RFID-Reader für Tierchips FDX-B/HDX
    schick mal das komplette Log vom Restart von EDOMI und einem DELETE Befehl.
    Am Anfang müsste doch noch mehr im Log stehen, z.B. die Liste der aktuell gültigen Keys.
       [TABLE="class: log, border: 0, cellpadding: 0, cellspacing: 0, width: 0, height: 12"]
      [TR]
      [TD]2016-11-02 21:18:02[/TD]
       			[TD]894752[/TD]
       			[TD]7545[/TD]
       			[TD]debug[/TD]
       			[TD]LBS19000372 [v0.3]: RFID Reader LBS started[/TD]
       		[/TR]
      [TR]
       			[TD]907274[/TD]
       			[TD]7545[/TD]
       			[TD]debug[/TD]
       			[TD]LBS19000372 [v0.3]: RFID Reader LBS finished[/TD]
       		[/TR]
      [TR]
       			[TD]974752[/TD]
       			[TD]7593[/TD]
       			[TD]debug[/TD]
       			[TD]EXE19000372 [v0.3]: RFID reader daemon started[/TD]
       		[/TR]
      [TR]
       			[TD]976655[/TD]
       			[TD]7593[/TD]
       			[TD]debug[/TD]
       			[TD]EXE19000372 [v0.3]: Delimiter CARRIAGE RETURN (CR)[/TD]
       		[/TR]
      [TR]
       			[TD]979876[/TD]
       			[TD]7593[/TD]
       			[TD]debug[/TD]
       			[TD]EXE19000372 [v0.3]: Executing SQL Query: CREATE DATABASE IF NOT EXISTS RFID[/TD]
       		[/TR]
      [TR]
       			[TD]981682[/TD]
       			[TD]7593[/TD]
       			[TD]debug[/TD]
       			[TD]EXE19000372 [v0.3]: Executing SQL Query: CREATE TABLE IF NOT EXISTS `tags` (`no` INT(10) NOT NULL AUTO_INCREMENT COMMENT 'Number of Transponder',`id` CHAR(10) NOT NULL COMMENT 'Unique transponder identifier',`name` CHAR(255) NOT NULL DEFAULT '' COMMENT 'Transponder name',`active` BIT(1) NOT NULL DEFAULT 1 COMMENT 'Active Transponder',PRIMARY KEY (`id`), KEY `no` (`no`), KEY `name` (`name`)) ENGINE=InnoDB DEFAULT CHARSET=utf8 COLLATE=utf8_general_ci;[/TD]
       		[/TR]
      [TR]
       			[TD]984164[/TD]
       			[TD]7593[/TD]
       			[TD]debug[/TD]
       			[TD]EXE19000372 [v0.3]: Executing SQL Query: SELECT * from tags;[/TD]
       		[/TR]
      [TR]
       			[TD]986787[/TD]
       			[TD]7593[/TD]
       			[TD]debug[/TD]
       			[TD]EXE19000372 [v0.3]: Valid IDs:[/TD]
       		[/TR]
      [TR]
       			[TD]987023[/TD]
       			[TD]7593[/TD]
       			[TD]debug[/TD]
       			[TD]EXE19000372 [v0.3]: 010BC61A84[/TD]
       		[/TR]
      [TR]
       			[TD]987162[/TD]
       			[TD]7593[/TD]
       			[TD]debug[/TD]
       			[TD]EXE19000372 [v0.3]: 276_093400[/TD]
       		[/TR]
      [TR]
       			[TD]987282[/TD]
       			[TD]7593[/TD]
       			[TD]debug[/TD]
       			[TD]EXE19000372 [v0.3]: 276_098800[/TD]
       		[/TR]
      [TR]
      [TD]2016-11-02 21:18:53[/TD]
       			[TD]982078[/TD]
       			[TD]7545[/TD]
       			[TD]debug[/TD]
       		[/TR]
      [TR]
       			[TD]983705[/TD]
       			[TD]7545[/TD]
       			[TD]debug[/TD]
       			[TD]LBS19000372 [v0.3]: Command sent to daemon: DEL:010BC61A84[/TD]
       		[/TR]
      [TR]
       			[TD]985249[/TD]
       			[TD]7545[/TD]
       			[TD]debug[/TD]
       		[/TR]
      [TR]
       			[TD]987420[/TD]
       			[TD]7593[/TD]
       			[TD]debug[/TD]
       			[TD]EXE19000372 [v0.3]: Starting command execution: DEL[/TD]
       		[/TR]
      [TR]
       			[TD]988790[/TD]
       			[TD]7593[/TD]
       			[TD]debug[/TD]
       			[TD]EXE19000372 [v0.3]: Executing SQL Query: DELETE IGNORE FROM `tags` WHERE `id`=`010BC61A84`;[/TD]
       		[/TR]
      [TR]
       			[TD]990238[/TD]
       			[TD]7593[/TD]
       			[TD]debug[/TD]
       			[TD]EXE19000372 [v0.3]: Deleted RFID tag: 010BC61A84[/TD]
       		[/TR]
      [TR]
      [TD]2016-11-02 21:19:07[/TD]
       			[TD]550518[/TD]
       			[TD]7545[/TD]
       			[TD]debug[/TD]
       		[/TR]
      [TR]
       			[TD]551956[/TD]
       			[TD]7545[/TD]
       			[TD]debug[/TD]
       		[/TR]
      [/TABLE]
      Zuletzt geändert von Robby; 02.11.2016, 21:21.
