funktioniert leider nicht...ich brauche einen immer wieder auslösenden Trigger (ob 0 oder 1 ist egal). Hat jemand dazu eine Idee?
alexa_item_turn_on: 1 alexa_item_turn_off: 1
alexa_item_turn_on: 0
alexa_name = "Trigger" alexa_device = trigger_test alexa_actions = "TurnOn TurnOff" alexa_retrievable = False alexa_proactivelyReported: = True autotimer: 1 = 1
"directive": {
"header": {
"namespace": "Alexa.Discovery",
"name": "Discover",
"messageId": "Unique identifier, preferably a version 4 UUID",
"payloadVersion": "3"
"payload": {
"scope": {
"type": "BearerToken",
"token": "OAuth2.0 bearer token"
"directive": {
"header": {
"name": "Discover",
"payload": {
"scope": {
[02/Oct/2023:15:51:26 +0200] "POST / HTTP/1.1" 500 438 "-" "-"
Alles sollte stimmen...lambda test bringt aber:{
"header": {
"messageId": "ba2bd4fd87ba45638b6639e7da5aa80f",
"namespace": "Alexa.ConnectedHome.Discovery",
"payloadVersion": "2",
"name": "DiscoverAppliancesResponse"
Haustuer:
type: bool
autotimer: 1 = 0
init: 1
alexa_actions : Unlock
alexa_icon: SMARTLOCK
alexa_description: Haustür
alexa_name: Haustuer
alexa_device: haustuer
2022-11-20 12:42:15 Type: INFO - respondig ReportState for 'haustuer' 2022-11-20 12:42:15 Type: INFO - received ReportState for 'haustuer' 2022-11-20 12:42:12 Type: INFO - respondig ReportState for 'haustuer' 2022-11-20 12:42:12 Type: INFO - received ReportState for 'haustuer' 2022-11-20 12:42:09 Type: INFO - respondig ReportState for 'haustuer'
EG:
Flur:
haustuer:
unlock:
knx_send: 9/9/1
type: bool
visu_acl: rw
knx_dpt: 1
alexa_actions: Unlock
autotimer: 5 = 0
on_change:
- EG.Flur.haustuer.state = 0 if sh.EG.Flur.haustuer.unlock() == True else None
lock:
knx_send: 9/9/2
type: bool
visu_acl: rw
knx_dpt: 1
alexa_actions: Lock
autotimer: 5 = 0
on_change:
- EG.Flur.haustuer.state = 1 if sh.EG.Flur.haustuer.lock() == True else None
state:
knx_listen: 9/9/3
knx_init: 9/9/3
type: num
visu_acl: rw
knx_dpt: 20
alexa_actions: ReportLockState
Haustuer:
type: bool
autotimer: 1 = 0
init: 1
Lock:
type: bool
enforce_updates: 'true'
knx_listen:
- 4/1/30
knx_dpt: 1
#eval: not sh..inverted()
#eval_trigger: .inverted
alexa_actions : Lock
alexa_device: Schuppen
inverted:
type: bool
knx_listen:
- 10/3/1 # zentral Licht aus
- 0/1/3 # Türen Schließen
knx_dpt: 1
on_update: .. = not value
alexa_actions : Unock
Schuppen:
Reed:
Aussentuer:
geschlossen:
type: bool
knx_dpt: 1
knx_cache: 8/1/1
database: 'true'
#database_maxage: 365
alexa_actions : ReportLockState
alexa_description: Schuppen
alexa_name: Schuppen
2022-11-18 15:27:42 Type: INFO - respondig ReportState for 'haustuer' 2022-11-18 15:27:42 Type: INFO - received ReportState for 'haustuer'
