JSON Dateien in ein Item schreiben
    ich habe ein Sensor zusammengelötet der Json Daten bereitstellt diese möchte ich in ein item Schreiben und es auf der Sitemap darstellen. Ich habe ein Item erstellt dieses holt von dem Gerät die Daten ab im Logfile sehe ich das...
    2018-01-28 19:37:10.744 [vent.ItemStateChangedEvent] - Wohnzimmersensor_Data changed from {"modultyp":"wiffi-wz","vars":[{"name":"0","homematic_name":"wz_ip","desc":"ip des wiffi-wz","type":"string","unit":"","value":"192.168.178.74"},{"name":"1","homematic_name":"wz_co2","desc":"Luftqualitaet","type":"number","unit":"%","value":76},{"name":"2","homematic_name":"wz_temp","desc":"Temperatur","type":"number","unit":"gradC","value":22.7},{"name":"3","homematic_name":"wz_feuchte","desc":"Luftfeuchte","type":"number","unit":"%","value":45.5},{"name":"19","homematic_name":"wz_taupunkt","desc":"Taupunkt","type":"number","unit":"gradC","value":10.3},{"name":"18","homematic_name":"wz_feuchte_abs","desc":"Absolutfeuchte","type":"number","unit":"g/m3","value":9.2},{"name":"9","homematic_name":"wz_baro","desc":"Luftdruck","type":"number","unit":"mB","value":1037.07},{"name":"5","homematic_name":"wz_luftdrucktrend","desc":"Luftdrucktrend","type":"string","unit":"","value":"steigend"},{"name":"8","homematic_name":"wz_lux","desc":"Helligkeit","type":"number","unit":"lux","value":0.00},{"name":"10","homematic_name":"wz_elevation","desc":"Sonne-Elevation","type":"number","unit":"grad","value":-22.4},{"name":"11","homematic_name":"wz_azimut","desc":"Sonne-Azimut","type":"number","unit":"grad","value":267.6},{"name":"12","homematic_name":"wz_buzzer","desc":"Buzzer","type":"boolean","unit":"","value":false},{"name":"21","homematic_name":"wz_relais","desc":"Relais","type":"boolean","unit":"","value":false}],{"name":"10","homematic_name":"wz_elevation","desc":"Sonne-Elevation","type":"number","unit":"grad","value":-22.4},{"name":"11","homematic_name":"wz_azimut","desc":"Sonne-Azimut","type":"number","unit":"grad","value":267.6},{"name":"12","homematic_name":"wz_buzzer","desc":"Buzzer","type":"boolean","unit":"","value":false},{"name":"21","homematic_name":"wz_relais","desc":"Relais","type":"boolean","unit":"","value":false}],"Systeminfo":{"MAC-Adresse":"81:7b:f8:34:fe:18","ip_Homematic_CCU":"192.168.178.73","WLAN_ssid":"T-Virus","WLAN_Signal_dBm":-57,"millis_seit_reset":26033346,"wiffizeit":" 1 19:36","firmware":"wiffi_wz_91"}} to {"modultyp":"wiffi-wz","vars":[{"name":"0","homematic_name":"wz_ip","desc":"ip des wiffi-wz","type":"string","unit":"","value":"192.168.178.74"},{"name":"1","homematic_name":"wz_co2","desc":"Luftqualitaet","type":"number","unit":"%","value":76},{"name":"2","homematic_name":"wz_temp","desc":"Temperatur","type":"number","unit":"gradC","value":22.7},{"name":"3","homematic_name":"wz_feuchte","desc":"Luftfeuchte","type":"number","unit":"%","value":47.7},{"name":"19","homematic_name":"wz_taupunkt","desc":"Taupunkt","type":"number","unit":"gradC","value":11.0},{"name":"18","homematic_name":"wz_feuchte_abs","desc":"Absolutfeuchte","type":"number","unit":"g/m3","value":9.6},{"name":"9","homematic_name":"wz_baro","desc":"Luftdruck","type":"number","unit":"mB","value":1037.10},{"name":"5","homematic_name":"wz_luftdrucktrend","desc":"Luftdrucktrend","type":"string","unit":"","value":"stabil"},{"name":"8","homematic_name":"wz_lux","desc":"Helligkeit","type":"number","unit":"lux","value":0.00},{"name":"10","homematic_name":"wz_elevation","desc":"Sonne-Elevation","type":"number","unit":"grad","value":-22.6},{"name":"11","homematic_name":"wz_azimut","desc":"Sonne-Azimut","type":"number","unit":"grad","value":267.8},{"name":"12","homematic_name":"wz_buzzer","desc":"Buzzer","type":"boolean","unit":"","value":false},{"name":"21","homematic_name":"wz_relais","desc":"Relais","type":"boolean","unit":"","value":false}],{"name":"10","homematic_name":"wz_elevation","desc":"Sonne-Elevation","type":"number","unit":"grad","value":-22.6},{"name":"11","homematic_name":"wz_azimut","desc":"Sonne-Azimut","type":"number","unit":"grad","value":267.8},{"name":"12","homematic_name":"wz_buzzer","desc":"Buzzer","type":"boolean","unit":"","value":false},{"name":"21","homematic_name":"wz_relais","desc":"Relais","type":"boolean","unit":"","value":false}],"Systeminfo":{"MAC-Adresse":"81:7b:f8:34:fe:18","ip_Homematic_CCU":"192.168.178.73","WLAN_ssid":"T-Virus","WLAN_Signal_dBm":-60,"millis_seit_reset":26094792,"wiffizeit":" 1 19:37","firmware":"wiffi_wz_91"}}
    das Item
    String Wohnzimmersensor_Data "Wohnzimmersensor Data" {http="<[http://192.168.178.74/?json:60000:REGEX((.*))]"}
    aber alle Versuche es in ein Item zu bekommen scheitern ich habe es mit einer Rule versucht.
    rule "Wohnzimmersensor Itemupdate"
    when
        Time cron "0 0/1 * * * ?"
    then
        var String data = Wohnzimmersensor_Data.state.toString
        var String value = transform ("JSONPATH", "$.vars[2].value", data)
    postUpdate (Wz_temp, value)
    end
    Diese Rule soll mit die Wohnzimmer Temperatur in ein Item schreiben. Funktioniert nicht kann mir jemand dieses Json erklären ich versteh es noch nicht was ein Jsonpath ist.
    Gruss Michael
    Gibt es einen Grund, warum Du die Daten über eine Rule lädst, statt sie direkt in ein Item zu schreiben?
    Nach dem Log ist der json String syntaktisch inkorrekt (eine schließende eckige Klammer ] mittendrin zu viel).
      Ich bin gerade am Versuchen direkt in ein Item zu schreiben muss aber erst verstehen was ich da schreiben muss.
        Statt REGEX schreibst Du halt JSONPATH und in die Klammern kommt der JSON-Ausdruck. Hast Du mal wegen des Fehlers in der Datei geschaut? die kommt ja im Zweifel aus dem Sensor.
          Ich Blick damit ganz ehrlich überhaupt nicht durch obwohl ich versuche die Doku zu übersetzten und zu lesen.
            Also, der String für die Abfrage sähe so aus:
            String Wohnzimmersensor_Data "Wohnzimmersensor Data" {http="<[http://192.168.178.74/?json:60000:JSONPATH($.vars[2].value)]"}
            Aber das funktioniert nur, wenn ein gültiges JSON geliefert wird.
