Jetzt müssten die devices eigentlich auch funktionieren.
Das socket reuse habe ich soeben als Update eingepflegt.
, zumindest kam auf .../api was zurück was bisher nicht der Fall war.<Directory "/usr/local/edomi/www"> AllowOverride All
| 2021-01-13 23:21:01 | 824733 | 992 | debug | EXE19002160 [v0.1]: Handling response for 192.168.4.6 : 50000 -- M-SEARCH * HTTP/1.1[CR][LF]HOST: 239.255.255.250:1900[CR][LF]ST: upnp:rootdevice[CR][LF]MAN: "ssdp:discover"[CR][LF]MX: 3[CR][LF][CR][LF] (3791) |
| 2021-01-13 23:21:01 | 825273 | 992 | debug | EXE19002160 [v0.1]: Handling response for 192.168.4.55 : 50000 -- M-SEARCH * HTTP/1.1[CR][LF]HOST: 239.255.255.250:1900[CR][LF]ST: upnp:rootdevice[CR][LF]MAN: "ssdp:discover"[CR][LF]MX: 3[CR][LF][CR][LF] (3791) |
| 2021-01-13 23:21:01 | 825838 | 992 | debug | EXE19002160 [v0.1]: Handling response for 192.168.4.55 : 50000 -- M-SEARCH * HTTP/1.1[CR][LF]HOST: 239.255.255.250:1900[CR][LF]ST: ssdp:all[CR][LF]MAN: "ssdp:discover"[CR][LF]MX: 3[CR][LF][CR][LF] (3791) |
| 2021-01-13 23:21:01 | 826366 | 992 | debug | EXE19002160 [v0.1]: Handling response for 192.168.4.55 : 50000 -- M-SEARCH * HTTP/1.1[CR][LF]HOST: 239.255.255.250:1900[CR][LF]ST: upnp:rootdevice[CR][LF]MAN: "ssdp:discover"[CR][LF]MX: 3[CR][LF][CR][LF] (3791) |
| 2021-01-13 23:21:01 | 827058 | 992 | debug | EXE19002160 [v0.1]: Handling response for 192.168.4.55 : 50000 -- M-SEARCH * HTTP/1.1[CR][LF]HOST: 239.255.255.250:1900[CR][LF]ST: ssdp:all[CR][LF]MAN: "ssdp:discover"[CR][LF]MX: 3[CR][LF][CR][LF] (3791) |
| 2021-01-13 23:21:01 | 827956 | 992 | debug | EXE19002160 [v0.1]: Handling response for 192.168.4.55 : 50000 -- M-SEARCH * HTTP/1.1[CR][LF]HOST: 239.255.255.250:1900[CR][LF]ST: upnp:rootdevice[CR][LF]MAN: "ssdp:discover"[CR][LF]MX: 3[CR][LF][CR][LF] (3791) |
| 2021-01-13 23:21:01 | 828861 | 992 | debug | EXE19002160 [v0.1]: Handling response for 192.168.4.6 : 50000 -- M-SEARCH * HTTP/1.1[CR][LF]HOST: 239.255.255.250:1900[CR][LF]ST: ssdp:all[CR][LF]MAN: "ssdp:discover"[CR][LF]MX: 3[CR][LF][CR][LF] (3791) |
| 2021-01-13 23:21:01 | 829631 | 992 | debug | EXE19002160 [v0.1]: Handling response for 192.168.4.6 : 50000 -- M-SEARCH * HTTP/1.1[CR][LF]HOST: 239.255.255.250:1900[CR][LF]ST: upnp:rootdevice[CR][LF]MAN: "ssdp:discover"[CR][LF]MX: 3[CR][LF][CR][LF] (3791) |
| 2021-01-13 23:21:01 | 830185 | 992 | debug | EXE19002160 [v0.1]: Handling response for 192.168.4.6 : 50000 -- M-SEARCH * HTTP/1.1[CR][LF]HOST: 239.255.255.250:1900[CR][LF]ST: ssdp:all[CR][LF]MAN: "ssdp:discover"[CR][LF]MX: 3[CR][LF][CR][LF] (3791) |
| 2021-01-13 23:21:01 | 830720 | 992 | debug | EXE19002160 [v0.1]: Handling response for 192.168.4.6 : 50000 -- M-SEARCH * HTTP/1.1[CR][LF]HOST: 239.255.255.250:1900[CR][LF]ST: upnp:rootdevice[CR][LF]MAN: "ssdp:discover"[CR][LF]MX: 3[CR][LF][CR][LF] (3791) |
| 2021-01-13 23:21:01 | 834808 | 992 | debug | EXE19002160 [v0.1]: Handling response for 192.168.4.16 : 50000 -- M-SEARCH * HTTP/1.1[CR][LF]HOST: 239.255.255.250:1900[CR][LF]ST: ssdp:all[CR][LF]MAN: "ssdp:discover"[CR][LF]MX: 3[CR][LF][CR][LF] (3791) |
| 2021-01-13 23:21:01 | 835361 | 992 | debug | EXE19002160 [v0.1]: Handling response for 192.168.4.16 : 50000 -- M-SEARCH * HTTP/1.1[CR][LF]HOST: 239.255.255.250:1900[CR][LF]ST: upnp:rootdevice[CR][LF]MAN: "ssdp:discover"[CR][LF]MX: 3[CR][LF][CR][LF] (3791) |
| Datei: /usr/local/edomi/www/data/liveproject/lbs/EXE19002160.php | Fehlercode: 2 | Zeile: 8 | socket_bind(): unable to bind address [98]: Address already in use |
| 2021-01-13 21:26:21 | 610171 | 2672 | debug | LBS19002160 [v0.1]: Starting Hue Emulate Receiver daemon... (3791) |
| 2021-01-13 21:26:21 | 634516 | 2672 | debug | LBS19002160 [v0.1]: Daemon is not running (3791) |
| 2021-01-13 21:26:21 | 635080 | 2672 | debug | LBS19002160 [v0.1]: Starting daemon ... (3791) |
| 2021-01-13 21:26:21 | 696774 | 13344 | debug | EXE19002160 [v0.1]: Could not bind socket : [98] Address already in use (3791) |
| 2021-01-13 21:26:21 | 697398 | 13344 | debug | EXE19002160 [v0.1]: Waiting for data ... (3791) |
| 2021-01-13 21:45:27 | 123745 | 2672 | debug | LBS19002160 [v0.1]: Daemon is running with PID: 13344 (3791) |
