Was ist eigentlich aus dem doch coolen Material Design geworden? Läuft es bei euch (Alltime, Incognito666) noch?
lg
Robert
lg
Robert
</xsd:schema>
<xsd:complexType name="menu">
</xsd:complexType>
<xsd:complexType name="header">
</xsd:complexType>
<xsd:complexType name="popup">
<xsd:attribute name="title" type="label" use="optional" />
</xsd:complexType>
[B]Warning[/B]: DOMDocument::schemaValidate(): Invalid Schema in [B]C:\xampp\htdocs\Material\src\check_config.php[/B] on line [B]127[/B] config [B]config/visu_config.xml is NOT [/B] valid XML [HR][/HR]The config file uses a library version of '8', current version is '8', so this is up to date. [HR][/HR] [B]Notice[/B]: Undefined variable: return in [B]C:\xampp\htdocs\Material\src\check_config.php[/B] on line [B]46[/B] [B]Error 3004[/B]: attribute decl. 'title', attribute 'type': The QName value 'label' does not resolve to a(n) simple type definition. on [URL="http://localhost/Material/src/check_config.php?config=#1372"]line [B]1373[/B][/URL] 1370: [COLOR=#0000ff]<[COLOR=#808000]switch[/COLOR] [COLOR=#800080]mapping[/COLOR]=[COLOR=#ff00ff]"OnOff"[/COLOR] [COLOR=#800080]bind_click_to_widget[/COLOR]=[COLOR=#ff00ff]"false"[/COLOR]>[/COLOR] 1371: [COLOR=#0000ff]<[COLOR=#808000]label[/COLOR]>[/COLOR]Treppenspots[COLOR=#0000ff]</[COLOR=#808000]label[/COLOR]>[/COLOR] 1372: [COLOR=#0000ff]<[COLOR=#808000]address[/COLOR] [COLOR=#800080]transform[/COLOR]=[COLOR=#ff00ff]"DPT:1.001"[/COLOR] [COLOR=#800080]mode[/COLOR]=[COLOR=#ff00ff]"write"[/COLOR]>[/COLOR]11/1/30[COLOR=#0000ff]</[COLOR=#808000]address[/COLOR]>[/COLOR] [B]1373: [COLOR=#0000ff]<[COLOR=#808000]address[/COLOR] [COLOR=#800080]transform[/COLOR]=[COLOR=#ff00ff]"DPT:1.011"[/COLOR] [COLOR=#800080]mode[/COLOR]=[COLOR=#ff00ff]"read"[/COLOR]>[/COLOR]11/1/31[COLOR=#0000ff]</[COLOR=#808000]address[/COLOR]>[/COLOR] [/B]1374: [COLOR=#0000ff]</[COLOR=#808000]switch[/COLOR]>[/COLOR] 1375: [COLOR=#0000ff]<[COLOR=#808000]info[/COLOR] [COLOR=#800080]mapping[/COLOR]=[COLOR=#ff00ff]"OnOffStatus"[/COLOR] [COLOR=#800080]flavour[/COLOR]=[COLOR=#ff00ff]"description"[/COLOR] [COLOR=#800080]align[/COLOR]=[COLOR=#ff00ff]"left"[/COLOR]>[/COLOR] 1376: [COLOR=#0000ff]<[COLOR=#808000]layout[/COLOR] [COLOR=#800080]colspan[/COLOR]=[COLOR=#ff00ff]"3"[/COLOR]/>[/COLOR]
