Struktur für RTR
Hi Hendrik,
Um den Modus zu ändern!? Irgendwie versteh ich die Frage nicht...
Hi Hendrik,
[[[[stellwert]]]]
type = num
visu = yes
history = true
knx_dpt = 5001
knx_init = 5/2/84
sqlite = yes
[[[[heizen]]]]
type=bool
visu=true
eval= 0 if value = 0 else 1
eval_trigger=EG.Buero.Temperatur.stellwert
2013-11-13 13:04:47,434 EG.Buero.Temperatur.heizen WARNING Method EG.Buero.Temperatur.heizen exception: invalid syntax (<string>, line 1) -- scheduler.py:_task:300
eval= 0 if value == 0 else 1
2013-11-14 21:34:28 WARNING eg.Gaeste.heizung.nacht Item eg.Gaeste.heizung.nacht: problem evaluating value if value < 2 else ((sh.eg.Gaeste.heizung.modus() & 0x02) >> 2): unorderable types: NoneType() < int()
[[[[modus]]]]
type = num
knx_send = 3/2/149
knx_dpt = 20
knx_init = 3/2/149
sqlite = yes
type = num
[[[[nacht]]]]
type = bool
knx_send = 3/2/152
knx_dpt = 1
eval = value if value < 2 else ((sh.eg.Gaeste.heizung.modus() & 0x02) >> 2)
eval_trigger = sh.eg.Gaeste.heizung.modus
sqlite = yes
type = num
>>> sh.eg.Kueche.heizung.modus() 0 >>> ((sh.eg.Kueche.heizung.modus() & 0x02) >> 1) 0 >>> type((sh.eg.Kueche.heizung.modus() & 0x02)) <class 'int'>
Restarting SmartHome smarthome.py 2013-11-19 21:56:18 INFO 1w-sen 1-Wire: path not found for og.Till.heizung.estrich 2013-11-19 21:56:18 INFO 1w-sen 1-Wire: path not found for Daten.Kinderbad_hum 2013-11-19 21:56:18 INFO 1w-sen 1-Wire: path not found for Daten.Kessel_Ruecklauf 2013-11-19 21:56:18 INFO 1w-sen 1-Wire: path not found for Daten.Kessel_Vorlauf 2013-11-19 21:56:18 INFO 1w-sen 1-Wire: path not found for Daten.Elternbad_hum 2013-11-19 21:56:20 INFO 1w-sen 1-Wire: path not found for Daten.Kinderbad_Wasserleitung 2013-11-19 21:56:20 WARNING Daten.Keller_hum_abs Item Daten.Keller_hum_abs: problem evaluating sh.tools.rel2abs(sh.Daten.Keller_temp(),sh.Daten.Keller_hum()/100.0): 'Item' object has no attribute 'Keller_hum' 2013-11-19 21:56:20 INFO 1w-sen 1-Wire: path not found for Daten.Kessel 2013-11-19 21:56:20 INFO 1w-sen 1-Wire: path not found for Daten.Gaestebad_Wasserleitung 2013-11-19 21:56:21 WARNING aktuelles_wetter.relative_luftfeuchte-eval Item aktuelles_wetter.relative_luftfeuchte: problem evaluating sh.aktuelles_wetter.relative_luftfeuchte_perc() * 0.01: 'Item' object has no attribute 'relative_luftfeuchte_perc' 2013-11-19 21:57:38 INFO Main Number of Threads: 7 2013-11-19 21:57:38 INFO Main Stop Plugins Killing smarthome.py Init SmartHome.py 0.9-464-ga68dc36+ 2013-11-19 21:57:44 INFO Main Start SmartHome.py 0.9-464-ga68dc36+ 2013-11-19 21:57:44 INFO Main Init Scheduler 2013-11-19 21:57:44 INFO Main Init Plugins 2013-11-19 21:57:45 INFO Main Init Items 2013-11-19 21:57:45 ERROR Main Problem parsing '/usr/local/smarthome/items/Licht.bkup.conf' invalid character in line 90: [[[Lina ]]]. Valid characters are: abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789_ 2013-11-19 21:57:45 ERROR Main Problem parsing '/usr/local/smarthome/items/Licht.conf' invalid character in line 82: [[Lina ]]. Valid characters are: abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789_ 2013-11-19 21:57:45 INFO Main 1-Wire: unknown sensor specified for Daten.Keller_VDD using path: /26.A1B930010000/VDD 2013-11-19 21:57:45 INFO Main 1-Wire: unknown sensor specified for Daten.Elternbad_VDD using path: /28.219A1B030000/VDD 2013-11-19 21:57:45 INFO Main 1-Wire: unknown sensor specified for Daten.Flur_temporaer_VDD using path: /26.4AA02E010000/VDD 2013-11-19 21:57:45 INFO Main 1-Wire: unknown sensor specified for Daten.AbstellKeller_VDD using path: /26.7ED96B010000/VDD 2013-11-19 21:57:45 WARNING og.Till.heizung.komfort Item og.Till.heizung.komfort: problem evaluating value if value < 2 else (sh.og.Till.heizung.modus() & 0x01): unorderable types: NoneType() < int() 2013-11-19 21:57:45 WARNING og.Till.heizung.standby Item og.Till.heizung.standby: problem evaluating value if value < 2 else (sh.og.Till.heizung.modus() & 0x02) >> 1: unorderable types: NoneType() < int()
2013-11-22 23:34:03 WARNING OG.Tim.Klima.Heizung.komfort Item OG.Tim.Klima.Heizung.komfort: problem evaluating value if value < 2 else (sh.OG.Tim.Klima.Heizung.modus() & 0x01): unorderable types: NoneType() < int() 2013-11-22 23:34:03 WARNING OG.Tim.Klima.Heizung.standby Item OG.Tim.Klima.Heizung.standby: problem evaluating value if value < 2 else ((sh.OG.Tim.Klima.Heizung.modus() & 0x02) >> 1): unorderable types: NoneType() < int() 2013-11-22 23:34:04 WARNING OG.Tim.Klima.Heizung.nacht Item OG.Tim.Klima.Heizung.nacht: problem evaluating value if value < 2 else ((sh.OG.Tim.Klima.Heizung.modus() & 0x04) >> 2): unorderable types: NoneType() < int() 2013-11-22 23:34:04 WARNING OG.Tim.Klima.Heizung.frostschutz Item OG.Tim.Klima.Heizung.frostschutz: problem evaluating value if value < 2 else ((sh.OG.Tim.Klima.Heizung.modus() & 0x08) >> 3): unorderable types: NoneType() < int() ....
