Also Du solltest noch ein enforce_updates bei config unter trial.taster spendieren. Dann würde ich in der Logik nicht auf == 1 prüfen sondern einfach schreiben
if sh.trial.taster():
sh.trial.licht(not sh.trial.licht() )
Dann schaltet Dein Taster um und nicht ein. Ist zum Testen einfacher...
2017-01-03 10:12:43 DEBUG __init__ smartvisu copy_widgets: Could not find source directory sv_widgets in plugins/backend -- __init__.py:copy_widgets:461
2017-01-03 10:12:43 DEBUG plugin Main Starting sql Plugin -- plugin.py:start:77
2017-01-03 10:12:43 DEBUG __init__ smartvisu copy_widgets: Could not find source directory sv_widgets in plugins/knx -- __init__.py:copy_widgets:461
2017-01-03 10:12:43 DEBUG __init__ smartvisu copy_widgets: Could not find source directory sv_widgets in plugins/visu_websocket -- __init__.py:copy_widgets:461
2017-01-03 10:12:43 DEBUG __init__ smartvisu copy_widgets: Could not find source directory sv_widgets in plugins/visu_smartvisu -- __init__.py:copy_widgets:461
2017-01-03 10:12:43 DEBUG __init__ smartvisu copy_widgets: Could not find source directory sv_widgets in plugins/cli -- __init__.py:copy_widgets:461
2017-01-03 10:12:43 DEBUG __init__ smartvisu copy_widgets: Could not find source directory sv_widgets in plugins/sqlite_visu2_8 -- __init__.py:copy_widgets:461
2017-01-03 10:12:43 INFO __init__ smartvisu Adding import statements to root.html -- __init__.py:install_widgets:436
2017-01-03 10:12:43 WARNING __init__ smartvisu Generating pages for smartVISU -- __init__.py:__init__:106
2017-01-03 10:12:43 INFO __init__ smartvisu copy_templates: Copying template 'category_page.html' from plugin to smartVISU -- __init__.py:copy_templates:374
2017-01-03 10:12:43 INFO __init__ smartvisu copy_templates: Copying template 'rooms.html' from plugin to smartVISU -- __init__.py:copy_templates:374
2017-01-03 10:12:43 INFO __init__ smartvisu copy_templates: Copying template 'roomlite.html' from plugin to smartVISU -- __init__.py:copy_templates:374
2017-01-03 10:12:43 INFO __init__ smartvisu copy_templates: Copying template 'room.html' from plugin to smartVISU -- __init__.py:copy_templates:374
2017-01-03 10:12:43 INFO __init__ smartvisu copy_templates: Copying template 'widgetblock_blk_noh.html' from plugin to smartVISU -- __init__.py:copy_templates:374
2017-01-03 10:12:43 INFO __init__ smartvisu copy_templates: Copying template 'navigation.html' from plugin to smartVISU -- __init__.py:copy_templates:374
2017-01-03 10:12:43 INFO __init__ smartvisu copy_templates: Copying template 'widgetblock2_blk_std.html' from plugin to smartVISU -- __init__.py:copy_templates:374
2017-01-03 10:12:43 INFO __init__ smartvisu copy_templates: Copying template 'widgetblock_std_std.html' from plugin to smartVISU -- __init__.py:copy_templates:374
2017-01-03 10:12:43 INFO __init__ smartvisu copy_templates: Copying template 'navi_sep.html' from plugin to smartVISU -- __init__.py:copy_templates:374
2017-01-03 10:12:43 INFO __init__ smartvisu copy_templates: Copying template 'widgetblock_blk_std.html' from plugin to smartVISU -- __init__.py:copy_templates:374
2017-01-03 10:12:43 INFO __init__ smartvisu copy_templates: Copying template 'widgetblock2_std_std.html' from plugin to smartVISU -- __init__.py:copy_templates:374
2017-01-03 10:12:43 INFO __init__ smartvisu copy_templates: Copying template 'index.html' from plugin to smartVISU -- __init__.py:copy_templates:374
2017-01-03 10:12:43 INFO __init__ smartvisu copy_templates: Copying template 'heading.html' from plugin to smartVISU -- __init__.py:copy_templates:374
2017-01-03 10:12:43 INFO __init__ smartvisu copy_templates: Copying template 'category.html' from plugin to smartVISU -- __init__.py:copy_templates:374
