Ich kann aktuell die knxproj nicht mehr einlesen:
Hier das Log:
Hat jemand eine Idee?
Hier das Log:
Logger: homeassistant.components.websocket_api.http.connection Quelle: components/knx/project.py:124 Integration: Home Assistant WebSocket API ([URL="https://www.home-assistant.io/integrations/websocket_api"]Dokumentation[/URL], [URL="https://github.com/home-assistant/core/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+websocket_api%22"]Probleme[/URL]) Erstmals aufgetreten: 22:28:18 (1 Vorkommnisse) Zuletzt protokolliert: 22:28:18 [139944937181040] Error handling message: Unknown error (unknown_error) Daniel from 10.38.111.48 (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/129.0.0.0 Safari/537.36 Edg/129.0.0.0)Traceback (most recent call last): File "/usr/src/homeassistant/homeassistant/components/websocket_api/decorators.py", line 28, in _handle_async_response await func(hass, connection, msg) File "/usr/src/homeassistant/homeassistant/components/knx/websocket.py", line 132, in with_knx await func(hass, knx, connection, msg) File "/usr/src/homeassistant/homeassistant/components/knx/websocket.py", line 231, in ws_project_file_process await knx.project.process_project_file( File "/usr/src/homeassistant/homeassistant/components/knx/project.py", line 126, in process_project_file project = await self.hass.async_add_executor_job(_parse_project) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run result = self.fn(*self.args, **self.kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/src/homeassistant/homeassistant/components/knx/project.py", line 124, in _parse_project return xknxproj.parse() ^^^^^^^^^^^^^^^^ File "/usr/local/lib/python3.12/site-packages/xknxproject/xknxproj.py", line 42, in parse project = XMLParser(knx_project_content).parse(self.language) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/local/lib/python3.12/site-packages/xknxproject/xml/parser.py", line 143, in parse self._load(language=language) File "/usr/local/lib/python3.12/site-packages/xknxproject/xml/parser.py", line 248, in _load device.merge_application_program_info(_application) File "/usr/local/lib/python3.12/site-packages/xknxproject/models/models.py", line 198, in merge_application_program_info com_instance.merge_application_program_info( File "/usr/local/lib/python3.12/site-packages/xknxproject/models/models.py", line 416, in merge_application_program_info self._merge_from_parent_object(com_object_ref, parameters=parameters) File "/usr/local/lib/python3.12/site-packages/xknxproject/models/models.py", line 432, in _merge_from_parent_object com_object.com_object_ref_text_with_paramter( File "/usr/local/lib/python3.12/site-packages/xknxproject/models/models.py", line 746, in com_object_ref_text_with_paramter parameter_instance_ref = util.text_parameter_insert_module_instance( ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/local/lib/python3.12/site-packages/xknxproject/util.py", line 146, in text_parameter_insert_module_instance _parameter_ref = text_parameter_ref_id.split("_P-")[1] ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^^^ IndexError: list index out of range
