GoogleWetter keine Abfrage
    Warum funktioniert bei mir das Google Wetter Makro aus der Enertex.lib nicht?
    Habe jetzt schon so viele Adressen probiert, auch jetzt die aus dem Enertexbeispiel!
    Es kommen keine Daten an!! Wenn ich im Debugger die Variablen Google_Zuhause_Wind oder Google_Zuhause_Wolken oder welche auch immer logge, kommt einfach kein WERT!
    GoogleWetter(Zuhause,91301,Germany,"Google Wetter-8/0/50")
    Die GA ist vom Typ b01!!!
    % Wert von Objekt 9166 (Google_Zuhause_Temperatur) abfragen:
    % C:/Users/Martin/Desktop/Eib-Pc NEU/EibstudioData/nconf -q 9166 10.0.0.29
    % Wert von Objekt 9166: 00 00 00 00 {2012-08-28 21:02:13}
    % Wert von Objekt 9167 (Google_Zuhause_VorhersageMax) abfragen:
    % C:/Users/Martin/Desktop/Eib-Pc NEU/EibstudioData/nconf -q 9167 10.0.0.29
    % Wert von Objekt 9167: 00 00 00 00 {2012-08-28 21:02:14}
    % Wert von Objekt 1015 (Google_Zuhause_Wolken) abfragen:
    % C:/Users/Martin/Desktop/Eib-Pc NEU/EibstudioData/nconf -q 1015 10.0.0.29
    % Wert von Objekt 1015: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 {2012-08-28 21:02:14}
    % Typ: erweiterter Text
    % Wert:
    MfG MrKnx
    Zitat von MrKNX Beitrag anzeigen
    Warum funktioniert bei mir das Google Wetter Makro aus der Enertes.lib nicht?
    Geht bei noir aktuell auch nicht, manchmal ist der google-Server nicht erreichbar oder wird umgestellt. Ich würde mal abwarten.
    Enertex Produkte kaufen
      @Micha kann es vielleicht damit zusammen hängen? https://knx-user-forum.de/cometvisu/...r-ist-tot.html
        Danke für die Rückmeldung!
        OK, dann muss ich mal warten! Versuche es schon seit Freitag hinzubekommen!
        MfG MrKnx
          Hört sich nicht sehr vielversprechend an!
          MfG MrKnx
            Gibt's Alternativen ?
              Hoi
              Ja Wunderground
              Aber die verlangen wohl aktuell eine Anmeldung und dann muss man den Api-Code verwenden.
              Bisher ging mein Link auch noch ohne ...
              http://api.wunderground.com/weatherstation/WXCurrentObXML.asp?ID=IZURICHC2
              Grüsse Bodo
                wetter.com liefert eigentlich eine sehr gute Datenqualität, aber die Einbindung der API erscheint mir relativ aufwendig.
                Vor allem muß für die XML API Abfrage ein md5-Hash berechnet aus Projektname, API Key und Suchstring mitgeliefert werden. Diese Berechnung im EibPC umzusetzen ist vermutlich aufwendig.
                Wenn jemand die md5-Berechnnung lösen kann, würde ich das Makro schreiben.
                  Also ich habe da auch im Moment Probleme mit meine Google-Wetter Webabfrage. Wenn ich die URL aufrufe kommt folgende meldung:
                  We're sorry...
                  ... but your computer or network may be sending automated queries. To protect our users, we can't process your request right now.
                  See Google Help for more information.
                  Ich denke mal durch die regelmäßige Abfrage haben die einfach die Rechner gesperrt, die immer wieder darauf zugreifen.
                  Gruß Andree Czybulski
                    http://status-dashboard.com/32226/47728?zone=EUROPE
                    wurde eher komplett abgeschaltet
                    greetz Benni
                      We're sorry...
                      Solche Meldungen gibt Google bei Benutzung eines Proxys öfter mal raus. Für Enduser macht das Sperren einzelner IPs auch keinen Sinn, da die normalerweise eh dynamisch sind.
                      Firma: Enertex Bayern GmbH, Ebermannstädter Straße 8, 91301 Forchheim
                      Amazon: KNXnet/IP Router
                      , KNXnet/IP Interface
                        Google Weather API disconnected
                        Google Weather API: Never Supported, Finally Disconnected
                          zurück aus dem Urlaub musste ich ebenfalls feststellen, dass die Schattenautomatik nicht funktionierte, da Google Weather tot ist.
                          Wunderground scheint ja brauchbare Daten zu liefern. Hat jemand evtl. schon das Makro so angepasst, dass man auch mit wunderground die Schattenautomatik steuern kann, oder eine andere kurze Anleitung wie an auf wunderground umstellt. Ich weiss mit einer Wetterstation wäre es genauer, aber dennoch. (wenn KNX RF da ist, dann kommt evtl. eine Wetterstation die mit Funk anzubinden ist in Frage :-)) )
                          Vielen dank im Voraus
                          Ralf
                            Wir sind da am evaluieren, am besten bräuchte man einen XML Dienst. Und zwar einen, der nicht auf absehbare zeit kostenpflichtig wird...
                              Hoi
                              Die Norweger bieten auch eine Unzahl von xml's an.
                              Information about the free weather data service - yr.no
                              Weather forecast for Forchheim, Bavaria (Germany)
                              <link id="xmlSource" url="http://www.yr.no/place/Germany/Bavaria/Forchheim~2925910/forecast.xml"/>
                              <link id="xmlSourceHourByHour" url="http://www.yr.no/place/Germany/Bavaria/Forchheim~2925910/forecast_hour_by_hour.xml"/>
                              <link id="overview" url="http://www.yr.no/place/Germany/Bavaria/Forchheim~2925910/"/>
                              <link id="hourByHour" url="http://www.yr.no/place/Germany/Bavaria/Forchheim~2925910/hour_by_hour"/>
                              <link id="longTermForecast" url="http://www.yr.no/place/Germany/Bavaria/Forchheim~2925910/long"/>
                              Grüsse Bodo
