Habe nun mal alles installiert und erhalte folgenden Fehler:
2015-03-10 19:54:08.105 [ERROR] [.i.c.internal.CalDavLoaderImpl] - error while loading calendar entries: Error at line 11:Cannot set timezone for UTC properties
net.fortuna.ical4j.data.ParserException: Error at line 11:Cannot set timezone for UTC properties
at net.fortuna.ical4j.data.CalendarParserImpl.parse(CalendarParserImpl.java:143) ~[na:na]
at net.fortuna.ical4j.data.CalendarBuilder.build(CalendarBuilder.java:213) ~[na:na]
at net.fortuna.ical4j.data.CalendarBuilder.build(CalendarBuilder.java:194) ~[na:na]
at net.fortuna.ical4j.data.CalendarBuilder.build(CalendarBuilder.java:182) ~[na:na]
at org.openhab.io.caldav.internal.CalDavLoaderImpl.loadEvents(CalDavLoaderImpl.java:301) ~[na:na]
at org.openhab.io.caldav.internal.CalDavLoaderImpl.access$5(CalDavLoaderImpl.java:251) ~[na:na]
at org.openhab.io.caldav.internal.CalDavLoaderImpl$4$1.run(CalDavLoaderImpl.java:368) ~[na:na]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471) [na:1.7.0_75]
at java.util.concurrent.FutureTask.run(FutureTask.java:262) [na:1.7.0_75]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145) [na:1.7.0_75]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615) [na:1.7.0_75]
at java.lang.Thread.run(Thread.java:745) [na:1.7.0_75]
Caused by: java.lang.UnsupportedOperationException: Cannot set timezone for UTC properties
at net.fortuna.ical4j.model.property.UtcProperty.setTimeZone(UtcProperty.java:94) ~[na:na]
at net.fortuna.ical4j.data.CalendarBuilder.updateTimeZone(CalendarBuilder.java:375) ~[na:na]
at net.fortuna.ical4j.data.CalendarBuilder.access$300(CalendarBuilder.java:89) ~[na:na]
at net.fortuna.ical4j.data.CalendarBuilder$ContentHandlerImpl.parameter(CalendarBuilder.java:299) ~[na:na]
at net.fortuna.ical4j.data.CalendarParserImpl$ParameterParser.parse(CalendarParserImpl.java:331) ~[na:na]
at net.fortuna.ical4j.data.CalendarParserImpl$ParameterParser.access$1700(CalendarParserImpl.java:284) ~[na:na]
at net.fortuna.ical4j.data.CalendarParserImpl$ParameterListParser.parse(CalendarParserImpl.java:272) ~[na:na]
at net.fortuna.ical4j.data.CalendarParserImpl$PropertyParser.parse(CalendarParserImpl.java:208) ~[na:na]
at net.fortuna.ical4j.data.CalendarParserImpl$PropertyParser.access$1100(CalendarParserImpl.java:189) ~[na:na]
at net.fortuna.ical4j.data.CalendarParserImpl$PropertyListParser.parse(CalendarParserImpl.java:173) ~[na:na]
at net.fortuna.ical4j.data.CalendarParserImpl$ComponentParser.parse(CalendarParserImpl.java:385) ~[na:na]
at net.fortuna.ical4j.data.CalendarParserImpl$ComponentParser.access$900(CalendarParserImpl.java:369) ~[na:na]
at net.fortuna.ical4j.data.CalendarParserImpl$PropertyListParser.parse(CalendarParserImpl.java:170) ~[na:na]
at net.fortuna.ical4j.data.CalendarParserImpl.parse(CalendarParserImpl.java:120) ~[na:na]
... 11 common frames omitted
- macht, was nun überhaupt nicht an diese Stelle passte!!! In meiner openhab.cfg ist dort kein Leerzeichen.