[B]Notice[/B]: Undefined variable: return in [B]C:\xampp\htdocs\Material\t\src\check_config.php[/B] on line [B]46[/B] [B]Error 1871[/B]: Element 'header': This element is not expected. Expected is one of ( line, break, text, switch, toggle, trigger, refresh, pushbutton, urltrigger, multitrigger ). on [URL="http://localhost/Material/t/src/check_config.php?config=#705"]line [B]706[/B][/URL] 703: 704: [COLOR=#0000ff]<[COLOR=#808000]page[/COLOR] [COLOR=#800080]name[/COLOR]=[COLOR=#ff00ff]"Start"[/COLOR] [COLOR=#800080]showtopnavigation[/COLOR]=[COLOR=#ff00ff]"false"[/COLOR] [COLOR=#800080]showfooter[/COLOR]=[COLOR=#ff00ff]"false"[/COLOR] [COLOR=#800080]shownavbar-left[/COLOR]=[COLOR=#ff00ff]"true"[/COLOR]>[/COLOR] 705: [COLOR=#0000ff]<[COLOR=#808000]navbar[/COLOR] [COLOR=#800080]position[/COLOR]=[COLOR=#ff00ff]"top"[/COLOR]>[/COLOR] [B] 706: [COLOR=#0000ff]<[COLOR=#808000]header[/COLOR]>[/COLOR] [/B] 707: [COLOR=#0000ff]<[COLOR=#808000]layout[/COLOR] [COLOR=#800080]colspan[/COLOR]=[COLOR=#ff00ff]"8"[/COLOR]/>[/COLOR] 708: [COLOR=#0000ff]</[COLOR=#808000]header[/COLOR]>[/COLOR] 709: [COLOR=#0000ff]<[COLOR=#808000]group[/COLOR] [COLOR=#800080]nowidget[/COLOR]=[COLOR=#ff00ff]"true"[/COLOR]>[/COLOR] [B]Notice[/B]: Undefined variable: return in [B]C:\xampp\htdocs\Material\t\src\check_config.php[/B] on line [B]46[/B] [B]Error 1871[/B]: Element 'menu': This element is not expected. Expected is one of ( line, break, text, switch, toggle, trigger, refresh, pushbutton, urltrigger, multitrigger ). on [URL="http://localhost/Material/t/src/check_config.php?config=#729"]line [B]730[/B][/URL] 727: [COLOR=#0000ff]</[COLOR=#808000]group[/COLOR]>[/COLOR] 728: [COLOR=#0000ff]</[COLOR=#808000]navbar[/COLOR]>[/COLOR] 729: [COLOR=#0000ff]<[COLOR=#808000]navbar[/COLOR] [COLOR=#800080]position[/COLOR]=[COLOR=#ff00ff]"left"[/COLOR] [COLOR=#800080]dynamic[/COLOR]=[COLOR=#ff00ff]"true"[/COLOR] [COLOR=#800080]width[/COLOR]=[COLOR=#ff00ff]"250"[/COLOR]>[/COLOR] [B] 730: [COLOR=#0000ff]<[COLOR=#808000]menu[/COLOR]/>[/COLOR] [/B] 731: [COLOR=#0000ff]</[COLOR=#808000]navbar[/COLOR]>[/COLOR] 732: 733: [COLOR=#0000ff]<[COLOR=#808000]page[/COLOR] [COLOR=#800080]name[/COLOR]=[COLOR=#ff00ff]"[DesktopHeader][0.0]Zentral"[/COLOR] [COLOR=#800080]visible[/COLOR]=[COLOR=#ff00ff]"false"[/COLOR]>[/COLOR] [B]Notice[/B]: Undefined variable: return in [B]C:\xampp\htdocs\Material\t\src\check_config.php[/B] on line [B]46[/B] [B]Error 1866[/B]: Element 'info', attribute 'bind_click_to_widget': The attribute 'bind_click_to_widget' is not allowed. on [URL="http://localhost/Material/t/src/check_config.php?config=#822"]line [B]823[/B][/URL] 820: [COLOR=#0000ff]</[COLOR=#808000]group[/COLOR]>[/COLOR] 