- √ - MIN/MAX Wert aus Datenbank
    ich möchte mir aus der Datenbank die MIN/MAX Temperaturwerte der letzten 24 Stunden anzeigen lassen.
    Funktioniert auch im Prinzip schon soweit, nur der MIN-Wert zeigt mir die letzen Tage immer 0,0 Grad an.
    Anbei das Logfile und die ItemConf:
    2013-12-28 23:45:54,079 INFO     Main         Start SmartHome.py 1.0-21-g7f162e6 -- smarthome.py:__init__:231
    2013-12-28 23:45:54,085 DEBUG    Main         Python 3.2.3 -- smarthome.py:__init__:232
    2013-12-28 23:45:54,091 INFO     Main         Init Scheduler -- scheduler.py:__init__:86
    2013-12-28 23:45:54,097 INFO     Main         Init Plugins -- smarthome.py:start:274
    2013-12-28 23:45:54,115 DEBUG    Scheduler    creating 5 workers -- scheduler.py:run:93
    2013-12-28 23:45:54,126 DEBUG    Main         Plugin: knx -- plugin.py:__init__:43
    2013-12-28 23:45:54,158 DEBUG    Main         Plugin: ow -- plugin.py:__init__:43
    2013-12-28 23:45:54,182 DEBUG    Main         Plugin: cli -- plugin.py:__init__:43
    2013-12-28 23:45:54,204 DEBUG    Main         Plugin: visu -- plugin.py:__init__:43
    2013-12-28 23:45:54,285 DEBUG    Main         Plugin: sql -- plugin.py:__init__:43
    2013-12-28 23:45:54,315 DEBUG    Main         SQLite 3.7.13 -- __init__.py:__init__:62
    2013-12-28 23:45:55,153 DEBUG    Main         SQLite: database integrity ok -- __init__.py:__init__:78
    2013-12-28 23:45:55,181 DEBUG    Main         SQLite pack next time: 2013-12-29 03:02:00+01:00 -- scheduler.py:_next_time:289
    2013-12-28 23:45:55,188 DEBUG    Main         Plugin: rrd -- plugin.py:__init__:43
    2013-12-28 23:45:55,288 DEBUG    Main         Plugin: mail -- plugin.py:__init__:43
    2013-12-28 23:45:55,449 INFO     Main         Init Items -- smarthome.py:start:280
    2013-12-28 23:45:55,875 DEBUG    Main         Item env.core.memory = 16784585.63763091 via SQLite None None -- item.py:set:457
    2013-12-28 23:45:55,923 DEBUG    Main         Item env.core.threads = 7.0 via SQLite None None -- item.py:set:457
    2013-12-28 23:45:55,970 DEBUG    Main         Item env.core.garbage = 0.0 via SQLite None None -- item.py:set:457
    2013-12-28 23:45:55,976 DEBUG    Main         Item env.core: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:56,020 DEBUG    Main         Item env.location: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:56,072 DEBUG    Main         Item env.system.load = 0.14684708993763512 via SQLite None None -- item.py:set:457
    2013-12-28 23:45:56,083 DEBUG    Main         Item env.system: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:56,087 DEBUG    Main         Item env: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:56,103 DEBUG    Main         KNX: Beleuchtung.Aussen.Haustuere listen on 2/1/1 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,109 DEBUG    Main         Item Beleuchtung.Aussen: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:56,121 DEBUG    Main         KNX: Beleuchtung.KG.Flur listen on 1/1/1 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,131 DEBUG    Main         KNX: Beleuchtung.KG.Buegelzimmer listen on 1/1/2 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,141 DEBUG    Main         KNX: Beleuchtung.KG.Lagerraum listen on 1/1/3 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,150 DEBUG    Main         KNX: Beleuchtung.KG.Buero listen on 1/1/4 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,156 DEBUG    Main         Item Beleuchtung.KG: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:56,169 DEBUG    Main         KNX: Beleuchtung.EG.Windfang listen on 2/1/2 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,178 DEBUG    Main         KNX: Beleuchtung.EG.Flur listen on 2/1/3 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,188 DEBUG    Main         KNX: Beleuchtung.EG.WC listen on 2/1/4 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,198 DEBUG    Main         KNX: Beleuchtung.EG.Speiss listen on 2/1/5 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,209 DEBUG    Main         KNX: Beleuchtung.EG.Kueche listen on 2/1/6 