        jep 8
          ...war schneller
          möchte die 3 Codes aus der Mitte des Logs weg haben, sonst
            das sieht aber jetzt so aus als hätte er den Code gelöscht
            Genau so sollte ein Löschen aussehen:
             [TABLE]
            [TR]
             			[TD]983705[/TD]
             			[TD]7545[/TD]
             			[TD]debug[/TD]
             		[/TR]
            [TR]
             			[TD]985249[/TD]
             			[TD]7545[/TD]
             			[TD]debug[/TD]
             		[/TR]
            [TR]
             			[TD]987420[/TD]
             			[TD]7593[/TD]
             			[TD]debug[/TD]
             		[/TR]
            [TR]
             			[TD]988790[/TD]
             			[TD]7593[/TD]
             			[TD]debug[/TD]
             		[/TR]
            [TR]
             			[TD]990238[/TD]
             			[TD]7593[/TD]
             			[TD]debug[/TD]
             		[/TR]
            [/TABLE]
              Kannst auch mal eine SSH Verbindung öffnen und dann
              mysql
              eingeben
              Danach
              use RFID;
              dann
              select * from tags;
              Dann siehst du die IDs die gespeichert sind. Damit kannst du monitoren ob eine DELETE funktioniert.
              Letzte Option ist dann ein
              drop database RFID;
              Dann iss alles weg und wird beim neuen Aktivieren von EDOMI neu angelegt. Obwohl ich jetzt lieber herausfinden würde, warum das DELETE nicht richtig funktioniert.
                [TR]
                [TD]2016-11-02 21:26:15[/TD]
                 			[TD]371788[/TD]
                 			[TD]7545[/TD]
                 			[TD]debug[/TD]
                 		[/TR]
                [TR]
                 			[TD]373579[/TD]
                 			[TD]7545[/TD]
                 			[TD]debug[/TD]
                 			[TD]LBS19000372 [v0.3]: Command sent to daemon: DEL:276_093400[/TD]
                 		[/TR]
                [TR]
                 			[TD]375134[/TD]
                 			[TD]7545[/TD]
                 			[TD]debug[/TD]
                 		[/TR]
                [TR]
                 			[TD]377381[/TD]
                 			[TD]7593[/TD]
                 			[TD]debug[/TD]
                 		[/TR]
                [TR]
                 			[TD]378822[/TD]
                 			[TD]7593[/TD]
                 			[TD]debug[/TD]
                 			[TD]EXE19000372 [v0.3]: Executing SQL Query: DELETE IGNORE FROM `tags` WHERE `id`=`276_093400`;[/TD]
                 		[/TR]
                [TR]
                 			[TD]380048[/TD]
                 			[TD]7593[/TD]
                 			[TD]debug[/TD]
                 			[TD]EXE19000372 [v0.3]: Deleted RFID tag: 276_093400[/TD]
                 		[/TR]
                [TR]
                [TD]2016-11-02 21:26:35[/TD]
                 			[TD]011462[/TD]
                 			[TD]7545[/TD]
                 			[TD]debug[/TD]
                 		[/TR]
                [TR]
                 			[TD]012602[/TD]
                 			[TD]7545[/TD]
                 			[TD]debug[/TD]
                 			[TD]LBS19000372 [v0.3]: Command sent to daemon: DEL:276_098800[/TD]
                 		[/TR]
                [TR]
                 			[TD]013644[/TD]
                 			[TD]7545[/TD]
                 			[TD]debug[/TD]
                 		[/TR]
                [TR]
                 			[TD]013972[/TD]
                 			[TD]7593[/TD]
                 			[TD]debug[/TD]
                 		[/TR]
                [TR]
                 			[TD]015775[/TD]
                 			[TD]7593[/TD]
                 			[TD]debug[/TD]
                 			[TD]EXE19000372 [v0.3]: Executing SQL Query: DELETE IGNORE FROM `tags` WHERE `id`=`276_098800`;[/TD]
                 		[/TR]
                [TR]
                 			[TD]016940[/TD]
                 			[TD]7593[/TD]
                 			[TD]debug[/TD]
