Wird sind ja genau dafür da
Jetzt steht nix der Lernfunktion im Weg
// Definition of the Communication Objects attached to the device KnxComObject KnxDevice::_comObjectsList[] = { /* don't change this */ Tools.createProgComObject(), // Currently, Sketch Index and Suite Index differ for ComObjects :-( /* Sketch-Index 1, Suite-Index 0 : */ KnxComObject(G_ADDR(0, 0, 1), KNX_DPT_9_001, COM_OBJ_SENSOR), // Temperatur Messwert /* Sketch-Index 2, Suite-Index 1 : */ KnxComObject(G_ADDR(0, 0, 2), KNX_DPT_1_001, COM_OBJ_SENSOR), // Temperatur unterer Meldewert /* Sketch-Index 3, Suite-Index 2 : */ KnxComObject(G_ADDR(0, 0, 3), KNX_DPT_1_001, COM_OBJ_SENSOR), // Temperatur oberer Meldewert };
// Definition of the Communication Objects attached to the device KnxComObject KnxDevice::_comObjectsList[] = { /* don't change this */ Tools.createProgComObject(), // Currently, Sketch Index and Suite Index differ for ComObjects :-( /* Sketch-Index 1, Suite-Index 0 : */ KnxComObject(KNX_DPT_9_001, COM_OBJ_SENSOR), // Temperatur Messwert /* Sketch-Index 2, Suite-Index 1 : */ KnxComObject(KNX_DPT_1_001, COM_OBJ_SENSOR), // Temperatur unterer Meldewert /* Sketch-Index 3, Suite-Index 2 : */ KnxComObject(KNX_DPT_1_001, COM_OBJ_SENSOR), // Temperatur oberer Meldewert };
In file included from /Volumes/SuperNussDrive/hanskeller/Documents/Arduino/libraries/KonnektingDeviceLibrary-1.0.0-BETA2/KnxDevice.h:36:0, from DemoSensor_Temp_RH.ino:11: /Volumes/SuperNussDrive/hanskeller/Documents/Arduino/libraries/KonnektingDeviceLibrary-1.0.0-BETA2/KnxTools.h:32:20: fatal error: EEPROM.h: No such file or directory #include <EEPROM.h> ^ compilation terminated. Fehler beim Kompilieren.