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,218 DEBUG    Main         KNX: Beleuchtung.EG.Esszimmer listen on 2/1/7 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,227 DEBUG    Main         KNX: Beleuchtung.EG.Wohnzimmer listen on 2/1/9 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,237 DEBUG    Main         KNX: Beleuchtung.EG.WohnzimmerWand listen on 2/1/11 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,242 DEBUG    Main         Item Beleuchtung.EG: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:56,254 DEBUG    Main         KNX: Beleuchtung.OG.Flur listen on 3/1/1 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,264 DEBUG    Main         KNX: Beleuchtung.OG.Kind1 listen on 3/1/2 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,273 DEBUG    Main         KNX: Beleuchtung.OG.Kind2 listen on 3/1/3 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,307 DEBUG    Main         KNX: Beleuchtung.OG.Eltern.Silke listen on 3/1/7 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,317 DEBUG    Main         KNX: Beleuchtung.OG.Eltern.Tom listen on 3/1/8 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,326 DEBUG    Main         KNX: Beleuchtung.OG.Eltern.Wandlampe listen on 3/1/4 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,331 DEBUG    Main         Item Beleuchtung.OG.Eltern: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:56,340 DEBUG    Main         KNX: Beleuchtung.OG.Ankleide listen on 3/1/5 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,349 DEBUG    Main         KNX: Beleuchtung.OG.Bad listen on 3/1/6 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,354 DEBUG    Main         Item Beleuchtung.OG: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:56,366 DEBUG    Main         KNX: Beleuchtung.DG.Dachboden listen on 4/1/1 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,371 DEBUG    Main         Item Beleuchtung.DG: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:56,376 DEBUG    Main         Item Beleuchtung: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:56,404 DEBUG    Main         KNX: Raffstore.EG.WC.pos listen on 2/4/14 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,409 DEBUG    Main         KNX: Raffstore.EG.WC.pos listen on and init with 2/4/14 -- __init__.py:parse_item:244
    2013-12-28 23:45:56,422 DEBUG    Main         KNX: Raffstore.EG.WC.angle listen on 2/4/15 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,427 DEBUG    Main         KNX: Raffstore.EG.WC.angle listen on and init with 2/4/15 -- __init__.py:parse_item:244
    2013-12-28 23:45:56,432 DEBUG    Main         Item Raffstore.EG.WC: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:56,454 DEBUG    Main         KNX: Raffstore.EG.Kueche1.pos listen on 2/4/74 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,458 DEBUG    Main         KNX: Raffstore.EG.Kueche1.pos listen on and init with 2/4/74 -- __init__.py:parse_item:244
    2013-12-28 23:45:56,472 DEBUG    Main         KNX: Raffstore.EG.Kueche1.angle listen on 2/4/75 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,476 DEBUG    Main         KNX: Raffstore.EG.Kueche1.angle listen on and init with 2/4/75 -- __init__.py:parse_item:244
    2013-12-28 23:45:56,481 DEBUG    Main         Item Raffstore.EG.Kueche1: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:56,504 DEBUG    Main         KNX: Raffstore.EG.Kueche2.pos listen on 2/4/64 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,508 DEBUG    Main         KNX: Raffstore.EG.Kueche2.pos listen on and init with 2/4/64 -- __init__.py:parse_item:244
    2013-12-28 23:45:56,522 DEBUG    Main         KNX: Raffstore.EG.Kueche2.angle listen on 2/4/65 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,527 DEBUG    Main         KNX: Raffstore.EG.Kueche2.angle listen on and init with 2/4/65 -- __init__.py:parse_item:244
    2013-12-28 23:45:56,532 DEBUG    Main         Item Raffstore.EG.Kueche2: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:56,553 DEBUG    Main         KNX: Raffstore.EG.Essen1.pos listen on 2/4/54 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,558 DEBUG    Main         KNX: Raffstore.EG.Essen1.pos listen on and init with 2/4/54 -- __init__.py:parse_item:244
