Hmm,
ich habe die Kommandos natürlich brav unter start.bat ausgeführt, jedoch dann zum loggen die start_debug.bat genommen. ;-)
Also nochmal von vorne und im log stand nun
Die Zeile in der cfg war
Ist nun
Mal sehen, was passiert.
21:37:58.807 DEBUG o.o.i.d.i.DropboxActivator[:50]- Dropbox IO Bundle has been started. 21:37:58.822 ERROR OSGi[:98]- CronExpression ''0 0/5 * * * ?'' is invalid,. java.lang.RuntimeException: CronExpression ''0 0/5 * * * ?'' is invalid,. at org.quartz.CronScheduleBuilder.cronSchedule(CronScheduleBuilder.java:105) at org.openhab.io.dropbox.internal.DropboxSynchronizerImpl.schedule(DropboxSynchronizerImpl.java:706) at org.openhab.io.dropbox.internal.DropboxSynchronizerImpl.scheduleJobs(DropboxSynchronizerImpl.java:677) at org.openhab.io.dropbox.internal.DropboxSynchronizerImpl.activate(DropboxSynchronizerImpl.java:173) at org.openhab.io.dropbox.internal.DropboxSynchronizerImpl.updated(DropboxSynchronizerImpl.java:799) at org.eclipse.equinox.internal.cm.ManagedServiceTracker$1.run(ManagedServiceTracker.java:183) at org.eclipse.equinox.internal.cm.SerializedTaskQueue$1.run(SerializedTaskQueue.java:36) Caused by: java.text.ParseException: Unexpected character: ' at org.quartz.CronExpression.storeExpressionVals(CronExpression.java:685) at org.quartz.CronExpression.buildExpression(CronExpression.java:463) at org.quartz.CronExpression.<init>(CronExpression.java:276) at org.quartz.CronScheduleBuilder.cronSchedule(CronScheduleBuilder.java:102) ... 6 common frames omitted
[SIZE=2][LEFT]dropbox:uploadInterval='0 0/5 * * * ?'[/LEFT] [/SIZE]
[SIZE=2][LEFT]#dropbox:uploadInterval='0 0/5 * * * ?'[/LEFT] [/SIZE]
