Super.
Danke für die Info!
Hendrik
Danke für die Info!
Hendrik
[szene]
[[nacht]]
type = scene
knx_dpt = 1
knx_send = 0/4/1
knx_listen = 0/4/1
visu = yes
1 zentral.aus off 1 wez.pm.sperre on
[zentral]
[[aus]]
type = bool
knx_dpt = 1
knx_send = 0/0/5
visu = yes
enforce_updates = yes
[wez]
[[pm]]
[[[sperre]]]
type = bool
visu = yes
knx_dpt = 1
knx_cache = 6/1/150
knx_send = 6/1/150
2013-08-04 18:42:57,335 SmartHome.py DEBUG knx: 1.1.254 set 0/4/1 to True -- __init__.py:parse_telegram:185 2013-08-04 18:42:57,341 SmartHome.py DEBUG szene.nacht = 1 via KNX 1.1.254 -- item.py:_update:219 2013-08-04 18:42:57,352 SmartHome.py ERROR Problem running <bound method Scenes._trigger of <lib.scene.Scenes instance at 0x6cb0d0>>: _trigger() takes exactly 4 arguments (5 given) -- item.py:_update:230 2013-08-04 18:42:58,869 SmartHome.py DEBUG knx: 1.1.11 set 2/7/162 to 0.582000017166 -- __init__.py:parse_telegram:185
[[[Buero]]]
type = bool
knx_dpt = 1
knx_send = 1/0/21
knx_listen = 1/0/24
knx_cache = 1/0/24
visu_acl = rw
[Szenen]
[[LichtRaff]]
type = scene
visu_acl = rw
knx_dpt = 1
15 EG.Licht.Buero 0
2013-11-18 20:51:26,816 DEBUG Main 192.168.0.1:55367 sent '{"cmd":"item","id":"Szenen.LichtRaff","val":"15"}' -- __init__.py:json_parse:269
2013-11-18 20:51:26,821 DEBUG Main Item Szenen.LichtRaff = 15 via Visu 192.168.0.1:55367 None -- item.py:__update:363
2013-11-18 20:51:26,827 DEBUG Main Item EG.Licht.Buero = False via Scene Szenen.LichtRaff None -- item.py:__update:363
2013-11-18 20:51:26,866 DEBUG Main knx: 0.0.1 set 1/0/21 to 00 -- __init__.py:parse_telegram:181
2013-11-18 20:51:26,909 DEBUG Main knx: 1.1.1 set 1/0/24 to False -- __init__.py:parse_telegram:190
2013-11-18 20:51:26,914 DEBUG Main Item EG.Licht.Buero_Read = False via KNX 1.1.1 1/0/24 -- item.py:__update:363
2013-11-18 20:51:31,034 DEBUG Main 192.168.0.1:55367 sent '{"cmd":"monitor","items":["EG.Licht.Buero","EG.Licht.VRWand","EG.Raff.KuecheTuere.ReadPos","EG.Raff.EZTuere.ReadPos","EG.Raff.EZFensterGross.ReadPos","EG.Raff.EZFensterKlein.ReadPos","EG.Raff.WZTuere.ReadPos","EG.Raff.WZFenster.ReadPos","OG.Raff.SZSR.ReadPos","OG.Raff.KiZiJona.ReadPos","OG.Raff.KiZiWest.ReadPos","OG.Raff.VR.ReadPos","OG.Raff.Bad.ReadPos","EG.Raff.KuecheTuere.ReadAngle","EG.Raff.EZTuere.ReadAngle","EG.Raff.EZFensterGross.ReadAngle","EG.Raff.EZFensterKlein.ReadAngle","EG.Raff.WZTuere.ReadAngle","EG.Raff.WZFenster.ReadAngle","OG.Raff.SZSR.ReadAngle","OG.Raff.KiZiJona.ReadAngle","OG.Raff.KiZiWest.ReadAngle","OG.Raff.VR.ReadAngle","OG.Raff.Bad.ReadAngle","EG.Licht.TR_Read","EG.Licht.WR_Read","EG.Licht.Buero_Read","EG.Licht.VRWand_Read","EG.Licht.VRDecke_Read","EG.Licht.BadWand_Read","EG.Licht.BadDecke_Read","EG.Licht.KuecheDecke_Read","EG.Licht.KuecheSpuele_Read","EG.Licht.EZRandzone_Read","EG.Licht.EZEsstisch_Read","EG.Licht.