    2013-12-28 23:45:56,571 DEBUG    Main         KNX: Raffstore.EG.Essen1.angle listen on 2/4/55 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,576 DEBUG    Main         KNX: Raffstore.EG.Essen1.angle listen on and init with 2/4/55 -- __init__.py:parse_item:244
    2013-12-28 23:45:56,581 DEBUG    Main         Item Raffstore.EG.Essen1: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:56,605 DEBUG    Main         KNX: Raffstore.EG.Essen2.pos listen on 2/4/44 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,609 DEBUG    Main         KNX: Raffstore.EG.Essen2.pos listen on and init with 2/4/44 -- __init__.py:parse_item:244
    2013-12-28 23:45:56,623 DEBUG    Main         KNX: Raffstore.EG.Essen2.angle listen on 2/4/45 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,628 DEBUG    Main         KNX: Raffstore.EG.Essen2.angle listen on and init with 2/4/45 -- __init__.py:parse_item:244
    2013-12-28 23:45:56,633 DEBUG    Main         Item Raffstore.EG.Essen2: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:56,655 DEBUG    Main         KNX: Raffstore.EG.Wohnen1.pos listen on 2/4/34 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,660 DEBUG    Main         KNX: Raffstore.EG.Wohnen1.pos listen on and init with 2/4/34 -- __init__.py:parse_item:244
    2013-12-28 23:45:56,674 DEBUG    Main         KNX: Raffstore.EG.Wohnen1.angle listen on 2/4/35 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,678 DEBUG    Main         KNX: Raffstore.EG.Wohnen1.angle listen on and init with 2/4/35 -- __init__.py:parse_item:244
    2013-12-28 23:45:56,684 DEBUG    Main         Item Raffstore.EG.Wohnen1: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:56,707 DEBUG    Main         KNX: Raffstore.EG.Wohnen2.pos listen on 2/4/24 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,713 DEBUG    Main         KNX: Raffstore.EG.Wohnen2.pos listen on and init with 2/4/24 -- __init__.py:parse_item:244
    2013-12-28 23:45:56,727 DEBUG    Main         KNX: Raffstore.EG.Wohnen2.angle listen on 2/4/25 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,732 DEBUG    Main         KNX: Raffstore.EG.Wohnen2.angle listen on and init with 2/4/25 -- __init__.py:parse_item:244
    2013-12-28 23:45:56,737 DEBUG    Main         Item Raffstore.EG.Wohnen2: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:56,741 DEBUG    Main         Item Raffstore.EG: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:56,768 DEBUG    Main         KNX: Raffstore.OG.Kind1.pos listen on 3/4/14 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,773 DEBUG    Main         KNX: Raffstore.OG.Kind1.pos listen on and init with 3/4/14 -- __init__.py:parse_item:244
    2013-12-28 23:45:56,787 DEBUG    Main         KNX: Raffstore.OG.Kind1.angle listen on 3/4/15 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,791 DEBUG    Main         KNX: Raffstore.OG.Kind1.angle listen on and init with 3/4/15 -- __init__.py:parse_item:244
    2013-12-28 23:45:56,796 DEBUG    Main         Item Raffstore.OG.Kind1: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:56,819 DEBUG    Main         KNX: Raffstore.OG.Kind2.pos listen on 3/4/24 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,824 DEBUG    Main         KNX: Raffstore.OG.Kind2.pos listen on and init with 3/4/24 -- __init__.py:parse_item:244
    2013-12-28 23:45:56,838 DEBUG    Main         KNX: Raffstore.OG.Kind2.angle listen on 3/4/25 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,843 DEBUG    Main         KNX: Raffstore.OG.Kind2.angle listen on and init with 3/4/25 -- __init__.py:parse_item:244
    2013-12-28 23:45:56,847 DEBUG    Main         Item Raffstore.OG.Kind2: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:56,870 DEBUG    Main         KNX: Raffstore.OG.Eltern.pos listen on 3/4/34 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,875 DEBUG    Main         KNX: Raffstore.OG.Eltern.pos listen on and init with 3/4/34 -- __init__.py:parse_item:244