            Hier mal die von Dir geposteten Daten als JSON formatiert:
            Alter Inhalt des Items:
                "modultyp": "wiffi-wz",
                "vars": [{
                    "name": "0",
                    "homematic_name": "wz_ip",
                    "desc": "ip des wiffi-wz",
                    "type": "string",
                    "unit": "",
                    "value": "192.168.178.74"
                    "name": "1",
                    "homematic_name": "wz_co2",
                    "desc": "Luftqualitaet",
                    "type": "number",
                    "unit": "%",
                    "value": 76
                    "name": "2",
                    "homematic_name": "wz_temp",
                    "desc": "Temperatur",
                    "type": "number",
                    "unit": "gradC",
                    "value": 22.7
                    "name": "3",
                    "homematic_name": "wz_feuchte",
                    "desc": "Luftfeuchte",
                    "type": "number",
                    "unit": "%",
                    "value": 45.5
                    "name": "19",
                    "homematic_name": "wz_taupunkt",
                    "desc": "Taupunkt",
                    "type": "number",
                    "unit": "gradC",
                    "value": 10.3
                    "name": "18",
                    "homematic_name": "wz_feuchte_abs",
                    "desc": "Absolutfeuchte",
                    "type": "number",
                    "unit": "g/m3",
                    "value": 9.2
                    "name": "9",
                    "homematic_name": "wz_baro",
                    "desc": "Luftdruck",
                    "type": "number",
                    "unit": "mB",
                    "value": 1037.07
                    "name": "5",
                    "homematic_name": "wz_luftdrucktrend",
                    "desc": "Luftdrucktrend",
                    "type": "string",
                    "unit": "",
                    "value": "steigend"
                    "name": "8",
                    "homematic_name": "wz_lux",
                    "desc": "Helligkeit",
                    "type": "number",
                    "unit": "lux",
                    "value": 0.00
                    "name": "10",
                    "homematic_name": "wz_elevation",
                    "desc": "Sonne-Elevation",
                    "type": "number",
                    "unit": "grad",
                    "value": -22.4
                    "name": "11",
                    "homematic_name": "wz_azimut",
                    "desc": "Sonne-Azimut",
                    "type": "number",
                    "unit": "grad",
                    "value": 267.6
                    "name": "12",
                    "homematic_name": "wz_buzzer",
                    "desc": "Buzzer",
                    "type": "boolean",
                    "unit": "",
                    "value": false
                    "name": "21",
                    "homematic_name": "wz_relais",
                    "desc": "Relais",
                    "type": "boolean",
                    "unit": "",
                    "value": false
                }[COLOR=#FF0000]][/COLOR][COLOR=#FF8C00],
                    "name": "10",
                    "type": "number",
                    "unit": "grad",
                    "value": -22.4
                    "name": "11",
                    "type": "number",
                    "unit": "grad",
                    "value": 267.6
                    "name": "12",
                    "desc": "Buzzer",
                    "type": "boolean",
                    "unit": "",
                    "value": false
                    "name": "21",
                    "desc": "Relais",
                    "type": "boolean",
                    "unit": "",
                    "value": false
                }[/COLOR]],
                "Systeminfo": {
                    "MAC-Adresse": "81:7b:f8:34:fe:18",
                    "ip_Homematic_CCU": "192.168.178.73",
                    "WLAN_ssid": "T-Virus",
                    "WLAN_Signal_dBm": -57,
                    "millis_seit_reset": 26033346,
                    "wiffizeit": " 1 19:36",
                    "firmware": "wiffi_wz_91"
            Neuer Inhalt des Items:
                "vars": [{
                    "name": "0",
                    "type": "string",
                    "unit": "",
                    "name": "1",
                    "type": "number",
                    "unit": "%",
                    "value": 76
                    "name": "2",
                    "type": "number",
                    "unit": "gradC",
                    "value": 22.7
                    "name": "3",
                    "type": "number",
                    "unit": "%",
                    "value": 47.7
                    "name": "19",
                    "desc": "Taupunkt",
                    "type": "number",
                    "unit": "gradC",
                    "value": 11.0
                    "name": "18",
                    "type": "number",
                    "unit": "g/m3",
                    "value": 9.6
                    "name": "9",
                    "type": "number",
                    "unit": "mB",
                    "value": 1037.10
                    "name": "5",
                    "type": "string",
                    "unit": "",
                    "value": "stabil"
                    "name": "8",
                    "type": "number",
                    "unit": "lux",
                    "value": 0.00
                    "name": "10",
                    "type": "number",
                    "unit": "grad",
                    "value": -22.6
                    "name": "11",
                    "type": "number",
                    "unit": "grad",
                    "value": 267.8
                    "name": "12",
                    "desc": "Buzzer",
                    "type": "boolean",
                    "unit": "",
                    "value": false
                    "name": "21",
                    "desc": "Relais",
                    "type": "boolean",
                    "unit": "",
                    "value": false
                    "name": "10",
                    "type": "number",
                    "unit": "grad",
                    "value": -22.6
                    "name": "11",
                    "type": "number",
                    "unit": "grad",
                    "value": 267.8
                    "name": "12",
                    "desc": "Buzzer",
                    "type": "boolean",
                    "unit": "",
                    "value": false
                    "name": "21",
                    "desc": "Relais",
                    "type": "boolean",
                    "unit": "",
                    "value": false
                }[/COLOR]],
                "Systeminfo": {
                    "WLAN_Signal_dBm": -60,
                    "millis_seit_reset": 26094792,
                    "wiffizeit": " 1 19:37",
            Der rote Teil muss weg, damit ein gültiges JSON entsteht, der orange Teil ist doppelt (die letzten vier Werte), vielleicht ist im Code ein Bug, der für diese Wiederholung sorgt - und damit für ein ungültiges JSON.
