sendmail with multiple lines
    I am trying to send a textual mail with multiple lines from my EibPC using sendmail().
    I've been looking around in the manual and tried to experiment with CR, but failed to make it work.
    Could someone provide a short example?
    Thanks and best regards, Sammy
    We have this as an feature on the list for Q4/2010.
    A workaround would be
    - if you want to read mails with the iPhone you can insert spaces and see, at which position the linebreak is done
    Enertex Produkte kaufen
      I wanted to use this to send an e-mail towards an SMS gateway.
      This gateway expects a certain format - so you workaround will not be applicable here.
      I am surprised to read that the sendmail() function is only able to send a one-liner :-(.
      Will look for another solution and use my Wiregate for this function for now.
      Best regards, Sammy
        I've already found this sendmail() behaviour some time ago...
          I've already found this sendmail() behaviour some time ago... => Wait for next but one release.