    2013-12-28 23:45:56,892 DEBUG    Main         KNX: Raffstore.OG.Eltern.angle listen on 3/4/35 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,896 DEBUG    Main         KNX: Raffstore.OG.Eltern.angle listen on and init with 3/4/35 -- __init__.py:parse_item:244
    2013-12-28 23:45:56,901 DEBUG    Main         Item Raffstore.OG.Eltern: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:56,924 DEBUG    Main         KNX: Raffstore.OG.Ankleide.pos listen on 3/4/44 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,928 DEBUG    Main         KNX: Raffstore.OG.Ankleide.pos listen on and init with 3/4/44 -- __init__.py:parse_item:244
    2013-12-28 23:45:56,943 DEBUG    Main         KNX: Raffstore.OG.Ankleide.angle listen on 3/4/45 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,947 DEBUG    Main         KNX: Raffstore.OG.Ankleide.angle listen on and init with 3/4/45 -- __init__.py:parse_item:244
    2013-12-28 23:45:56,952 DEBUG    Main         Item Raffstore.OG.Ankleide: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:56,975 DEBUG    Main         KNX: Raffstore.OG.Bad.pos listen on 3/4/54 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,979 DEBUG    Main         KNX: Raffstore.OG.Bad.pos listen on and init with 3/4/54 -- __init__.py:parse_item:244
    2013-12-28 23:45:56,993 DEBUG    Main         KNX: Raffstore.OG.Bad.angle listen on 3/4/55 -- __init__.py:parse_item:235
    2013-12-28 23:45:56,998 DEBUG    Main         KNX: Raffstore.OG.Bad.angle listen on and init with 3/4/55 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,003 DEBUG    Main         Item Raffstore.OG.Bad: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:57,007 DEBUG    Main         Item Raffstore.OG: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:57,012 DEBUG    Main         Item Raffstore: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:57,091 DEBUG    Main         Item Heizungsanlage.Heizraum: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:57,166 DEBUG    Main         Item Heizungsanlage.Anschlussraum: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:57,172 DEBUG    Main         Item Heizungsanlage: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:57,194 DEBUG    Main         KNX: RTR.KG.Buegelzimmer.actual listen on 1/2/12 -- __init__.py:parse_item:235
    2013-12-28 23:45:57,199 DEBUG    Main         KNX: RTR.KG.Buegelzimmer.actual listen on and init with 1/2/12 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,208 DEBUG    Main         KNX: RTR.KG.Buegelzimmer.set listen on and init with 1/2/16 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,219 DEBUG    Main         KNX: RTR.KG.Buegelzimmer.mode listen on and init with 1/2/17 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,229 DEBUG    Main         KNX: RTR.KG.Buegelzimmer.state listen on 1/2/15 -- __init__.py:parse_item:235
    2013-12-28 23:45:57,233 DEBUG    Main         KNX: RTR.KG.Buegelzimmer.state listen on and init with 1/2/15 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,238 DEBUG    Main         Item RTR.KG.Buegelzimmer: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:57,251 DEBUG    Main         KNX: RTR.KG.Lagerraum.actual listen on 0/5/2 -- __init__.py:parse_item:235
    2013-12-28 23:45:57,256 DEBUG    Main         KNX: RTR.KG.Lagerraum.actual listen on and init with 0/5/2 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,262 DEBUG    Main         Item RTR.KG.Lagerraum: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:57,275 DEBUG    Main         KNX: RTR.KG.Buero.actual listen on 1/2/2 -- __init__.py:parse_item:235
    2013-12-28 23:45:57,279 DEBUG    Main         KNX: RTR.KG.Buero.actual listen on and init with 1/2/2 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,289 DEBUG    Main         KNX: RTR.KG.Buero.set listen on and init with 1/2/6 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,298 DEBUG    Main         KNX: RTR.KG.Buero.mode listen on and init with 1/2/7 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,308 DEBUG    Main         KNX: RTR.KG.Buero.state listen on 1/2/5 -- __init__.py:parse_item:235
