das coding sieht korrekt aus, was sagt denn das Log?
Gruß, Waldemar
Gruß, Waldemar
2019-08-05 22:23:23 WARNING raumtemp.devices.onewire_gateway.ch1_error.sensor2_error Item raumtemp.devices.onewire_gateway.ch1_error.sensor2_error: value "2" does not match type bool. Via Eval raumtemp.devices.onewire_gateway.ch1_error.from_knx
# TODO: Candidate for Utils.to_bool() # write testcase and replace # -> should castng be restricted like this or handled exactly like Utils.to_bool()? # Example: _cast_bool(2) is False, Utils.to_bool(2) is True def _cast_bool(value): if type(value) in [bool, int, float]: if value in [False, 0]: return False elif value in [True, 1]: return True else: raise ValueError elif type(value) in [str, str]: if value.lower() in ['0', 'false', 'no', 'off', '']: return False elif value.lower() in ['1', 'true', 'yes', 'on']: return True else: raise ValueError else: raise TypeError