                 			[TD]EXE19000372 [v0.3]: Deleted RFID tag: 276_098800[/TD]
                 		[/TR]
                [TR]
                [TD]2016-11-02 21:26:55[/TD]
                 			[TD]140325[/TD]
                 			[TD]7545[/TD]
                 			[TD]debug[/TD]
                 		[/TR]
                [TR]
                 			[TD]141396[/TD]
                 			[TD]7545[/TD]
                 			[TD]debug[/TD]
                 		[/TR]
                [TR]
                 			[TD]142433[/TD]
                 			[TD]7545[/TD]
                 			[TD]debug[/TD]
                 		[/TR]
                [TR]
                 			[TD]144154[/TD]
                 			[TD]7593[/TD]
                 			[TD]debug[/TD]
                 		[/TR]
                [TR]
                [TD]2016-11-02 21:27:07[/TD]
                 			[TD]401263[/TD]
                 			[TD]7545[/TD]
                 			[TD]debug[/TD]
                 		[/TR]
                [TR]
                 			[TD]402703[/TD]
                 			[TD]7545[/TD]
                 			[TD]debug[/TD]
                 		[/TR]
                [TR]
                [TD]2016-11-02 21:29:04[/TD]
                 			[TD]379992[/TD]
                 			[TD]8451[/TD]
                 			[TD]debug[/TD]
                 		[/TR]
                [TR]
                 			[TD]393944[/TD]
                 			[TD]8451[/TD]
                 			[TD]debug[/TD]
                 		[/TR]
                [TR]
                 			[TD]460473[/TD]
                 			[TD]8548[/TD]
                 			[TD]debug[/TD]
                 		[/TR]
                [TR]
                 			[TD]462069[/TD]
                 			[TD]8548[/TD]
                 			[TD]debug[/TD]
                 		[/TR]
                [TR]
                 			[TD]463702[/TD]
                 			[TD]8548[/TD]
                 			[TD]debug[/TD]
                 		[/TR]
                [TR]
                 			[TD]465209[/TD]
                 			[TD]8548[/TD]
                 			[TD]debug[/TD]
                 		[/TR]
                [TR]
                 			[TD]467253[/TD]
                 			[TD]8548[/TD]
                 			[TD]debug[/TD]
                 		[/TR]
                [TR]
                 			[TD]469338[/TD]
                 			[TD]8548[/TD]
                 			[TD]debug[/TD]
                 		[/TR]
                [TR]
                 			[TD]469619[/TD]
                 			[TD]8548[/TD]
                 			[TD]debug[/TD]
                 		[/TR]
                [TR]
                 			[TD]469774[/TD]
                 			[TD]8548[/TD]
                 			[TD]debug[/TD]
                 		[/TR]
                [TR]
                 			[TD]469901[/TD]
                 			[TD]8548[/TD]
                 			[TD]debug[/TD]
                 		[/TR]
                [/TABLE]
                Ich habe alle 3 Nummern eingegeben zum löschen wie man im Log sieht....die unteren 3 Zeilen sagen wohl das es sie doch noch gibt....auch das Bild vom LBS mit den KO´s NACH dem löschen.
                Ich glaub ich mal lieber morgen weiter
                  ok, ich glaube ich sehs schon ...
                      Mach mal in Zeile 459 aus dem
                      `id` CHAR(10)
                      ein
                      `id` CHAR(20)
                      Und zum Löschen gib mal die Codes so ein, wie sie im Log stehen, also
                       [TABLE]
                      [TR]
                      [TD]276_098800
                      			276_093400
                      			010BC61A84[/TD]
                       		[/TR]
                      [/TABLE]
                        1.pngLBS geändert und alle LBS neu eingelesen...die Codes lassen sich aber trotzdem nicht löschen....die Datenbank zeigt genau das gleiche Bild wie in #54
                        Ich mach mal morgen weiter....