    2013-12-28 23:45:57,312 DEBUG    Main         KNX: RTR.KG.Buero.state listen on and init with 1/2/5 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,317 DEBUG    Main         Item RTR.KG.Buero: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:57,322 DEBUG    Main         Item RTR.KG: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:57,339 DEBUG    Main         KNX: RTR.EG.Flur.actual listen on 2/2/2 -- __init__.py:parse_item:235
    2013-12-28 23:45:57,343 DEBUG    Main         KNX: RTR.EG.Flur.actual listen on and init with 2/2/2 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,353 DEBUG    Main         KNX: RTR.EG.Flur.set listen on and init with 2/2/6 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,362 DEBUG    Main         KNX: RTR.EG.Flur.mode listen on and init with 2/2/7 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,372 DEBUG    Main         KNX: RTR.EG.Flur.state listen on 2/2/5 -- __init__.py:parse_item:235
    2013-12-28 23:45:57,376 DEBUG    Main         KNX: RTR.EG.Flur.state listen on and init with 2/2/5 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,381 DEBUG    Main         Item RTR.EG.Flur: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:57,394 DEBUG    Main         KNX: RTR.EG.WC.actual listen on 2/2/12 -- __init__.py:parse_item:235
    2013-12-28 23:45:57,399 DEBUG    Main         KNX: RTR.EG.WC.actual listen on and init with 2/2/12 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,408 DEBUG    Main         KNX: RTR.EG.WC.set listen on and init with 2/2/16 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,418 DEBUG    Main         KNX: RTR.EG.WC.mode listen on and init with 2/2/17 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,427 DEBUG    Main         KNX: RTR.EG.WC.state listen on 2/2/15 -- __init__.py:parse_item:235
    2013-12-28 23:45:57,432 DEBUG    Main         KNX: RTR.EG.WC.state listen on and init with 2/2/15 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,437 DEBUG    Main         Item RTR.EG.WC: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:57,452 DEBUG    Main         KNX: RTR.EG.Speiss.actual listen on 0/5/6 -- __init__.py:parse_item:235
    2013-12-28 23:45:57,457 DEBUG    Main         KNX: RTR.EG.Speiss.actual listen on and init with 0/5/6 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,462 DEBUG    Main         Item RTR.EG.Speiss: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:57,475 DEBUG    Main         KNX: RTR.EG.KochenEssenWohnen.actual listen on 2/2/22 -- __init__.py:parse_item:235
    2013-12-28 23:45:57,479 DEBUG    Main         KNX: RTR.EG.KochenEssenWohnen.actual listen on and init with 2/2/22 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,489 DEBUG    Main         KNX: RTR.EG.KochenEssenWohnen.set listen on and init with 2/2/26 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,498 DEBUG    Main         KNX: RTR.EG.KochenEssenWohnen.mode listen on and init with 2/2/27 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,508 DEBUG    Main         KNX: RTR.EG.KochenEssenWohnen.state listen on 2/2/25 -- __init__.py:parse_item:235
    2013-12-28 23:45:57,513 DEBUG    Main         KNX: RTR.EG.KochenEssenWohnen.state listen on and init with 2/2/25 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,518 DEBUG    Main         Item RTR.EG.KochenEssenWohnen: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:57,522 DEBUG    Main         Item RTR.EG: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:57,539 DEBUG    Main         KNX: RTR.OG.Kind1.actual listen on 3/2/11 -- __init__.py:parse_item:235
    2013-12-28 23:45:57,544 DEBUG    Main         KNX: RTR.OG.Kind1.actual listen on and init with 3/2/11 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,553 DEBUG    Main         KNX: RTR.OG.Kind1.set listen on and init with 3/2/15 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,563 DEBUG    Main         KNX: RTR.OG.Kind1.mode listen on and init with 3/2/16 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,573 DEBUG    Main         KNX: RTR.OG.Kind1.state listen on 3/2/14 -- __init__.py:parse_item:235
