Problem mit KNXD Installation
    Ich bin aktuell dabei eine neue SD lt. Komplettanleitung aufzusetzen.
    SHNG + SV läuft, jedoch bekomme ich eine Fehlermeldung beim Versuch KNXD zu starten. Bis dahin hatte ich keinerlei Fehlermeldungen.
    smarthome@raspberrypi:~ $ sudo systemctl stop knxd.socket
    [sudo] password for smarthome:
    smarthome@raspberrypi:~ $ sudo systemctl stop knxd.service
    smarthome@raspberrypi:~ $ sudo systemctl enable knxd.service
    Synchronizing state for knxd.service with sysvinit using update-rc.d...
    Executing /usr/sbin/update-rc.d knxd defaults
    Executing /usr/sbin/update-rc.d knxd enable
    smarthome@raspberrypi:~ $ sudo systemctl enable knxd.socket
    smarthome@raspberrypi:~ $ sudo systemctl start knxd.socket
    smarthome@raspberrypi:~ $ sudo systemctl start knxd.service
    Job for knxd.service failed. See 'systemctl status knxd.service' and 'journalctl -xn' for details.
    smarthome@raspberrypi:~ $ sudo systemctl status knxd.socket
    ● knxd.socket - KNX Daemon (socket)
       Loaded: loaded (/lib/systemd/system/knxd.socket; enabled)
       Active: active (running) since Sam 2017-04-22 20:19:02 CEST; 30s ago
       Listen: /var/run/knx (Stream)
               [::]:6720 (Stream)
    Apr 22 20:19:02 raspberrypi systemd[1]: Starting KNX Daemon (socket).
    Apr 22 20:19:02 raspberrypi systemd[1]: Listening on KNX Daemon (socket).
    smarthome@raspberrypi:~ $ sudo systemctl status knxd.service
    ● knxd.service - KNX Daemon
       Loaded: loaded (/lib/systemd/system/knxd.service; enabled)
       Active: activating (auto-restart) (Result: exit-code) since Sam 2017-04-22 20:19:38 CEST; 9s ago
      Process: 1004 ExecStart=/usr/bin/knxd $KNXD_OPTS (code=exited, status=1/FAILURE)
     Main PID: 1004 (code=exited, status=1/FAILURE)
    Apr 22 20:19:38 raspberrypi systemd[1]: Failed to start KNX Daemon.
    Apr 22 20:19:38 raspberrypi systemd[1]: Unit knxd.service entered failed state.
    # configuration for knxd.service
    KNXD_OPTS="-c --no-tunnel-client-queuing -b ipt:192.168.0.200"
    Kann mir jemand sagen wie ich dieses Problem lösen kann?
    P.S.: Ich hatte das Problem bereits in diesem Thread gepostet, aber ich denke es passt besser hier her.
    Zuletzt geändert von fuxl66; 25.04.2017, 11:36.
    Welche Komplettanleitung meinst Du denn genau? Diese hier https://github.com/smarthomeNG/smart...d-installieren?
    Da steht das mit den Optionen aber ganz anders ...
      Sorry, hatte die Komplettanleitung nicht verlinkt. Ja genau diese meine ich.
      Ich habe auf einem zweiten System bereits KNXD mit dieser Option am Laufen. Allerdings mit Version 0.11.
      (Weinzierl 730 IP Interface)
      Zuletzt geändert von fuxl66; 25.04.2017, 11:59.
        Naja, zum Thema knxd kann man nur sagen: Die Installationsanweisungen auf Github passen schon und es gibt einige weitreichende Änderungen zwischen den Versionen. 0.10 -> 0.12 -> 0.14 insofern schaue Dir genau an, welche Version vom knxd Du installieren willst und halte Dich an github. Zum Beispiel hier für die 0.12er: https://github.com/knxd/knxd/tree/v0.12
          Mit Version 0.12 und folgenden Eintrag funktioniert es dann auch.
          KNXD_OPTS="-e 0.0.1 -E 0.0.2:8 -c --send-delay=30 -b ipt:192.168.0.200"
          Daran hätte ich nicht gedacht. Danke.
          Zuletzt geändert von fuxl66; 02.05.2017, 13:33.
            Ich setze grad meinen Raspi nach Komplettanleitung auf. Aktuell bin ich bei knxd. knxd läuft soweit und ich kann gruppenadressen schalten.
            Während der Installation sind aber einige Meldungen aufgetaucht. Siehe Anhang.
            Kann das zu Problemen führen oder sind die ganz normal?
            Danke.
            Markus
              Markus, die Fragen zu knxd wären am Besten in dem passenden Forum aufgehoben.
                Hat hier vielleicht jemand einen Tipp zum Thema? --> Schaltverzögerung Weinzierl 730