2017-01-03 10:12:43 INFO __init__ smartvisu copy_templates: Copying template 'navi.html' from plugin to smartVISU -- __init__.py:copy_templates:374
2017-01-03 10:12:43 INFO __init__ smartvisu copy_templates: Copying template 'roomslite.html' from plugin to smartVISU -- __init__.py:copy_templates:374
2017-01-03 10:12:43 ERROR connection Connections KNX: could not connect to 192.168.178.26:6720 (TCP): [Errno 111] Verbindungsaufbau abgelehnt -- connection.py:connect:389
2017-01-03 10:12:43 ERROR connection Connections _websocket: problem binding 0.0.0.0:2424 (TCP): [Errno 98] Die Adresse wird bereits verwendet -- connection.py:connect:156
2017-01-03 10:12:43 ERROR connection Connections CLI: problem binding 0.0.0.0:2323 (TCP): [Errno 98] Die Adresse wird bereits verwendet -- connection.py:connect:156
2017-01-03 10:12:48 DEBUG item env_init Item env.core.version = 1.2.0.man via Logic None None -- item.py:__update:374
2017-01-03 10:12:48 DEBUG item env_init Item env.core.start = 2017-01-03 10:12:48.513038+01:00 via Logic None None -- item.py:__update:374
2017-01-03 10:12:48 DEBUG item env_init Item env.system.name = shng via Logic None None -- item.py:__update:374
2017-01-03 10:12:48 DEBUG item env_init Item env.system.start = 2017-01-03 09:43:34.513988+01:00 via Logic None None -- item.py:__update:374
2017-01-03 10:12:48 DEBUG item env_loc Item env.location.sunrise = 2017-01-04 08:27:24.026573+01:00 via Logic None None -- item.py:__update:374
2017-01-03 10:12:48 DEBUG item env_loc Item env.location.sunrise.azimut.degrees = 137.36 via Logic None None -- item.py:__update:374
2017-01-03 10:12:48 DEBUG item env_loc Item env.location.sunrise.elevation.degrees = 6.46 via Logic None None -- item.py:__update:374
2017-01-03 10:12:48 DEBUG item env_loc Item env.location.sunrise.azimut.radians = 2.4 via Logic None None -- item.py:__update:374
2017-01-03 10:12:48 DEBUG item env_loc Item env.location.sunrise.elevation.radians = 0.11 via Logic None None -- item.py:__update:374
2017-01-03 10:12:48 DEBUG item env_loc Item env.location.sunset = 2017-01-03 16:41:30.870570+01:00 via Logic None None -- item.py:__update:374
2017-01-03 10:12:48 DEBUG item env_loc Item env.location.sunset.azimut.degrees = 245.42 via Logic None None -- item.py:__update:374
2017-01-03 10:12:48 DEBUG item env_loc Item env.location.sunset.elevation.degrees = -9.22 via Logic None None -- item.py:__update:374
2017-01-03 10:12:48 DEBUG item env_loc Item env.location.sunset.azimut.radians = 4.28 via Logic None None -- item.py:__update:374
2017-01-03 10:12:48 DEBUG item env_loc Item env.location.sunset.elevation.radians = -0.16 via Logic None None -- item.py:__update:374
2017-01-03 10:12:48 DEBUG item env_loc Item env.location.sun_position.azimut.degrees = 147.07 via Logic None None -- item.py:__update:374
2017-01-03 10:12:48 DEBUG item env_loc Item env.location.sun_position.elevation.degrees = 10.84 via Logic None None -- item.py:__update:374
2017-01-03 10:12:48 DEBUG smarthome sh.gc Garbage collector: collected 0 objects. -- smarthome.py:_garbage_collection:492
2017-01-03 10:12:48 DEBUG item env_loc Item env.location.sun_position.azimut.radians = 2.57 via Logic None None -- item.py:__update:374
2017-01-03 10:12:48 DEBUG smarthome sh.gc Object references: 12488 -- smarthome.py:_maintenance:484
2017-01-03 10:12:48 DEBUG item env_loc Item env.location.sun_position.elevation.radians = 0.19 via Logic None None -- item.py:__update:374
2017-01-03 10:12:48 DEBUG item env_loc Item env.location.moonrise = 2017-01-03 11:11:56.148943+01:00 via Logic None None -- item.py:__update:374