                          sorry vergessen. Du musst die Datenbank löschen. via mysql. wie oben beschrieben
                          mysql
                          drop database RFID;
                          Danach EDOMI neu aktivieren. Dann sind alle Keys weg. Und dann mal Anlegen und Löschen testen.
                          Kannst ja morgen mal berichten.
                            [TR]
                            [TD="colspan: 5"]{EDOMI,CUSTOMLOG_RFID Reader --- LBS19000372.htm,02.11.2016,22:13:07,700074,12888}[/TD]
                             		[/TR]
                            [TR]
                            [TD]Zeitstempel[/TD]
                             			[TD]ms[/TD]
                             			[TD]PID[/TD]
                             			[TD]LogLevel[/TD]
                             			[TD]Meldung[/TD]
                             		[/TR]
                            [TR]
                            [TD]2016-11-02 22:13:07[/TD]
                             			[TD]699891[/TD]
                             			[TD]12888[/TD]
                             			[TD]debug[/TD]
                             		[/TR]
                            [TR]
                             			[TD]712680[/TD]
                             			[TD]12888[/TD]
                             			[TD]debug[/TD]
                             		[/TR]
                            [TR]
                             			[TD]806879[/TD]
                             			[TD]12934[/TD]
                             			[TD]debug[/TD]
                             		[/TR]
                            [TR]
                             			[TD]808959[/TD]
                             			[TD]12934[/TD]
                             			[TD]debug[/TD]
                             		[/TR]
                            [TR]
                             			[TD]811373[/TD]
                             			[TD]12934[/TD]
                             			[TD]debug[/TD]
                             		[/TR]
                            [TR]
                             			[TD]815278[/TD]
                             			[TD]12934[/TD]
                             			[TD]debug[/TD]
                             			[TD]EXE19000372 [v0.3]: Executing SQL Query: CREATE TABLE IF NOT EXISTS `tags` (`no` INT(10) NOT NULL AUTO_INCREMENT COMMENT 'Number of Transponder',`id` CHAR(20) NOT NULL COMMENT 'Unique transponder identifier',`name` CHAR(255) NOT NULL DEFAULT '' COMMENT 'Transponder name',`active` BIT(1) NOT NULL DEFAULT 1 COMMENT 'Active Transponder',PRIMARY KEY (`id`), KEY `no` (`no`), KEY `name` (`name`)) ENGINE=InnoDB DEFAULT CHARSET=utf8 COLLATE=utf8_general_ci;[/TD]
                             		[/TR]
                            [TR]
                             			[TD]826380[/TD]
                             			[TD]12934[/TD]
                             			[TD]debug[/TD]
                             		[/TR]
                            [TR]
                             			[TD]828509[/TD]
                             			[TD]12934[/TD]
                             			[TD]debug[/TD]
                             		[/TR]
                            [TR]
                            [TD]2016-11-02 22:13:33[/TD]
                             			[TD]801765[/TD]
                             			[TD]12888[/TD]
                             			[TD]debug[/TD]
                             		[/TR]
                            [TR]
                             			[TD]803219[/TD]
                             			[TD]12888[/TD]
                             			[TD]debug[/TD]
                             			[TD]LBS19000372 [v0.3]: Command sent to daemon: READ:[/TD]
                             		[/TR]
                            [TR]
                             			[TD]804688[/TD]
                             			[TD]12888[/TD]
                             			[TD]debug[/TD]
                             		[/TR]
                            [TR]
                             			[TD]806762[/TD]
                             			[TD]12934[/TD]
                             			[TD]debug[/TD]
                             			[TD]EXE19000372 [v0.3]: Starting command execution: READ[/TD]
                             		[/TR]
                            [TR]
                             			[TD]809231[/TD]
                             			[TD]12934[/TD]
                             			[TD]debug[/TD]
                             			[TD]EXE19000372 [v0.3]: RFID tag list:[/TD]
                             		[/TR]
                            [TR]
                            [TD]2016-11-02 22:14:09[/TD]
                             			[TD]856704[/TD]
                             			[TD]12888[/TD]
                             			[TD]debug[/TD]
                             		[/TR]
                            [TR]
                             			[TD]858247[/TD]
                             			[TD]12888[/TD]
                             			[TD]debug[/TD]
                             			[TD]LBS19000372 [v0.3]: Command sent to daemon: ADD:276_093400688440[/TD]
                             		[/TR]
                            [TR]
                             			[TD]859746[/TD]
                             			[TD]12888[/TD]
                             			[TD]debug[/TD]