    2013-12-28 23:45:57,577 DEBUG    Main         KNX: RTR.OG.Kind1.state listen on and init with 3/2/14 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,582 DEBUG    Main         Item RTR.OG.Kind1: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:57,595 DEBUG    Main         KNX: RTR.OG.Kind2.actual listen on 3/2/21 -- __init__.py:parse_item:235
    2013-12-28 23:45:57,600 DEBUG    Main         KNX: RTR.OG.Kind2.actual listen on and init with 3/2/21 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,609 DEBUG    Main         KNX: RTR.OG.Kind2.set listen on and init with 3/2/25 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,619 DEBUG    Main         KNX: RTR.OG.Kind2.mode listen on and init with 3/2/26 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,628 DEBUG    Main         KNX: RTR.OG.Kind2.state listen on 3/2/24 -- __init__.py:parse_item:235
    2013-12-28 23:45:57,633 DEBUG    Main         KNX: RTR.OG.Kind2.state listen on and init with 3/2/24 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,638 DEBUG    Main         Item RTR.OG.Kind2: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:57,651 DEBUG    Main         KNX: RTR.OG.Eltern.actual listen on 3/2/31 -- __init__.py:parse_item:235
    2013-12-28 23:45:57,655 DEBUG    Main         KNX: RTR.OG.Eltern.actual listen on and init with 3/2/31 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,665 DEBUG    Main         KNX: RTR.OG.Eltern.set listen on and init with 3/2/35 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,674 DEBUG    Main         KNX: RTR.OG.Eltern.mode listen on and init with 3/2/36 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,684 DEBUG    Main         KNX: RTR.OG.Eltern.state listen on 3/2/34 -- __init__.py:parse_item:235
    2013-12-28 23:45:57,688 DEBUG    Main         KNX: RTR.OG.Eltern.state listen on and init with 3/2/34 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,693 DEBUG    Main         Item RTR.OG.Eltern: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:57,706 DEBUG    Main         KNX: RTR.OG.Ankleide.actual listen on 3/2/41 -- __init__.py:parse_item:235
    2013-12-28 23:45:57,711 DEBUG    Main         KNX: RTR.OG.Ankleide.actual listen on and init with 3/2/41 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,722 DEBUG    Main         KNX: RTR.OG.Ankleide.set listen on and init with 3/2/45 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,732 DEBUG    Main         KNX: RTR.OG.Ankleide.mode listen on and init with 3/2/46 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,741 DEBUG    Main         KNX: RTR.OG.Ankleide.state listen on 3/2/44 -- __init__.py:parse_item:235
    2013-12-28 23:45:57,746 DEBUG    Main         KNX: RTR.OG.Ankleide.state listen on and init with 3/2/44 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,751 DEBUG    Main         Item RTR.OG.Ankleide: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:57,764 DEBUG    Main         KNX: RTR.OG.Bad.actual listen on 3/2/51 -- __init__.py:parse_item:235
    2013-12-28 23:45:57,768 DEBUG    Main         KNX: RTR.OG.Bad.actual listen on and init with 3/2/51 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,778 DEBUG    Main         KNX: RTR.OG.Bad.set listen on and init with 3/2/55 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,787 DEBUG    Main         KNX: RTR.OG.Bad.mode listen on and init with 3/2/56 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,798 DEBUG    Main         KNX: RTR.OG.Bad.state listen on 3/2/54 -- __init__.py:parse_item:235
    2013-12-28 23:45:57,803 DEBUG    Main         KNX: RTR.OG.Bad.state listen on and init with 3/2/54 -- __init__.py:parse_item:244
    2013-12-28 23:45:57,808 DEBUG    Main         Item RTR.OG.Bad: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:57,812 DEBUG    Main         Item RTR.OG: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:57,817 DEBUG    Main         Item RTR: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:57,830 DEBUG    Main         KNX: Sicherheitsfunktionen.Feueralarm listen on 0/3/1 -- __init__.py:parse_item:235
