Zitat von Dark1ce
SynOhr FW 1.084
Please write in English. The autotranslate does not work.offizielles Supportforum für den Enertex® EibPC: https://knx-user-forum.de/eibpc/
Enertex Produkte kaufen
My multisense not see flash card and not load. Where can I get standard files from a flash drive?Zitat von enertegus Beitrag anzeigenPlease write in English. The autotranslate does not work.
not load
My multisense not see flash card and not load. Where can I get standard files from a flash drive?Zitat von SteffiEnertex Beitrag anzeigenMein Leben.... *schnauf*
Da ging tatsächlich was beim Zippen/Hochladen,... schief.
Update kommt sofort,... ist da.
Jetzt aber auf zu den letzten Messevorbereitungen,...
You need SynOhrStudio http://www.enertex.de/downloads/syno...Studio-win.zip and the Languagefiles (Sprachschatz). For now only German is available (http://www.enertex.de/downloads/syno...hSchatz-DE.zip) but we are working on English and French.Zitat von Dark1ce Beitrag anzeigenMy multisense not see flash card and not load. Where can I get standard files from a flash drive?offizielles Supportforum für den Enertex® EibPC: https://knx-user-forum.de/eibpc/
What can I do with this error? http://4.firepic.org/4/images/2014-1...2lt7rmyf1z.jpgZitat von enertegus Beitrag anzeigenYou need SynOhrStudio http://www.enertex.de/downloads/syno...Studio-win.zip and the Languagefiles (Sprachschatz). For now only German is available (http://www.enertex.de/downloads/syno...hSchatz-DE.zip) but we are working on English and French.
Please make sure, you have configured an output path in SynOhrStudio for your files, where you have the full access rights. Best would be on your home-directory or desktop.Zitat von Dark1ce Beitrag anzeigenWhat can I do with this error? http://4.firepic.org/4/images/2014-1...2lt7rmyf1z.jpgoffizielles Supportforum für den Enertex® EibPC: https://knx-user-forum.de/eibpc/
I have configured all pathes and I have full access, but error still remains.Zitat von enertegus Beitrag anzeigenPlease make sure, you have configured an output path in SynOhrStudio for your files, where you have the full access rights. Best would be on your home-directory or desktop.
Can You send me all standart files from flash drive?Zitat von enertegus Beitrag anzeigenPlease make sure, you have configured an output path in SynOhrStudio for your files, where you have the full access rights. Best would be on your home-directory or desktop.
We can (send a mail to synohr@enertex.de), but without SynOhrStudio running, no customizing is possible. Please also send "synohrstudio.set" to the support mail.Zitat von Dark1ce Beitrag anzeigenI have configured all pathes and I have full access, but error still remains.offizielles Supportforum für den Enertex® EibPC: https://knx-user-forum.de/eibpc/
I sent mail.Zitat von enertegus Beitrag anzeigenWe can (send a mail to synohr@enertex.de), but without SynOhrStudio running, no customizing is possible. Please also send "synohrstudio.set" to the support mail.
Thank you. SynOhrStudio does not show an error. But MultiSense write "PROGRAMM BEENDET!"Zitat von enertegus Beitrag anzeigenWe can (send a mail to synohr@enertex.de), but without SynOhrStudio running, no customizing is possible. Please also send "synohrstudio.set" to the support mail.
Look at your mail and please contact the given number. You now have to load the files to your sd card and restart SynOhr.Zitat von Dark1ce Beitrag anzeigenThank you. SynOhrStudio does not show an error. But MultiSense write "PROGRAMM BEENDET!"offizielles Supportforum für den Enertex® EibPC: https://knx-user-forum.de/eibpc/
Please, send me standart folders(.fseventsd, .spotlight-V100 andZitat von enertegus Beitrag anzeigenLook at your mail and please contact the given number. You now have to load the files to your sd card and restart SynOhr.
other) and files from flash drive(all of them).
Leg mal die DLL von Klaus Gütter aus diesem Thread in das Verzeichnis mit dem Update Tool:
https://knx-user-forum.de/eibpc/3012...1-030-a-3.html
Dann sollte es funktionieren.Gruß
Volker
Wer will schon Homematic?
