Making first setup work ...
    Hi Tuxedo, tomorrow I'll make some time to work further on this. Today & tonight too busy. Thanks for the video!
      KONNEKTING Suite - Version 1.0.0-BETA3 Build 2016-04-13_09-07-40 DEBUG MODE!
      Betriebssystem: Windows 8.1
      KNX Verbindung: IP-Interface
      [Programmiere] 1.1.50 KONNEKTING Test Sketch
      [Programmiere] Initialisiere ...
      [Programmiere] Lese KOs ...
      [Programmiere] Lese Parameter ...
      [Programmiere] Fortschritt: 1/8
      [Programmiere] Bitte 'Programmieren' Knopf drücken...
      KNX Telegramm entdeckt. Verbindung scheint in Ordnung zu sein.
      [Programmiere] Fortschritt: 2/8
      [Programmiere] Starte programmierung...
      [Programmiere] Fortschritt: 3/8
      [Programmiere] Schreibe KO #0 / aktiv=false
      [Programmiere] Fortschritt: 4/8
      [Programmiere] Schreibe KO #1 / aktiv=false
      [Programmiere] Fortschritt: 5/8
      [Programmiere] Schreibe Parameter #0
      [Programmiere] Fortschritt: 6/8
      [Programmiere] Beende Programmierung...
      [Programmiere] Fortschritt: 7/8
      [Programmiere] Veranlasse Geräteneustart...
      [Programmiere] Fortschritt: 8/8
      [Programmiere] Fertig!
      [Programmiere] Fertig! Dauer: 20866 ms
      Setup KnxTools
      createProgComObject
      Manufacturer: DEADhex
      Device: FFhex
      Revision: 0hex
      numberOfCommObjects: 3
      _deviceFlags: 10001bin
      Using EEPROM
      ComObj index=1 Suite-ID=0 HI: 0x0 LO: 0x1 GA: 0x1 Settings: 0x80 Active: 1
      ComObj index=2 Suite-ID=1 HI: 0x0 LO: 0x2 GA: 0x2 Settings: 0x80 Active: 1
      IA: 0x11C7
      KnxDevice startup status: 0x0
      getParamValue: index=0 _paramTableStartindex=19 skipBytes=0 paramLen=2
       val[0]@19 --> 0xFF
       val[1]@20 --> 0xFF
      Toggle every 4294967295 ms
      Setup is ready. go to loop...
      PROGBUTTON toggle
      PROGBUTTON 1
      PROGBUTTON toggle
      PROGBUTTON 0
      PROGBUTTON toggle
      PROGBUTTON 1
      PROGBUTTON toggle
      PROGBUTTON 0
      PROGBUTTON toggle
      PROGBUTTON 1
      knxToolsEvents index=0
      internalComObject index=0
      buffer[0]    hex=0x0      bin=0
      buffer[1]    hex=0x1      bin=1
      buffer[2]    hex=0x11      bin=10001
      buffer[3]    hex=0x32      bin=110010
      buffer[4]    hex=0x0      bin=0
      buffer[5]    hex=0x0      bin=0
      buffer[6]    hex=0x0      bin=0
      buffer[7]    hex=0x0      bin=0
      buffer[8]    hex=0x0      bin=0
      buffer[9]    hex=0x0      bin=0
      buffer[10]    hex=0x0      bin=0
      buffer[11]    hex=0x0      bin=0
      buffer[12]    hex=0x0      bin=0
      buffer[13]    hex=0x0      bin=0
      protocolversion=0x0
      msgType=0x1
      handleMsgReadDeviceInfo
      no matching IA
      buffer[1]    hex=0x15      bin=10101
      buffer[2]    hex=0x0      bin=0
      buffer[3]    hex=0x0      bin=0
      protocolversion=0x0
      msgType=0x15
      handleMsgReadIndividualAddress
      buffer[1]    hex=0x14      bin=10100
      protocolversion=0x0
      msgType=0x14
      handleMsgWriteIndividualAddress
      memUpdate: index=1 data=0x11
      memUpdate: index=2 data=0x32
      DeviceFlags after =0x11
      memUpdate: index=0 data=0x11
      sendAck errorcode=0x0 indexinformation=0x0
      buffer[1]    hex=0xA      bin=1010
      buffer[4]    hex=0x1      bin=1
      protocolversion=0x0
      msgType=0xA
      handleMsgWriteProgrammingMode
      matching IA
      PROGBUTTON 1
      buffer[1]    hex=0xB      bin=1011
      protocolversion=0x0
      msgType=0xB
      handleMsgReadProgrammingMode
      protocolversion=0x0
      msgType=0x1
      buffer[1]    hex=0x28      bin=101000
      protocolversion=0x0
      msgType=0x28
      handleMsgWriteComObject
      CO id=0 hi=0x0 lo=0x0 ga=0x0 settings=0x0
      memUpdate: index=10 data=0x0
      memUpdate: index=11 data=0x0