    2013-12-28 23:45:57,840 DEBUG    Main         KNX: Sicherheitsfunktionen.Windalarm listen on 0/3/2 -- __init__.py:parse_item:235
    2013-12-28 23:45:57,847 DEBUG    Main         Item Sicherheitsfunktionen: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:57,870 DEBUG    Main         Item Zentralfunktionen.Beschattung: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:57,875 DEBUG    Main         Item Zentralfunktionen: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:57,898 DEBUG    Main         KNX: Aussenbereich.Temp reply to 0/4/3 -- __init__.py:parse_item:267
    2013-12-28 23:45:57,906 DEBUG    Main         Item Aussenbereich: no type specified. -- item.py:__init__:242
    2013-12-28 23:45:57,984 DEBUG    Main         Triggering Heizungsanlage.Anschlussraum.AVGAnschlussraum - by: Init source: None dest: None value: {'caller': 'Init', 'value': 0} -- scheduler.py:trigger:162
    2013-12-28 23:45:57,989 DEBUG    Main         Triggering Heizungsanlage.Anschlussraum.AVGHeizraum - by: Init source: None dest: None value: {'caller': 'Init', 'value': 0} -- scheduler.py:trigger:162
    2013-12-28 23:45:57,998 DEBUG    Main         Triggering Aussenbereich.Temp.min - by: Init source: None dest: None value: {'caller': 'Init', 'value': 0} -- scheduler.py:trigger:162
    2013-12-28 23:45:58,005 DEBUG    Main         Triggering Aussenbereich.Temp.max - by: Init source: None dest: None value: {'caller': 'Init', 'value': 0} -- scheduler.py:trigger:162
    2013-12-28 23:45:58,030 INFO     Main         Start Plugins -- plugin.py:start:65
    2013-12-28 23:45:58,045 DEBUG    ow           1w-disc next time: 2013-12-28 23:46:00+01:00 -- scheduler.py:_next_time:289
    2013-12-28 23:45:58,161 DEBUG    rrd          RRDtool next time: 2013-12-28 23:47:38+01:00 -- scheduler.py:_next_time:289
    2013-12-28 23:45:58,164 INFO     Main         Start Logics -- logic.py:__init__:33
    2013-12-28 23:45:58,194 DEBUG    Main         Reading Logics from /usr/smarthome/lib/env/logic_conf -- logic.py:_read_logics:64
    2013-12-28 23:45:58,179 DEBUG    Aussenbereich.Temp.max Item Aussenbereich.Temp.max = 7.0 via Init None None -- item.py:__update:363
    2013-12-28 23:45:58,266 DEBUG    Main         Reading Logics from /usr/smarthome/etc/logic.conf -- logic.py:_read_logics:64
    2013-12-28 23:45:58,305 DEBUG    Main         Logic: Feueralarm -- logic.py:__init__:44
    2013-12-28 23:45:58,398 DEBUG    Connections  KNX: connected to 127.0.0.1:6720 -- connection.py:connect:386
    2013-12-28 23:45:58,408 DEBUG    Connections  KNX: enable group monitor -- __init__.py:handle_connect:117
    2013-12-28 23:45:58,413 DEBUG    Connections  KNX: init read -- __init__.py:handle_connect:123
    2013-12-28 23:45:58,404 DEBUG    Main         Logic: env_stat -- logic.py:__init__:44
    2013-12-28 23:45:58,442 DEBUG    Main         env_stat next time: 2013-12-28 23:46:10+01:00 -- scheduler.py:_next_time:289
    2013-12-28 23:45:58,453 DEBUG    Main         Logic: Windalarm -- logic.py:__init__:44
    2013-12-28 23:45:58,483 DEBUG    Main         Logic: FBH -- logic.py:__init__:44
    2013-12-28 23:45:58,509 DEBUG    Main         Logic: env_init -- logic.py:__init__:44
    2013-12-28 23:45:58,511 INFO     Connections  1-Wire: connected to 127.0.0.1:4304 -- __init__.py:connect:66
    2013-12-28 23:45:58,524 DEBUG    Connections  CLI: binding to 0.0.0.0:2323 (TCP) -- connection.py:connect:161
    2013-12-28 23:45:58,533 DEBUG    Main         Logic: env_loc -- logic.py:__init__:44
    2013-12-28 23:45:58,539 DEBUG    Connections  WebSocket: binding to 0.0.0.0:2424 (TCP) -- connection.py:connect:161
    2013-12-28 23:45:58,600 DEBUG    Main         KNX: 1.1.3 read 2/4/14 -- __init__.py:parse_telegram:203
    2013-12-28 23:45:58,612 DEBUG    Main         knx: 1.1.103 set 2/4/14 to 255 -- __init__.py:parse_telegram:190
    2013-12-28 23:45:58,617 DEBUG    Main         Item Raffstore.EG.WC.pos = 255 via KNX 1.1.103 2/4/14 -- item.py:__update:363
    2013-12-28 23:45:58,685 DEBUG    Main         KNX: 1.1.3 read 2/4/15 -- __init__.py:parse_telegram:203
    2013-12-28 23:45:58,707 DEBUG    Main         knx: 1.1.103 set 2/4/15 to 255 -- __init__.py:parse_telegram:190
