SVN version bricht interessant zusammen:
Wenn is save mache, kriege ich zurueck
<br /> <b>Warning</b>: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in <b>/var/www/localhost/htdocs/comet-visu/editor/bin/save_config.php</b> on line <b>56</b><br /> {"success":true,"message":"all good, file \/var\/www\/localhost\/htdocs\/comet-visu\/config\/visu_config.xml saved"}
was natuerlich JSON zum zusammenbrechen bringt in jQuery mit
kryptischen Meldungen.
Abhilfe ? irgendein krypto php.ini setting ?
danke
-- tony
danke
-- tony
