So, alles repariert, scheint wieder ordentlich zu laufen. Neue Version steht im SVN.
PelliX
PelliX
<?php
// MySQL
$mysql_db = "db_name";
$mysql_table = "tbl_name";
$mysql_user = "user";
$mysql_pass = "password";
$mysql_srv = "mysql.local.lan";
// SQLite
$dbfile = "/my/local/rsslog.db";
// MySQL connection
mysql_connect($mysql_srv, $mysql_user, $mysql_pass) or
die ("database connection failed!" . mysql_error());
mysql_select_db($mysql_db) or
die ("database cannot be located!" . mysql_error());
// create database connection
$db = sqlite_open($dbfile, 0666, $error);
if (!$db) die ($error);
// fetch and copy data
$result = retrieve($db);
while( sqlite_has_more($result) )
$row = sqlite_fetch_array($result, SQLITE_ASSOC );
$id = $row['id'];
$title = $row['title'];
$content = $row['content'];
$tags = $row['tags'];
$state = $row['state'];
$t = $row['t'];
$mysql_q = "INSERT INTO " . $mysql_table . " (id,title,content,tags,state,t) VALUES " .
"('" . $id . "', '" . $title . "', '" . $content . "', '" . $tags . "', '" .
$state . "', '" . $t . "')";
mysql_query($mysql_q);
// get SQLite data
function retrieve($db)
$q = "SELECT id, title, content, tags, state, t FROM Logs";
return sqlite_query( $db, $q, SQLITE_ASSOC );
# php5-cgi --version PHP 5.2.6-1+lenny16 with Suhosin-Patch 0.9.6.2 (cgi-fcgi) (built: Feb 3 2012 13:10:53) Copyright (c) 1997-2008 The PHP Group Zend Engine v2.2.0, Copyright (c) 1998-2008 Zend Technologies