                             		[/TR]
                            [TR]
                             			[TD]862346[/TD]
                             			[TD]12934[/TD]
                             			[TD]debug[/TD]
                             			[TD]EXE19000372 [v0.3]: Starting command execution: ADD[/TD]
                             		[/TR]
                            [TR]
                             			[TD]863877[/TD]
                             			[TD]12934[/TD]
                             			[TD]debug[/TD]
                             			[TD]EXE19000372 [v0.3]: Executing SQL Query: REPLACE INTO `tags` SET `id`= '276_093400688440', `active`=1;[/TD]
                             		[/TR]
                            [TR]
                             			[TD]865326[/TD]
                             			[TD]12934[/TD]
                             			[TD]debug[/TD]
                             			[TD]EXE19000372 [v0.3]: Added RFID tag: 276_093400688440[/TD]
                             		[/TR]
                            [TR]
                            [TD]2016-11-02 22:14:48[/TD]
                             			[TD]242579[/TD]
                             			[TD]12888[/TD]
                             			[TD]debug[/TD]
                             		[/TR]
                            [TR]
                             			[TD]243760[/TD]
                             			[TD]12888[/TD]
                             			[TD]debug[/TD]
                             			[TD]LBS19000372 [v0.3]: Command sent to daemon: ADD:276_098800005234[/TD]
                             		[/TR]
                            [TR]
                             			[TD]244884[/TD]
                             			[TD]12888[/TD]
                             			[TD]debug[/TD]
                             		[/TR]
                            [TR]
                             			[TD]250370[/TD]
                             			[TD]12934[/TD]
                             			[TD]debug[/TD]
                             		[/TR]
                            [TR]
                             			[TD]251756[/TD]
                             			[TD]12934[/TD]
                             			[TD]debug[/TD]
                             			[TD]EXE19000372 [v0.3]: Executing SQL Query: REPLACE INTO `tags` SET `id`= '276_098800005234', `active`=1;[/TD]
                             		[/TR]
                            [TR]
                             			[TD]253137[/TD]
                             			[TD]12934[/TD]
                             			[TD]debug[/TD]
                             			[TD]EXE19000372 [v0.3]: Added RFID tag: 276_098800005234[/TD]
                             		[/TR]
                            [TR]
                            [TD]2016-11-02 22:15:01[/TD]
                             			[TD]232916[/TD]
                             			[TD]12888[/TD]
                             			[TD]debug[/TD]
                             		[/TR]
                            [TR]
                             			[TD]234363[/TD]
                             			[TD]12888[/TD]
                             			[TD]debug[/TD]
                             		[/TR]
                            [TR]
                            [TD]2016-11-02 22:15:47[/TD]
                             			[TD]269417[/TD]
                             			[TD]13311[/TD]
                             			[TD]debug[/TD]
                             		[/TR]
                            [TR]
                             			[TD]281632[/TD]
                             			[TD]13311[/TD]
                             			[TD]debug[/TD]
                             		[/TR]
                            [TR]
                             			[TD]359992[/TD]
                             			[TD]13359[/TD]
                             			[TD]debug[/TD]
                             		[/TR]
                            [TR]
                             			[TD]362015[/TD]
                             			[TD]13359[/TD]
                             			[TD]debug[/TD]
                             		[/TR]
                            [TR]
                             			[TD]363730[/TD]
                             			[TD]13359[/TD]
                             			[TD]debug[/TD]
                             		[/TR]
                            [TR]
                             			[TD]365405[/TD]
                             			[TD]13359[/TD]
                             			[TD]debug[/TD]
                             		[/TR]
                            [TR]
                             			[TD]367820[/TD]
                             			[TD]13359[/TD]
                             			[TD]debug[/TD]
                             		[/TR]
                            [TR]
                             			[TD]369956[/TD]
                             			[TD]13359[/TD]
                             			[TD]debug[/TD]
                             		[/TR]
                            [TR]
                             			[TD]370206[/TD]
                             			[TD]13359[/TD]
                             			[TD]debug[/TD]
                             			[TD]EXE19000372 [v0.3]: 276_093400688440[/TD]
                             		[/TR]
                            [TR]