EZGang_Read","EG.Licht.Stiege_Read","EG.Licht.Lesebereich_Read","EG.Licht.WZDecke_Read","EG.Licht.WZWand_Read","EG.Licht.WZBoxen_Read","OG.Licht.VRWand_Read","OG.Licht.KiZiJona_Read","OG.Licht.KiZiWest_Read","OG.Licht.BadDecke_Read","OG.Licht.BadSpiegel_Read","OG.Licht.BadBox_Read","OG.Licht.BadWand_Read","OG.Licht.SR_Read","OG.Licht.SZDecke_Read","OG.Licht.SZWand_Read","AB.Licht.Eingang_Read","solar.current","solar.day"]}' -- __init__.py:json_parse:269
2013-11-18 20:51:32,132 DEBUG Main 192.168.0.1:55367 sent '{"cmd":"item","id":"EG.Licht.Buero","val":1}' -- __init__.py:json_parse:269
2013-11-18 20:51:32,137 DEBUG Main Item EG.Licht.Buero = True via Visu 192.168.0.1:55367 None -- item.py:__update:363
2013-11-18 20:51:32,172 DEBUG Main knx: 0.0.1 set 1/0/21 to 01 -- __init__.py:parse_telegram:181
2013-11-18 20:51:32,222 DEBUG Main knx: 1.1.1 set 1/0/24 to True -- __init__.py:parse_telegram:190
2013-11-18 20:51:32,228 DEBUG Main Item EG.Licht.Buero_Read = True via KNX 1.1.1 1/0/24 -- item.py:__update:363
2013-11-18 20:51:34,633 DEBUG Main 192.168.0.1:55367 sent '{"cmd":"monitor","items":["ZS.Raffstore.Gesamt.move","ZS.Raffstore.Gesamt.stop","Szenen.Raff","ZS.Raffstore.Sueden.move","Szenen.LichtRaff","EG.Raff.KuecheTuere.ReadPos","EG.Raff.EZTuere.ReadPos","EG.Raff.EZFensterGross.ReadPos","EG.Raff.EZFensterKlein.ReadPos","EG.Raff.WZTuere.ReadPos","EG.Raff.WZFenster.ReadPos","OG.Raff.SZSR.ReadPos","OG.Raff.KiZiJona.ReadPos","OG.Raff.KiZiWest.ReadPos","OG.Raff.VR.ReadPos","OG.Raff.Bad.ReadPos","EG.Raff.KuecheTuere.ReadAngle","EG.Raff.EZTuere.ReadAngle","EG.Raff.EZFensterGross.ReadAngle","EG.Raff.EZFensterKlein.ReadAngle","EG.Raff.WZTuere.ReadAngle","EG.Raff.WZFenster.ReadAngle","OG.Raff.SZSR.ReadAngle","OG.Raff.KiZiJona.ReadAngle","OG.Raff.KiZiWest.ReadAngle","OG.Raff.VR.ReadAngle","OG.Raff.Bad.ReadAngle","EG.Licht.TR_Read","EG.Licht.WR_Read","EG.Licht.Buero_Read","EG.Licht.VRWand_Read","EG.Licht.VRDecke_Read","EG.Licht.BadWand_Read","EG.Licht.BadDecke_Read","EG.Licht.KuecheDecke_Read","EG.Licht.KuecheSpuele_Read","EG.Licht.EZRandzone_Read","EG.Licht.EZEsstisch_Read","EG.Licht.EZGang_Read","EG.Licht.Stiege_Read","EG.Licht.Lesebereich_Read","EG.Licht.WZDecke_Read","EG.Licht.WZWand_Read","EG.Licht.WZBoxen_Read","OG.Licht.VRWand_Read","OG.Licht.KiZiJona_Read","OG.Licht.KiZiWest_Read","OG.Licht.BadDecke_Read","OG.Licht.BadSpiegel_Read","OG.Licht.BadBox_Read","OG.Licht.BadWand_Read","OG.Licht.SR_Read","OG.Licht.SZDecke_Read","OG.Licht.SZWand_Read","AB.Licht.Eingang_Read","solar.current","solar.day"]}' -- __init__.py:json_parse:269
2013-11-18 20:51:35,626 DEBUG Main 192.168.0.1:55367 sent '{"cmd":"item","id":"Szenen.LichtRaff","val":"15"}' -- __init__.py:json_parse:269
[Szenen]
[[LichtRaff]]
type = scene
[B]enforce_updates = true[/B]
visu_acl = rw
knx_dpt = 1
