Hat jemand das Binding schon mit Schaltaktoren (dimmern) getestet? Weil ich lese hier nur was von Temperatur- und Feuchtigkeitssensoren.
Marco
Marco
2014-08-14 19:24:35.226 DEBUG o.o.b.a.i.AleonceanBinding[:121]- Parse config: port; /dev/ttyUSB0 2014-08-14 19:24:35.228 DEBUG o.o.b.a.i.AleonceanBinding[:121]- Parse config: service.pid; org.openhab.aleoncean 2014-08-14 19:24:35.240 DEBUG o.o.b.a.internal.worker.Worker[:157]- Received ESP3 port: /dev/ttyUSB0 2014-08-14 19:24:35.243 DEBUG o.o.b.a.internal.worker.Worker[:235]- Do a disconnect... 2014-08-14 19:24:35.246 DEBUG o.o.b.a.internal.worker.Worker[:237]- Disconnect returned. 2014-08-14 19:24:35.248 DEBUG o.o.b.a.internal.worker.Worker[:239]- Wait for reader thread... 2014-08-14 19:24:35.258 DEBUG o.o.b.a.internal.worker.Worker[:241]- Wait for reader thread returned.
2014-10-06 20:41:26.601 WARN eu.aleon.aleoncean.rxtx.USB300[:67]- Port (/dev/ttyUSB0) not found.
gnu.io.NoSuchPortException: null
at gnu.io.CommPortIdentifier.getPortIdentifier(CommPortIdentifier.java:273)
at eu.aleon.aleoncean.rxtx.USB300.connect(USB300.java:65)
at org.openhab.binding.aleoncean.internal.worker.Worker.startESP3(Worker.java:223)
at org.openhab.binding.aleoncean.internal.worker.Worker.handleWorkerItemESP3Port(Worker.java:160)
at org.openhab.binding.aleoncean.internal.worker.Worker.run(Worker.java:116)
at java.lang.Thread.run(Thread.java:744)
################################# Aleoncean Binding ##################################### # # Aleoncean USB adapter serial port aleoncean:port=/dev/ttyUSB0
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 003 Device 004: ID 0764:0501 Cyber Power System, Inc. CP1500 AVR UPS Bus 003 Device 003: ID 04fa:2490 Dallas Semiconductor DS1490F 2-in-1 Fob, 1-Wire adapter Bus 004 Device 004: ID 147b:5120 Bus 004 Device 006: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 8
idVendor 0x0403 Future Technology Devices International, Ltd
idProduct 0x6001 FT232 USB-Serial (UART) IC
bcdDevice 6.00
iManufacturer 1 EnOcean GmbH
iProduct 2 EnOcean USB 300 DA
iSerial 3 FTWFMOEL
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 32
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xa0
(Bus Powered)
Remote Wakeup
MaxPower 90mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 255 Vendor Specific Class
bInterfaceSubClass 255 Vendor Specific Subclass
bInterfaceProtocol 255 Vendor Specific Protocol
iInterface 2 EnOcean USB 300 DA
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Device Status: 0x0000
(Bus Powered)