821: [COLOR=#0000ff]<[COLOR=#808000]group[/COLOR]>[/COLOR] 822: [COLOR=#0000ff]<[COLOR=#808000]layout[/COLOR] [COLOR=#800080]colspan[/COLOR]=[COLOR=#ff00ff]"8"[/COLOR]/>[/COLOR] [B] 823: [COLOR=#0000ff]<[COLOR=#808000]info[/COLOR] [COLOR=#800080]mapping[/COLOR]=[COLOR=#ff00ff]"DoorOpenClose"[/COLOR] [COLOR=#800080]bind_click_to_widget[/COLOR]=[COLOR=#ff00ff]"false"[/COLOR]>[/COLOR] [/B] 824: [COLOR=#0000ff]<[COLOR=#808000]layout[/COLOR] [COLOR=#800080]colspan[/COLOR]=[COLOR=#ff00ff]"4"[/COLOR]/>[/COLOR] 825: [COLOR=#0000ff]<[COLOR=#808000]label[/COLOR]>[/COLOR]Zentral[COLOR=#0000ff]</[COLOR=#808000]label[/COLOR]>[/COLOR] 826: [COLOR=#0000ff]<[COLOR=#808000]address[/COLOR] [COLOR=#800080]transform[/COLOR]=[COLOR=#ff00ff]"DPT:1.019"[/COLOR] [COLOR=#800080]mode[/COLOR]=[COLOR=#ff00ff]"read"[/COLOR]>[/COLOR]0/3/0[COLOR=#0000ff]</[COLOR=#808000]address[/COLOR]>[/COLOR] [B]Notice[/B]: Undefined variable: return in [B]C:\xampp\htdocs\Material\t\src\check_config.php[/B] on line [B]46[/B] [B]Error 1866[/B]: Element 'info', attribute 'bind_click_to_widget': The attribute 'bind_click_to_widget' is not allowed. on [URL="http://localhost/Material/t/src/check_config.php?config=#827"]line [B]828[/B][/URL] 825: [COLOR=#0000ff]<[COLOR=#808000]label[/COLOR]>[/COLOR]Zentral[COLOR=#0000ff]</[COLOR=#808000]label[/COLOR]>[/COLOR] 826: [COLOR=#0000ff]<[COLOR=#808000]address[/COLOR] [COLOR=#800080]transform[/COLOR]=[COLOR=#ff00ff]"DPT:1.019"[/COLOR] [COLOR=#800080]mode[/COLOR]=[COLOR=#ff00ff]"read"[/COLOR]>[/COLOR]0/3/0[COLOR=#0000ff]</[COLOR=#808000]address[/COLOR]>[/COLOR] 827: [COLOR=#0000ff]</[COLOR=#808000]info[/COLOR]>[/COLOR] [B] 828: [COLOR=#0000ff]<[COLOR=#808000]info[/COLOR] [COLOR=#800080]mapping[/COLOR]=[COLOR=#ff00ff]"DoorOpenClose"[/COLOR] [COLOR=#800080]bind_click_to_widget[/COLOR]=[COLOR=#ff00ff]"false"[/COLOR]>[/COLOR] [/B] 829: [COLOR=#0000ff]<[COLOR=#808000]layout[/COLOR] [COLOR=#800080]colspan[/COLOR]=[COLOR=#ff00ff]"4"[/COLOR]/>[/COLOR] 830: [COLOR=#0000ff]<[COLOR=#808000]label[/COLOR]>[/COLOR]KG[COLOR=#0000ff]</[COLOR=#808000]label[/COLOR]>[/COLOR] 831: [COLOR=#0000ff]<[COLOR=#808000]address[/COLOR] [COLOR=#800080]transform[/COLOR]=[COLOR=#ff00ff]"DPT:1.019"[/COLOR] [COLOR=#800080]mode[/COLOR]=[COLOR=#ff00ff]"read"[/COLOR]>[/COLOR]0/3/20[COLOR=#0000ff]</[COLOR=#808000]address[/COLOR]>[/COLOR] [B]Notice[/B]: Undefined variable: return in [B]C:\xampp\htdocs\Material\t\src\check_config.php[/B] on line [B]46[/B] [B]Error 1871[/B]: Element 'popup': This element is not expected. on [URL="http://localhost/Material/t/src/check_config.php?config=#832"]line [B]833[/B][/URL] 830: [COLOR=#0000ff]<[COLOR=#808000]label[/COLOR]>[/COLOR]KG[COLOR=#0000ff]</[COLOR=#808000]label[/COLOR]>[/COLOR] 831: [COLOR=#0000ff]<[COLOR=#808000]address[/COLOR] [COLOR=#800080]transform[/COLOR]=[COLOR=#ff00ff]"DPT:1.019"[/COLOR] [COLOR=#800080]mode[/COLOR]=[COLOR=#ff00ff]"read"[/COLOR]>[/COLOR]0/3/20[COLOR=#0000ff]</[COLOR=#808000]address[/COLOR]>[/COLOR] 832: [COLOR=#0000ff]</[COLOR=#808000]info[/COLOR]>[/COLOR] [B] 833: [COLOR=#0000ff]<[COLOR=#808000]popup[/COLOR]>[/COLOR] [/B] 834: [COLOR=#0000ff]<[COLOR=#808000]layout[/COLOR] [COLOR=#800080]colspan[/COLOR]=[COLOR=#ff00ff]"4"[/COLOR]/>[/COLOR] 835: [COLOR=#0000ff]<[COLOR=#808000]popuptrigger[/COLOR]>[/COLOR] 836: [COLOR=#0000ff]<[COLOR=#808000]info[/COLOR] [COLOR=#800080]mapping[/COLOR]=[COLOR=#ff00ff]"DoorOpenClose"[/COLOR] [COLOR=#800080]bind_click_to_widget[/COLOR]=[COLOR=#ff00ff]"false"[/COLOR]>[/COLOR] [B]Notice[/B]: Undefined variable: return in [B]C:\xampp\htdocs\Material\t\src\check_config.php[/B] on line [B]46[/B] [B]Error 1866[/B]: Element 'info', attribute 'bind_click_to_widget': The attribute 'bind_click_to_widget' is not allowed. on [URL="http://localhost/Material/t/src/check_config.php?config=#1050"]line [B]1051[/B][/URL] 1048: [COLOR=#0000ff]</[COLOR=#808000]group[/COLOR]>[/COLOR] 1049: [COLOR=#0000ff]<[COLOR=#808000]group[/COLOR]>[/COLOR] 1050: [COLOR=#0000ff]<[COLOR=#808000]layout[/COLOR] [COLOR=#800080]colspan[/COLOR]=[COLOR=#ff00ff]"6"[/COLOR]/>[/COLOR] [B]1051: [COLOR=#0000ff]<[COLOR=#808000]info[/COLOR] [COLOR=#800080]mapping[/COLOR]=[COLOR=#ff00ff]"DoorOpenClose"[/COLOR] [COLOR=#800080]bind_click_to_widget[/COLOR]=[COLOR=#ff00ff]"false"[/COLOR]>[/COLOR] [/B]1052: [COLOR=#0000ff]<[COLOR=#808000]layout[/COLOR] [COLOR=#800080]colspan[/COLOR]=[COLOR=#ff00ff]"3"[/COLOR]/>[/COLOR] 1053: [COLOR=#0000ff]<[COLOR=#808000]label[/COLOR]>[/COLOR]Zentral[COLOR=#0000ff]</[COLOR=#808000]label[/COLOR]>[/COLOR] 1054: [COLOR=#0000ff]<[COLOR=#808000]address[/COLOR] [COLOR=#800080]transform[/COLOR]=[COLOR=#ff00ff]"DPT:1.019"[/COLOR] [COLOR=#800080]mode[/COLOR]=[COLOR=#ff00ff]"read"[/COLOR]>[/COLOR]0/3/0[COLOR=#0000ff]</[COLOR=#808000]address[/COLOR]>[/COLOR] [B]Notice[/B]: Undefined variable: return in [B]C:\xampp\htdocs\Material\t\src\check_config.php[/B] on line [B]46[/B] [B]Error 1866[/B]: Element 