                             			[TD]370343[/TD]
                             			[TD]13359[/TD]
                             			[TD]debug[/TD]
                             			[TD]EXE19000372 [v0.3]: 276_098800005234[/TD]
                             		[/TR]
                            [TR]
                            [TD]2016-11-02 22:16:04[/TD]
                             			[TD]502443[/TD]
                             			[TD]13359[/TD]
                             			[TD]debug[/TD]
                             			[TD]EXE19000372 [v0.3]: RFID ID received (HEX/ASC): 3237365f3039333430303638383434300d / 276_093400688440[/TD]
                             		[/TR]
                            [TR]
                             			[TD]508879[/TD]
                             			[TD]13359[/TD]
                             			[TD]debug[/TD]
                             			[TD]EXE19000372 [v0.3]: Access granted to RFID key (Name/Key): 1/276_093400688440[/TD]
                             		[/TR]
                            [TR]
                            [TD]2016-11-02 22:16:23[/TD]
                             			[TD]654844[/TD]
                             			[TD]13311[/TD]
                             			[TD]debug[/TD]
                             		[/TR]
                            [TR]
                             			[TD]656563[/TD]
                             			[TD]13311[/TD]
                             			[TD]debug[/TD]
                             		[/TR]
                            [TR]
                             			[TD]657995[/TD]
                             			[TD]13311[/TD]
                             			[TD]debug[/TD]
                             		[/TR]
                            [TR]
                             			[TD]663254[/TD]
                             			[TD]13359[/TD]
                             			[TD]debug[/TD]
                             		[/TR]
                            [TR]
                             			[TD]665843[/TD]
                             			[TD]13359[/TD]
                             			[TD]debug[/TD]
                             			[TD]EXE19000372 [v0.3]: RFID tag list: [[1][276_093400688440]][[2][276_098800005234]][/TD]
                             		[/TR]
                            [TR]
                            [TD]2016-11-02 22:16:46[/TD]
                             			[TD]689845[/TD]
                             			[TD]13311[/TD]
                             			[TD]debug[/TD]
                             		[/TR]
                            [TR]
                             			[TD]690989[/TD]
                             			[TD]13311[/TD]
                             			[TD]debug[/TD]
                             			[TD]LBS19000372 [v0.3]: Command sent to daemon: DEL:276_098800005234[/TD]
                             		[/TR]
                            [TR]
                             			[TD]692006[/TD]
                             			[TD]13311[/TD]
                             			[TD]debug[/TD]
                             		[/TR]
                            [TR]
                             			[TD]697416[/TD]
                             			[TD]13359[/TD]
                             			[TD]debug[/TD]
                             		[/TR]
                            [TR]
                             			[TD]698940[/TD]
                             			[TD]13359[/TD]
                             			[TD]debug[/TD]
                             			[TD]EXE19000372 [v0.3]: Executing SQL Query: DELETE IGNORE FROM `tags` WHERE `id`=`276_098800005234`;[/TD]
                             		[/TR]
                            [TR]
                             			[TD]700135[/TD]
                             			[TD]13359[/TD]
                             			[TD]debug[/TD]
                             			[TD]EXE19000372 [v0.3]: Deleted RFID tag: 276_098800005234[/TD]
                             		[/TR]
                            [TR]
                            [TD]2016-11-02 22:17:15[/TD]
                             			[TD]179657[/TD]
                             			[TD]13311[/TD]
                             			[TD]debug[/TD]
                             		[/TR]
                            [TR]
                             			[TD]181201[/TD]
                             			[TD]13311[/TD]
                             			[TD]debug[/TD]
                             		[/TR]
                            [/TABLE]
                            Das löschen der Datenbank hat geklappt....anlegen der 15-stelligen Codes auch....Werden jetzt auch richtig in der Code List angezeigt
                            Löschen klappt scheinbar nicht.....
                            Rest wirklich morgen....wäre jetzt nur noch zur Fehlersuche....komme ja damit zurecht wenn ich die datenbank lösche und nur meine Codes einlese..Trotzdem mal wieder vieeelen Dank
                              Nur so am Rande: Warum nicht 'id' als varchar(1000) oder so?
                                Wir müssen doch Speicherplatz sparen
                                Aber ja, du hast schon recht. Im Update des LBS werde ich etwas großzügiger sein.
                                Nicht das nachher noch Elefanten durch die Katzenklappe kommen