              Ach so... Falls Du mehrere (alle?) Werte aus dem JSON auslesen möchtest, bietet es sich an, ein http Cache dafür einzurichten. Das heißt, der Cache wird in regelmäßigen Abständen aktualisiert, die Items werden jeweils aus dem Cache gefüllt. So gibt es dann weniger Anfragen an das Gerät, trotzdem stehen alle werte in separaten Items zur Verfügung.
                Ja ich möchte alle Werte auslesen aber was ist den ein http-Cache wie mache ich das. Ich versuch heute Abend das umzusetzen.
                  Schau mal hier: https://docs.openhab.org/addons/bind...-configuration
                    Ich glaube dass sas Gerät ein Falsches JSON liefert wenn ich auf dem Gerät mit die JSON Daten anzeigen lasse kommt das raus
                     {"modultyp":"wiffi-wz","vars":[{"name":"0","homematic_name":"wz_ip","desc":"ip des wiffi-wz","type":"string","unit":"","value":"192.168.178.74"}, {"name":"1","homematic_name":"wz_co2","desc":"Luftqualitaet","type":"number","unit":"%","value":90}, {"name":"2","homematic_name":"wz_temp","desc":"Temperatur","type":"number","unit":"gradC","value":25.4}, {"name":"3","homematic_name":"wz_feuchte","desc":"Luftfeuchte","type":"number","unit":"%","value":37.9}, {"name":"19","homematic_name":"wz_taupunkt","desc":"Taupunkt","type":"number","unit":"gradC","value":10.0}, {"name":"18","homematic_name":"wz_feuchte_abs","desc":"Absolutfeuchte","type":"number","unit":"g/m3","value":8.9}, {"name":"9","homematic_name":"wz_baro","desc":"Luftdruck","type":"number","unit":"mB","value":1028.14}, {"name":"5","homematic_name":"wz_luftdrucktrend","desc":"Luftdrucktrend","type":"string","unit":"","value":"fallend"}, {"name":"8","homematic_name":"wz_lux","desc":"Helligkeit","type":"number","unit":"lux","value":7.13}, {"name":"10","homematic_name":"wz_elevation","desc":"Sonne-Elevation","type":"number","unit":"grad","value":-9.1}, {"name":"11","homematic_name":"wz_azimut","desc":"Sonne-Azimut","type":"number","unit":"grad","value":252.4}, {"name":"12","homematic_name":"wz_buzzer","desc":"Buzzer","type":"boolean","unit":"","value":false}, {"name":"21","homematic_name":"wz_relais","desc":"Relais","type":"boolean","unit":"","value":false}], {"name":"10","homematic_name":"wz_elevation","desc":"Sonne-Elevation","type":"number","unit":"grad","value":-9.1}, {"name":"11","homematic_name":"wz_azimut","desc":"Sonne-Azimut","type":"number","unit":"grad","value":252.4}, {"name":"12","homematic_name":"wz_buzzer","desc":"Buzzer","type":"boolean","unit":"","value":false}, {"name":"21","homematic_name":"wz_relais","desc":"Relais","type":"boolean","unit":"","value":false}], "Systeminfo":{"MAC-Adresse":"81:7b:f8:34:fe:18","ip_Homematic_CCU":"192.168.178.73","WLAN_ssid":"T-Virus", "WLAN_Signal_dBm":-53,"millis_seit_reset":83876326,"wiffizeit":" 3 18:13","firmware":"wiffi_wz_91"}}
                    da sind wieder 4 Werte Doppelt.
