Wenn ich das Alexa Plugin in der plugin.yaml wie folg definiere:
bekomme ich beim starten:
Mit class_name und class_path funktioniert es:
Mache ich was falsch oder gibt es da einen Bug im Alexa Plugin?
LG
mode
PS: SmarthomeNG und plugins sind auf dem aktuellen MASTER Branch...
alexa4p3: service_port: 9001 plugin_name: alexa4p3
2019-11-23 20:21:09 INFO lib.shyaml Loading '/home/smarthome/smarthome_1.6.1/plugins/alexa4p3/plugin.yaml' to 'OrderedDict'
2019-11-23 20:21:09 INFO lib.metadata plugin 'alexa4p3': Metadata paramlist = '['service_port']'
2019-11-23 20:21:09 INFO lib.metadata plugin 'alexa4p3': Metadata itemdeflist = '['alexa_name', 'alexa_description', 'alexa_device', 'alexa_icon', 'alexa_actions', 'alexa_retrievable', 'alexa_proactivelyReported', 'alexa_types', 'alexa_item_range', 'alexa_item_turn_on', 'alexa_color_value_type', 'alexa_thermo_config', 'alexa[I]stream[/I](1)1(2)(3)', 'alexa_csc_uri', 'alexa_auth_cred', 'alexa_camera_imageUri']'
2019-11-23 20:21:09 ERROR lib.plugin Plugin 'alexa4p3' exception during execution of plugin: module 'plugins.alexa4p3' has no attribute 'alexap3'
File "/home/smarthome/smarthome_1.6.1/lib/plugin.py", line 553, in [B]init[/B]
exec("self.plugin = {0}.{1}.[B]new[/B]({0}.{1})".format(classpath, classname))
File "<string>", line 1, in <module>
AttributeError: module 'plugins.alexa4p3' has no attribute 'alexap3'
2019-11-23 20:21:09 INFO lib.shyaml Loading '/home/smarthome/smarthome_1.6.1/plugins/alexa4p3/locale.yaml' to 'dict'
2019-11-23 20:21:09 ERROR lib.plugin Plugin 'alexa4p3' from section 'alexa4p3' exception: 'PluginWrapper' object has no attribute 'plugin'
File "/home/smarthome/smarthome_1.6.1/lib/plugin.py", line 145, in [B]init[/B]
plugin_thread = PluginWrapper(smarthome, plugin, classname, classpath, args, instance, self.meta, self._gtrans)
File "/home/smarthome/smarthome_1.6.1/lib/plugin.py", line 571, in [B]init[/B]
if isinstance(self.get_implementation(), SmartPlugin):
File "/home/smarthome/smarthome_1.6.1/lib/plugin.py", line 715, in get_implementation
return self.plugin
AttributeError: 'PluginWrapper' object has no attribute 'plugin'
2019-11-23 20:21:09 INFO lib.plugin Load of plugins finished
alexa4p3: class_name: Alexa4P3 class_path: plugins.alexa4p3 service_port: 9001 plugin_name: alexa4p3
LG
mode