'info', attribute 'bind_click_to_widget': The attribute 'bind_click_to_widget' is not allowed. on [URL="http://localhost/Material/t/src/check_config.php?config=#1055"]line [B]1056[/B][/URL] 1053: [COLOR=#0000ff]<[COLOR=#808000]label[/COLOR]>[/COLOR]Zentral[COLOR=#0000ff]</[COLOR=#808000]label[/COLOR]>[/COLOR] 1054: [COLOR=#0000ff]<[COLOR=#808000]address[/COLOR] [COLOR=#800080]transform[/COLOR]=[COLOR=#ff00ff]"DPT:1.019"[/COLOR] [COLOR=#800080]mode[/COLOR]=[COLOR=#ff00ff]"read"[/COLOR]>[/COLOR]0/3/0[COLOR=#0000ff]</[COLOR=#808000]address[/COLOR]>[/COLOR] 1055: [COLOR=#0000ff]</[COLOR=#808000]info[/COLOR]>[/COLOR] [B]1056: [COLOR=#0000ff]<[COLOR=#808000]info[/COLOR] [COLOR=#800080]mapping[/COLOR]=[COLOR=#ff00ff]"DoorOpenClose"[/COLOR] [COLOR=#800080]bind_click_to_widget[/COLOR]=[COLOR=#ff00ff]"false"[/COLOR]>[/COLOR] [/B]1057: [COLOR=#0000ff]<[COLOR=#808000]layout[/COLOR] [COLOR=#800080]colspan[/COLOR]=[COLOR=#ff00ff]"3"[/COLOR]/>[/COLOR] 1058: [COLOR=#0000ff]<[COLOR=#808000]label[/COLOR]>[/COLOR]KG[COLOR=#0000ff]</[COLOR=#808000]label[/COLOR]>[/COLOR] 1059: [COLOR=#0000ff]<[COLOR=#808000]address[/COLOR] [COLOR=#800080]transform[/COLOR]=[COLOR=#ff00ff]"DPT:1.019"[/COLOR] [COLOR=#800080]mode[/COLOR]=[COLOR=#ff00ff]"read"[/COLOR]>[/COLOR]0/3/20[COLOR=#0000ff]</[COLOR=#808000]address[/COLOR]>[/COLOR] [B]Notice[/B]: Undefined variable: return in [B]C:\xampp\htdocs\Material\t\src\check_config.php[/B] on line [B]46[/B] [B]Error 1871[/B]: Element 'popup': This element is not expected. on [URL="http://localhost/Material/t/src/check_config.php?config=#1060"]line [B]1061[/B][/URL] 1058: [COLOR=#0000ff]<[COLOR=#808000]label[/COLOR]>[/COLOR]KG[COLOR=#0000ff]</[COLOR=#808000]label[/COLOR]>[/COLOR] 1059: [COLOR=#0000ff]<[COLOR=#808000]address[/COLOR] [COLOR=#800080]transform[/COLOR]=[COLOR=#ff00ff]"DPT:1.019"[/COLOR] [COLOR=#800080]mode[/COLOR]=[COLOR=#ff00ff]"read"[/COLOR]>[/COLOR]0/3/20[COLOR=#0000ff]</[COLOR=#808000]address[/COLOR]>[/COLOR] 1060: [COLOR=#0000ff]</[COLOR=#808000]info[/COLOR]>[/COLOR] [B]1061: [COLOR=#0000ff]<[COLOR=#808000]popup[/COLOR]>[/COLOR] [/B]1062: [COLOR=#0000ff]<[COLOR=#808000]layout[/COLOR] [COLOR=#800080]colspan[/COLOR]=[COLOR=#ff00ff]"3"[/COLOR]/>[/COLOR] 1063: [COLOR=#0000ff]<[COLOR=#808000]popuptrigger[/COLOR]>[/COLOR] 1064: [COLOR=#0000ff]<[COLOR=#808000]info[/COLOR] [COLOR=#800080]mapping[/COLOR]=[COLOR=#ff00ff]"DoorOpenClose"[/COLOR] [COLOR=#800080]bind_click_to_widget[/COLOR]=[COLOR=#ff00ff]"false"[/COLOR]>[/COLOR]