                      Das ist ungünstig. Mal ins Blaue geraten (und weil ich da homematic lese), vielleicht gibt es eine korrigierte Firmware von ELV? Ansonsten würde ich da mal nachfragen, denn das Teil soll ja korrektes JSON liefern. Für Notepad++ gibt es ein Plugin, das mault und zeigt gar nichts an (es sei denn, man entfernt die eckige Klammer)
                        Jetzt sieht der JSON Ausdruck so aus
                            "vars": [{
                                "name": "0",
                                "type": "string",
                                "unit": "",
                                "name": "1",
                                "type": "number",
                                "unit": "%",
                                "value": 95
                                "name": "2",
                                "type": "number",
                                "unit": "gradC",
                                "value": 25.6
                                "name": "3",
                                "type": "number",
                                "unit": "%",
                                "value": 39.9
                                "name": "19",
                                "desc": "Taupunkt",
                                "type": "number",
                                "unit": "gradC",
                                "value": 11.0
                                "name": "18",
                                "type": "number",
                                "unit": "g/m3",
                                "value": 9.5
                                "name": "9",
                                "type": "number",
                                "unit": "mB",
                                "value": 1007.69
                                "name": "5",
                                "type": "string",
                                "unit": "",
                                "value": "not valid"
                                "name": "8",
                                "type": "number",
                                "unit": "lux",
                                "value": 4.42
                                "name": "6",
                                "homematic_name": "wz_motion_left",
                                "desc": "Bewegung links",
                                "type": "boolean",
                                "unit": "",
                                "value": false
                                "name": "7",
                                "homematic_name": "wz_motion_right",
                                "desc": "Bewegung rechts",
                                "type": "boolean",
                                "unit": "",
                                "value": false
                                "name": "20",
                                "homematic_name": "wz_motion",
                                "desc": "Bewegung",
                                "type": "boolean",
                                "unit": "",
                                "value": false
                                "name": "4",
                                "homematic_name": "wz_noise",
                                "desc": "Geraeusch",
                                "type": "boolean",
                                "unit": "",
                                "value": false
                                "name": "10",
                                "type": "number",
                                "unit": "grad",
                                "value": -7.0
                                "name": "11",
                                "type": "number",
                                "unit": "grad",
                                "value": 250.3
                                "name": "12",
                                "desc": "Buzzer",
                                "type": "boolean",
                                "unit": "",
                                "value": false
                                "name": "21",
                                "desc": "Relais",
                                "type": "boolean",
                                "unit": "",
                                "value": false
                            "Systeminfo": {
                                "WLAN_Signal_dBm": -55,
                                "millis_seit_reset": 410296,
                                "wiffizeit": " 4 18:01",
                                "firmware": "wiffi_wz_86"
                        Der ist doch jetzt OK?
                          Es hat geklappt mit dem Item
                          String Wohnzimmersensor_Data "Wohnzimmersensor Data" {http="<[http://192.168.178.74/?json:60000:JSONPATH((.*))]"}
                          und dann mit den Rules die Items mit Daten füllen.
                          when
                          then
                          postUpdate (Wz_temp_Test, value)
                          value = transform ("JSONPATH", "$.vars[1].value", data)
                          postUpdate (Wz_co2_Test, value)
                          usw.
                          end
                            Wie hast Du es hinbekommen, dass der Sender gültiges JSON ausgibt?
                            Wenn Du in der http.cfg folgendes einträgst:
                            wohnzimmersensor.url=http://192.168.178.74/?json
                            wohnzimmersensor.updateInterval=60000
                            kannst Du auf die Rule verzichten und stattdessen nur die Items anlegen:
                            Number Wz_temp_Test "Temperatur [%.1f °C]" {http="<[wohnzimmersensor:60000:JSONPATH($.vars[2].value)]"}
                            Number Wz_co2_Test "CO2 [%.1f ppm]" {http="<[wohnzimmersensor:60000:JSONPATH($.vars[1].value)]"}
                            Zuletzt geändert von udo1toni; 06.02.2018, 09:58.
                              Ich habe die Firmware geändert jetzt klappt es mit JSOn nur wenn ich es in die http.cfg Eintrage kommen fehler im Log kann es sein das noch was fehlt
                               wohnzimmersensor.url= http="<[http://192.168.178.74/?json
