Hello,
i wish to get rid of third party node-red-knx modules and use only the proServ, that's more reliable than other third party stuffs.
For now, when you need to switch a light, you need to have it registered to the proKNX via ETS.
Is there a way to have in the future, a RealKNX module that allow you to send "semi raw" data to proKNX, without having to add each Group Address via ETS?
For example, i wish to control tons of group addresses that i do not intend to add to the proKNX and i need a simplest way to do that, maybe using a module to send to the proKNX a payload like {groupaddress:0/1/8; datapoint
TP1; value:true}
The same may be done for receiving "semi raw" data from a realKNX module.
Thanks.
TP1; value:true}The same may be done for receiving "semi raw" data from a realKNX module.
Thanks.
