Naja, die ist noch in der Garantie, demnach zieh ich die VMs um, und schicke die Platte zurück. War mir gar nicht bewusst, dass auch SSDs Bad Sectors haben können.
Also: liegt erstmal nicht am Container.
[edomi@edomi ~]# df -h Dateisystem Größe Benutzt Verf. Verw% Eingehängt auf /dev/loop0 32G 9,7G 20G 33% / none 492K 4,0K 488K 1% /dev udev 32G 0 32G 0% /dev/tty tmpfs 32G 0 32G 0% /dev/shm tmpfs 32G 49M 32G 1% /run tmpfs 6,3G 0 6,3G 0% /run/user/0
lxc-start 105 20220723231434.955 INFO confile - ../src/lxc/confile.c:set_config_idmaps:2267 - Read uid map: type u nsid 0 hostid 100000 range 65536 lxc-start 105 20220723231434.963 INFO confile - ../src/lxc/confile.c:set_config_idmaps:2267 - Read uid map: type g nsid 0 hostid 100000 range 65536 lxc-start 105 20220723231434.963 INFO lsm - ../src/lxc/lsm/lsm.c:lsm_init_static:38 - Initialized LSM security driver AppArmor lxc-start 105 20220723231434.963 INFO conf - ../src/lxc/conf.c:run_script_argv:337 - Executing script "/usr/share/lxc/hooks/lxc-pve-prestart-hook" for container "105", config section "lxc" lxc-start 105 20220723231435.320 DEBUG conf - ../src/lxc/conf.c:run_buffer:310 - Script exec /usr/share/lxc/hooks/lxc-pve-prestart-hook 105 lxc pre-start produced output: mount: /var/lib/lxc/.pve-staged-mounts/rootfs: cannot mount /dev/loop0 read-only. lxc-start 105 20220723231435.397 DEBUG conf - ../src/lxc/conf.c:run_buffer:310 - Script exec /usr/share/lxc/hooks/lxc-pve-prestart-hook 105 lxc pre-start produced output: command 'mount /dev/loop0 /var/lib/lxc/.pve-staged-mounts/rootfs' failed: exit code 32 lxc-start 105 20220723231435.404 ERROR conf - ../src/lxc/conf.c:run_buffer:321 - Script exited with status 255 lxc-start 105 20220723231435.404 ERROR start - ../src/lxc/start.c:lxc_init:847 - Failed to run lxc.hook.pre-start for container "105" lxc-start 105 20220723231435.404 ERROR start - ../src/lxc/start.c:__lxc_start:2008 - Failed to initialize container "105" lxc-start 105 20220723231435.404 INFO conf - ../src/lxc/conf.c:run_script_argv:337 - Executing script "/usr/share/lxc/hooks/lxc-pve-poststop-hook" for container "105", config section "lxc" lxc-start 105 20220723231435.677 DEBUG conf - ../src/lxc/conf.c:run_buffer:310 - Script exec /usr/share/lxc/hooks/lxc-pve-poststop-hook 105 lxc post-stop produced output: umount: /var/lib/lxc/105/rootfs: not mounted lxc-start 105 20220723231435.677 DEBUG conf - ../src/lxc/conf.c:run_buffer:310 - Script exec /usr/share/lxc/hooks/lxc-pve-poststop-hook 105 lxc post-stop produced output: command 'umount --recursive -- /var/lib/lxc/105/rootfs' failed: exit code 1 lxc-start 105 20220723231435.682 ERROR conf - ../src/lxc/conf.c:run_buffer:321 - Script exited with status 1 lxc-start 105 20220723231435.682 ERROR start - ../src/lxc/start.c:lxc_end:988 - Failed to run lxc.hook.post-stop for container "105" lxc-start 105 20220723231435.682 ERROR lxc_start - ../src/lxc/tools/lxc_start.c:main:306 - The container failed to start lxc-start 105 20220723231435.682 ERROR lxc_start - ../src/lxc/tools/lxc_start.c:main:311 - Additional information can be obtained by setting the --logfile and --logpriority options