[OG]
[[Tim]]
[[[Klima]]]
[[[[Heizung]]]]
name = Temperatur
type = num
sqlite = yes
sv_widget = {{ device.rtr('TimRTR', 'Temperatur', 'OG.Tim.Klima.Heizung.ist', 'OG.Tim.Klima.Heizung.soll', 'OG.Tim.Klima.Heizung.sollwertverschiebung', 'OG.Tim.Klima.Heizung.stellwert', 'OG.Tim.Klima.Heizung.modus') }} | {{ plot.rtr ('TimPLOT', 'OG.Tim.Klima.Heizung.ist', 'OG.Tim.Klima.Heizung.soll', 'OG.Tim.Klima.Heizung.stellwert') }}
[[[[[ist]]]]]
type=num
visu=yes
knx_dpt=9
knx_listen=3/1/8
cache=true
sqlite=true
[[[[[soll]]]]]
type=num
acl=rw
knx_dpt=9
knx_init=3/2/8
sqlite=true
[[[[[sollwertverschiebung]]]]]
type=num
acl=rw
knx_dpt=9
knx_send=3/6/9
[[[[[stellwert]]]]]
type=num
acl=rw
knx_dpt=5001
knx_init=3/3/55
sqlite=true
[[[[[modus]]]]]
type=num
acl=rw
knx_dpt=20
knx_send=3/4/8
knx_init=3/4/8
[[[[[komfort]]]]]
type=bool
visu=true
knx_dpt=1
knx_send=3/7/3
eval=value if value < 2 else (sh.OG.Tim.Klima.Heizung.modus() & 0x01)
eval_trigger=OG.Tim.Klima.Heizung.modus
[[[[[standby]]]]]
type=bool
visu=true
eval=value if value < 2 else ((sh.OG.Tim.Klima.Heizung.modus() & 0x02) >> 1)
[[[[[nacht]]]]]
type=bool
visu=true
knx_dpt=1
knx_send=3/7/4
eval=value if value < 2 else ((sh.OG.Tim.Klima.Heizung.modus() & 0x04) >> 2)
[[[[[frostschutz]]]]]
type=bool
visu=true
knx_dpt=1
knx_send=3/7/5
eval=value if value < 2 else ((sh.OG.Tim.Klima.Heizung.modus() & 0x08) >> 3)
[[[[[frostalarm]]]]]
type=bool
visu=true
eval=(sh.OG.Tim.Klima.Heizung.modus() & 0x80) >> 7
[[[[[heizen]]]]]
type=bool
visu=true
eval=(sh.OG.Tim.Klima.Heizung.modus() & 0x20) >> 5
2013-12-01 23:28:05,991 WARNING EG.Buero.Temperatur.komfort-eval Item EG.Buero.Temperatur.komfort: problem evaluating value if value < 2 else (sh.EG.Buero.Temperatur.modus() & 0x01): unorderable types: str() < int() -- item.py:__run_eval:331
og.Elternbad.heizung.komfort-eval Item og.Elternbad.heizung.komfort: problem evaluating value if value < 2 else (sh.og.Elternbad.heizung.modus() & 0x01): unorderable types: str() < int()
[og]
[[Elternbad]]
[[[heizung]]]
[[[[modus]]]]
type = num
knx_send = 3/2/29
knx_dpt = 20
knx_init = 3/2/29
sqlite = cache
[[[[komfort]]]]
type = num
knx_send = 3/2/31
knx_dpt = 1
sqlite = cache
eval = value if value < 2 else (sh.og.Elternbad.heizung.modus() & 0x01)
eval_trigger = og.Elternbad.heizung.modus
sh.og.Elternbad.heizung.komfort() 0 >>> type(0x01) <class 'int'> >>> type(sh.og.Elternbad.heizung.komfort()) <class 'int'> >>> type(sh.og.Elternbad.heizung.komfort() & 0x01) <class 'int'> >>> type(sh.og.Elternbad.heizung.modus() & 0x01) <class 'int'> >>> type(sh.og.Elternbad.heizung.modus() ) <class 'int'> >>> sh.og.Elternbad.heizung.modus() 40
type(sh.og.Elternbad.heizung.komfort) <class 'lib.item.Item'>
