Nur img1.7.1 auf die Karte gezogen, Anwenderdaten nachgefühlt und langsam mit der Visu begonnen.
Bei der Index.html versucht die Sonne/Mond-Zeiten anzuzeigen.
2020-04-18 20:29:10 ERROR item lib.item Item Haustechnik.Hintertuer.Schloss.Action_out: problem running <bound method Mqtt2.update_item of <plugins.mqtt.Mqtt2 object at 0x7fb95ee24cf8>>: 'Mqtt2' object has no attribute 'alive' -- item.py:__update:2370 Traceback (most recent call last): File "/usr/local/smarthome/lib/item.py", line 2368, in __update method(self, caller, source, dest) File "/usr/local/smarthome/plugins/mqtt/__init__.py", line 214, in update_item if self.alive and caller != self.get_shortname(): AttributeError: 'Mqtt2' object has no attribute 'alive' 2020-04-18 20:29:10 ERROR item lib.item Item Haustechnik.Schuppen.Schloss.Action_out: problem running <bound method Mqtt2.update_item of <plugins.mqtt.Mqtt2 object at 0x7fb95ee24cf8>>: 'Mqtt2' object has no attribute 'alive' -- item.py:__update:2370 Traceback (most recent call last): File "/usr/local/smarthome/lib/item.py", line 2368, in __update method(self, caller, source, dest) File "/usr/local/smarthome/plugins/mqtt/__init__.py", line 214, in update_item if self.alive and caller != self.get_shortname(): AttributeError: 'Mqtt2' object has no attribute 'alive' 2020-04-18 20:29:11 ERROR item lib.item Item Haustechnik.Lueftung.stufe.com_obj: problem running <bound method Mqtt2.update_item of <plugins.mqtt.Mqtt2 object at 0x7fb95ee24cf8>>: 'Mqtt2' object has no attribute 'alive' -- item.py:__update:2370 Traceback (most recent call last): File "/usr/local/smarthome/lib/item.py", line 2368, in __update method(self, caller, source, dest) File "/usr/local/smarthome/plugins/mqtt/__init__.py", line 214, in update_item if self.alive and caller != self.get_shortname(): AttributeError: 'Mqtt2' object has no attribute 'alive'
def run(self): """ Run method for the plugin """ self.logger.debug("Run method called") self.alive = True # start subscription to all topics self.start_subscriptions()
2020-04-29 19:43:58 ERROR plugins.telegram telegram: Unable to import Python package 'python-telegram-bot' 2020-04-29 19:43:58 ERROR lib.plugin Plugins: Plugin 'telegram' initialization failed, plugin not loaded
2020-04-29 22:55:23 WARNING __main__ -------------------- Init SmartHomeNG 1.7.1.master (cf2f7d85) -------------------- 2020-04-29 22:55:23 WARNING __main__ -------------------- Init SmartHomeNG 1.7.1.master (cf2f7d85) -------------------- 2020-04-29 22:55:23 WARNING __main__ Running in Python interpreter 'v3.7.3 final' (pid=13947) on linux platform 2020-04-29 22:55:23 WARNING __main__ Running in Python interpreter 'v3.7.3 final' (pid=13947) on linux platform 2020-04-29 22:55:24 WARNING lib.shtime Nutze Feiertage für Land 'DE', Provinz 'None', State 'None', 1 benutzerdefinierte Feiertagsdefinition(en) definiert 2020-04-29 22:55:24 WARNING lib.shtime Nutze Feiertage für Land 'DE', Provinz 'None', State 'None', 1 benutzerdefinierte Feiertagsdefinition(en) definiert 2020-04-29 22:55:24 INFO cherrypy.error [29/Apr/2020:22:55:24] ENGINE Bus STARTING 2020-04-29 22:55:24 INFO cherrypy.error [29/Apr/2020:22:55:24] ENGINE Serving on http://192.168.0.74:8384 2020-04-29 22:55:24 INFO cherrypy.error [29/Apr/2020:22:55:24] ENGINE Serving on http://192.168.0.74:8383 2020-04-29 22:55:24 INFO cherrypy.error [29/Apr/2020:22:55:24] ENGINE Bus STARTED 2020-04-29 22:55:25 WARNING plugins.cli CLI: You should set a password for this plugin. 2020-04-29 22:55:25 WARNING plugins.cli CLI: You should set a password for this plugin. 2020-04-29 22:55:26 WARNING lib.plugin Plugin section 'myOfenlog' uses same class 'OperationLog' and instance 'default' as plugin section 'mystatuslog' 2020-04-29 22:55:26 WARNING lib.plugin Plugin section 'myOfenlog' uses same class 'OperationLog' and instance 'default' as plugin section 'mystatuslog' 2020-04-29 22:55:26 WARNING lib.plugin Plugin section 'watchdoglogger' uses same class 'MemLog' and instance 'default' as plugin section 'statuslogger' 2020-04-29 22:55:26 WARNING lib.plugin Plugin section 'watchdoglogger' uses same class 'MemLog' and instance 'default' as plugin section 'statuslogger' 2020-04-29 22:55:26 INFO root Database [Database]: Connected with <pymysql.connections.Connection object at 0x7f07c05480b8> using "pyformat" style 2020-04-29 22:55:26 INFO root Database [Database]: Version 6 found 2020-04-29 22:55:26 ERROR plugins.telegram telegram: Unable to import Python package 'python-telegram-bot' 2020-04-29 22:55:26 ERROR plugins.telegram telegram: Unable to import Python package 'python-telegram-bot' 2020-04-29 22:55:26 ERROR lib.plugin Plugins: Plugin 'telegram' initialization failed, plugin not loaded 2020-04-29 22:55:26 ERROR lib.plugin Plugins: Plugin 'telegram' initialization failed, plugin not loaded
smarthome@debian64-smarthome:/usr/local/smarthome$ python -V Python 2.7.16 smarthome@debian64-smarthome:/usr/local/smarthome$ python3 -V Python 3.7.3 smarthome@debian64-smarthome:/usr/local/smarthome$ pip -V pip 20.1 from /home/smarthome/.local/lib/python3.7/site-packages/pip (python 3.7) smarthome@debian64-smarthome:/usr/local/smarthome$ pip3 -V pip 20.1 from /home/smarthome/.local/lib/python3.7/site-packages/pip (python 3.7)
root: # This is the configuration of the root logger. Additionally to be written to other logs, # ALL entries are handed to this logger. To keep the warnings file easy readable, # the level should always be WARNING! # # Logging of details (level INFO and DEBUG) should be handled by other loggers and written # to other log files than the warnings file. # #level: WARNING #handlers: [shng_warnings_file] level: DEBUG handlers: [shng_details_file]
