequest('/data_request/vehicle_state');
public function wakeUp() # : array
$d=$this->sendRequest('/wake_up', array(), 'POST');
public function setValetMode($active = false, $pin = 0000) # : array
$params = array(
'on' => $active,
'pin' => $pin
$d=$this->sendRequest('/command/set_valet_mode', $params, 'POST');
public function resetValetPin() # : array
$d=$this->sendRequest('/command/reset_valet_pin', array(), 'POST');
public function openChargePort() # : array
$d=$this->sendRequest('/command/charge_port_door_open', array(), 'POST');
public function setChargeLimitToStandard() # : array
$d=$this->sendRequest('/command/charge_standard', array(), 'POST');
public function setChargeLimitToMaxRange() # : array
$d=$this->sendRequest('/command/charge_max_range', array(), 'POST');
public function setChargeLimit($percent = 90) # : array
$params = array(
'percent' => "$percent"
$d=$this->sendRequest('/command/set_charge_limit', $params, 'POST');
public function startCharging() # : array
$d=$this->sendRequest('/command/charge_start', array(), 'POST');
public function stopCharging() # : array
$d=$this->sendRequest('/command/charge_stop', array(), 'POST');
public function flashLights() # : array
$d=$this->sendRequest('/command/flash_lights', array(), 'POST');
public function honkHorn() # : array
$d=$this->sendRequest('/command/honk_horn', array(), 'POST');
public function unlockDoors() # : array
$d=$this->sendRequest('/command/door_unlock', array(), 'POST');
public function lockDoors() # : array
$d=$this->sendRequest('/command/door_lock', array(), 'POST');
public function setTemperature($driverDegreesCelcius = 20.0, $passengerDegreesCelcius = 20.0)# : array
$d=$this->sendRequest('/command/set_temps?driver_temp=' . $driverDegreesCelcius . '&passenger_temp=' . $passengerDegreesCelcius, array(), 'POST');
public function startHvac() # : array
$d=$this->sendRequest('/command/auto_conditioning_start', array(), 'POST');
public function stopHvac() # : array
$d=$this->sendRequest('/command/auto_conditioning_stop', array(), 'POST');
public function movePanoramicRoof($state = 'vent', $percent = 50) # : array
$d=$this->sendRequest('/command/sun_roof_control?state=' . $state . '&percent=' . $percent, array(), 'POST');
public function remoteStart($password = '') # : array
$d=$this->sendRequest('/command/remote_start_drive?password=' . $password, array(), 'POST');
public function openTrunk() # : array
$d=$this->sendRequest('/command/trunk_open?which_trunk=rear', array(), 'POST');
public function getAccessToken($username, $password)
$ch = curl_init();
curl_setopt($ch, CURLOPT_URL, $this->tokenUrl);
curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
curl_setopt($ch, CURLOPT_TIMEOUT, 30);
curl_setopt($ch, CURLOPT_POST, true);
curl_setopt($ch, CURLOPT_HTTPHEADER, array(
'Content-Type: application/json',
'Accept: application/json',
'User-Agent: Mozilla/5.0 (Linux; Android 9.0.0; VS985 4G Build/LRX21Y; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/58.0.3029.83 Mobile Safari/537.36',
'X-Tesla-User-Agent: TeslaApp/3.4.4-350/fad4a582e/android/9.0.0',
curl_setopt($ch, CURLOPT_POSTFIELDS, json_encode(array(
'grant_type' => 'password',
'client_id' => getenv('TESLA_CLIENT_ID'),
'client_secret' => getenv('TESLA_CLIENT_SECRET'),
'email' => $username,
'password' => $password,
// JM-2018-09-16: added because we had problems with the SSL certificate verification
curl_setopt($ch, CURLOPT_SSL_VERIFYPEER, false);
$apiResult = curl_exec($ch);
print(curl_error($ch));
$apiResultJson = json_decode($apiResult, true);
curl_close($ch);
$this->accessToken = $apiResultJson['access_token'];
return $apiResultJson;
protected function sendRequest($endpoint, $params = array(''), $method = 'GET')
$ch = curl_init();
if ($endpoint !== '/vehicles' && ! is_null($this->vehicleId)) {
$endpoint = '/vehicles/' . $this->vehicleId . $endpoint;
curl_setopt($ch, CURLOPT_URL, $this->apiBaseUrl . $endpoint);
curl_setopt($ch, CURLOPT_HEADER, false);
'Authorization: Bearer ' . $this->accessToken,
if ($method == 'POST' || $method == 'PUT' || $method == 'DELETE') {
if ($method == 'POST') {
if (in_array($method, array('PUT', 'DELETE'))) {
curl_setopt($ch, CURLOPT_CUSTOMREQUEST, $method);
curl_setopt($ch, CURLOPT_POSTFIELDS, json_encode($params));
$headerInfo = curl_getinfo($ch);
curl_close($ch);
$result = array();
if ($apiResult === false) {
$result['errorcode'] = 0;
$result['errormessage'] = curl_error($ch);
throw new TeslaException($result['errormessage'], $result['errorcode']);
if (! in_array($headerInfo['http_code'], array('200', '201', '204'))) {
//print_r($headerInfo);
$result['errorcode'] = $headerInfo['http_code'];
if (isset($apiresult)) {
$result['errormessage'] = $apiresult;
if(array_key_exists('errormessage',$result)){
}else{
throw new TeslaException('Error occured', $result['errorcode']);
//return false;
if(isset($apiResultJson)){
}else{
return $apiResult;
###[/EXEC]###