2017-01-03 10:12:48 DEBUG item env_loc Item env.location.moonset = 2017-01-03 22:32:15.695132+01:00 via Logic None None -- item.py:__update:374
2017-01-03 10:12:48 DEBUG item env_loc Item env.location.moonphase = 1 via Logic None None -- item.py:__update:374
2017-01-03 10:12:48 DEBUG item env_loc Item env.location.day = True via Logic None None -- item.py:__update:374
2017-01-03 10:12:49 DEBUG scheduler Scheduler sh.gc next time: 2017-01-04 02:04:00+01:00 -- scheduler.py:_next_time:316
2017-01-03 10:12:49 DEBUG scheduler Scheduler env_loc next time: 2017-01-03 10:42:49+01:00 -- scheduler.py:_next_time:316
2017-01-03 10:12:53 ERROR connection Connections _websocket: problem binding 0.0.0.0:2424 (TCP): [Errno 98] Die Adresse wird bereits verwendet -- connection.py:connect:156
2017-01-03 10:12:53 ERROR connection Connections CLI: problem binding 0.0.0.0:2323 (TCP): [Errno 98] Die Adresse wird bereits verwendet -- connection.py:connect:156
2017-01-03 10:12:55 DEBUG item env_stat Item env.system.libs.ephem_version = 3.7.6.0 via Logic None None -- item.py:__update:374
2017-01-03 10:12:55 DEBUG item env_stat Item env.core.memory = 16453632 via Logic None None -- item.py:__update:374
2017-01-03 10:12:55 DEBUG item env_stat Item env.system.load = 0.1 via Logic None None -- item.py:__update:374
2017-01-03 10:12:55 DEBUG item env_stat Item env.system.diskfree = 62494707712 via Logic None None -- item.py:__update:374
2017-01-03 10:12:55 DEBUG item env_stat Item env.system.disksize = 70801424384 via Logic None None -- item.py:__update:374
2017-01-03 10:12:55 DEBUG item env_stat Item env.system.diskusage = 4686614528 via Logic None None -- item.py:__update:374
2017-01-03 10:12:55 DEBUG item env_stat Item env.system.diskusagepercent = 6.62 via Logic None None -- item.py:__update:374
2017-01-03 10:12:55 DEBUG item env_stat Item env.location.moonlight = 25 via Logic None None -- item.py:__update:374
2017-01-03 10:12:55 DEBUG scheduler Scheduler env_stat next time: 2017-01-03 10:17:55+01:00 -- scheduler.py:_next_time:316
2017-01-03 10:13:03 ERROR connection Connections _websocket: problem binding 0.0.0.0:2424 (TCP): [Errno 98] Die Adresse wird bereits verwendet -- connection.py:connect:156
2017-01-03 10:13:03 ERROR connection Connections CLI: problem binding 0.0.0.0:2323 (TCP): [Errno 98] Die Adresse wird bereits verwendet -- connection.py:connect:156
^C2017-01-03 10:13:04 INFO smarthome Main Number of Threads: 7 -- smarthome.py:stop:337
2017-01-03 10:13:04 INFO plugin Main Stop Plugins -- plugin.py:stop:81
2017-01-03 10:13:04 DEBUG plugin Main Stopping knx Plugin -- plugin.py:stop:83
2017-01-03 10:13:04 DEBUG plugin Main Stopping visu Plugin -- plugin.py:stop:83
2017-01-03 10:13:04 DEBUG plugin Main Stopping smartvisu Plugin -- plugin.py:stop:83
2017-01-03 10:13:04 DEBUG plugin Main Stopping cli Plugin -- plugin.py:stop:83
2017-01-03 10:13:04 DEBUG plugin Main Stopping sql Plugin -- plugin.py:stop:83
2017-01-03 10:13:05 INFO smarthome Main SmartHome.py stopped -- smarthome.py:stop:361
So das ist die Ausgabe.
Eine Frage noch zum enforce_updates: Gehört das zu den items oder kommt das in die logic.conf? Am besten hänge ich noch einmal alles an.
trial.py
sh.trial.licht( not sh.trial.licht() )
print "if zweig"
else:
print "else zweig"
ampere84 es gehört zu dem jew item wo du das haben möchtest..
PS: hier hast Du doch offenbar schon das Problem
Läuft der KNXD ? Hast Du diesen mal autonom getestet?
Autonom testen bedeutet mittels groupwrite? Ja das funktioniert. Ich sende GAs und die entsprechenden Ausgänge am Aktor werden gesetzt.
Was ist denn mit der IP des Hosts vom KNX in der plugin.conf gemeint? Ich habe jetzt mal die IP meines IP-Interfaces angegeben.