      memUpdate: index=12 data=0x0
      buffer[2]    hex=0x1      bin=1
      protocolversion=0x0
      msgType=0x28
      CO id=1 hi=0x0 lo=0x0 ga=0x0 settings=0x0
      memUpdate: index=13 data=0x0
      memUpdate: index=14 data=0x0
      memUpdate: index=15 data=0x0
      buffer[1]    hex=0x1E      bin=11110
      buffer[3]    hex=0x3      bin=11
      buffer[4]    hex=0xE8      bin=11101000
      protocolversion=0x0
      msgType=0x1E
      handleMsgWriteParameter
      id=0
       data[0]=0x3
      memUpdate: index=19 data=0x3
       data[1]=0xE8
      memUpdate: index=20 data=0xE8
      protocolversion=0x0
      msgType=0xA
      matching IA
      PROGBUTTON 0
      buffer[1]    hex=0x9      bin=1001
      protocolversion=0x0
      msgType=0x9
      handleMsgRestart
      matching IA
      WDT reset NOW
      Setup KnxTools
      createProgComObject
      Device: FFhex
      Revision: 0hex
      Using EEPROM
      ComObj index=1 Suite-ID=0 HI: 0x0 LO: 0x0 GA: 0x0 Settings: 0x0 Active: 0
      ComObj index=2 Suite-ID=1 HI: 0x0 LO: 0x0 GA: 0x0 Settings: 0x0 Active: 0
      IA: 0x1132
       val[0]@19 --> 0x3
       val[1]@20 --> 0xE8
      Toggle every 1000 ms
      Actual state: 0
      Actual state: 1
      Actual state: 0
      Actual state: 1
      Actual state: 0
      Actual state: 1
      Actual state: 0
      Actual state: 1
      Actual state: 0
      Actual state: 1
      Actual state: 0
      Actual state: 1
      Actual state: 0
      Actual state: 1
      Actual state: 0
      Actual state: 1
      Actual state: 0
      Actual state: 1
      Actual state: 0
      Actual state: 1
      Whoohoo it's working now . I did shutdown my RaspberryPi while doing a new attempt. I think I was using the same tunneling address at the same time... Tomorrow I'll try to do the HTU21 sketch. Thanks a lot for helping me out Tuxedo & Eugenius .
        Hey,
        that are good news. Wow.
        Could you do me a favor? Switch the Suite to english... Otherwise I have no idea why I invested the time to implement i18n :-(
          Now I have the temp/RH sketch working! BTW, I modified the .bat file so the suite starts in English
            Zitat von Eugenius Beitrag anzeigen
            I have allready working Sketch for DS18B20, i can share it with you.
            BME280 is similar to HTU21D=DemoSketch
            Also interested in this one :-).
              Check this out:
              https://github.com/KONNEKTING/Konnek...Sensor_DS18B20
                Hi there! I am familiarizing myself with the konnekting library, and it seems promising for my needs (simple sensors, etc). However I cannot get my Sparkfun (copy) Pro Micro 3.3V model into Programming mode. I use a Siemens 5wg1117-2AB12 BCU. When I push the button a LED lights up on the board.
                I appreciate any help, thank you!
                My config in the ino file:
                #define KNX_SERIAL Serial1 // D0=RX/D1=TX
                #define PROG_LED_PIN 17 // External LED
                #define TEST_LED LED_BUILTIN // On board LED on pin D13
                #define PROG_BUTTON_PIN 7 // pin with interrupt
                #define DEBUGSERIAL Serial // USB port
                Datasheet: https://learn.sparkfun.com/tutorials...okup-guide/all
                The strange thing is that the console only logs this:
                16:19:54.416 -> DEBUG! free ram: 1935 bytes
                16:19:54.416 -> KONNEKTING DemoSketch
                16:19:54.416 -> Toggle LED every 2500 ms.
                16:19:54.416 -> Setup is ready. go to loop...
                And not the toggling so the Konnekting.isReadyForApplication() seems to be false. However when I try to program the device through Konnekting Suite or even ETS (with self generated knxprod) the device is not recognized and the tools are saying to press the prog button.
                Thank you!