    2013-12-28 23:45:58,713 DEBUG    Main         Item Raffstore.EG.WC.angle = 255 via KNX 1.1.103 2/4/15 -- item.py:__update:363
    2013-12-28 23:45:58,781 DEBUG    Main         KNX: 1.1.3 read 2/4/74 -- __init__.py:parse_telegram:203
    2013-12-28 23:45:58,804 DEBUG    Main         knx: 1.1.102 set 2/4/74 to 255 -- __init__.py:parse_telegram:190
    2013-12-28 23:45:58,810 DEBUG    Main         Item Raffstore.EG.Kueche1.pos = 255 via KNX 1.1.102 2/4/74 -- item.py:__update:363
    2013-12-28 23:45:58,878 DEBUG    Main         KNX: 1.1.3 read 2/4/75 -- __init__.py:parse_telegram:203
    2013-12-28 23:45:58,901 DEBUG    Main         knx: 1.1.102 set 2/4/75 to 255 -- __init__.py:parse_telegram:190
    2013-12-28 23:45:58,907 DEBUG    Main         Item Raffstore.EG.Kueche1.angle = 255 via KNX 1.1.102 2/4/75 -- item.py:__update:363
    2013-12-28 23:45:58,976 DEBUG    Main         KNX: 1.1.3 read 2/4/64 -- __init__.py:parse_telegram:203
    2013-12-28 23:45:58,999 DEBUG    Main         knx: 1.1.102 set 2/4/64 to 255 -- __init__.py:parse_telegram:190
    2013-12-28 23:45:59,005 DEBUG    Main         Item Raffstore.EG.Kueche2.pos = 255 via KNX 1.1.102 2/4/64 -- item.py:__update:363
    2013-12-28 23:45:59,073 DEBUG    Main         KNX: 1.1.3 read 2/4/65 -- __init__.py:parse_telegram:203
    2013-12-28 23:45:59,094 DEBUG    Main         knx: 1.1.102 set 2/4/65 to 255 -- __init__.py:parse_telegram:190
    2013-12-28 23:45:59,100 DEBUG    Main         Item Raffstore.EG.Kueche2.angle = 255 via KNX 1.1.102 2/4/65 -- item.py:__update:363
    2013-12-28 23:45:59,169 DEBUG    Main         KNX: 1.1.3 read 2/4/54 -- __init__.py:parse_telegram:203
    2013-12-28 23:45:59,190 DEBUG    Main         knx: 1.1.102 set 2/4/54 to 255 -- __init__.py:parse_telegram:190
    2013-12-28 23:45:59,203 DEBUG    Main         Item Raffstore.EG.Essen1.pos = 255 via KNX 1.1.102 2/4/54 -- item.py:__update:363
    2013-12-28 23:45:59,264 DEBUG    Main         KNX: 1.1.3 read 2/4/55 -- __init__.py:parse_telegram:203
    2013-12-28 23:45:59,285 DEBUG    Main         knx: 1.1.102 set 2/4/55 to 255 -- __init__.py:parse_telegram:190
    2013-12-28 23:45:59,291 DEBUG    Main         Item Raffstore.EG.Essen1.angle = 255 via KNX 1.1.102 2/4/55 -- item.py:__update:363
    2013-12-28 23:45:59,360 DEBUG    Main         KNX: 1.1.3 read 2/4/44 -- __init__.py:parse_telegram:203
    2013-12-28 23:45:59,382 DEBUG    Main         knx: 1.1.103 set 2/4/44 to 255 -- __init__.py:parse_telegram:190
    2013-12-28 23:45:59,388 DEBUG    Main         Item Raffstore.EG.Essen2.pos = 255 via KNX 1.1.103 2/4/44 -- item.py:__update:363
    2013-12-28 23:45:59,457 DEBUG    Main         KNX: 1.1.3 read 2/4/45 -- __init__.py:parse_telegram:203
    2013-12-28 23:45:59,480 DEBUG    Main         knx: 1.1.103 set 2/4/45 to 255 -- __init__.py:parse_telegram:190
    2013-12-28 23:45:59,486 DEBUG    Main         Item Raffstore.EG.Essen2.angle = 255 via KNX 1.1.103 2/4/45 -- item.py:__update:363
    2013-12-28 23:45:59,554 DEBUG    Main         KNX: 1.1.3 read 2/4/34 -- __init__.py:parse_telegram:203
    2013-12-28 23:45:59,578 DEBUG    Main         knx: 1.1.103 set 2/4/34 to 255 -- __init__.py:parse_telegram:190
    2013-12-28 23:45:59,584 DEBUG    Main         Item Raffstore.EG.Wohnen1.pos = 255 via KNX 1.1.103 2/4/34 -- item.py:__update:363
    2013-12-28 23:45:59,652 DEBUG    Main         KNX: 1.1.3 read 2/4/35 -- __init__.py:parse_telegram:203
    2013-12-28 23:45:59,676 DEBUG    Main         knx: 1.1.103 set 2/4/35 to 255 -- __init__.py:parse_telegram:190
    2013-12-28 23:45:59,683 DEBUG    Main         Item Raffstore.EG.Wohnen1.angle = 255 via KNX 1.1.103 2/4/35 -- item.py:__update:363
    2013-12-28 23:45:59,750 DEBUG    Main         KNX: 1.1.3 read 2/4/24 -- __init__.py:parse_telegram:203
    2013-12-28 23:45:59,773 DEBUG    Main         knx: 1.1.103 set 2/4/24 to 255 -- __init__.py:parse_telegram:190
    2013-12-28 23:45:59,779 DEBUG    Main         Item Raffstore.EG.Wohnen2.pos = 255 via KNX 1.1.103 2/4/24 -- item.py:__update:363
    2013-12-28 23:45:59,848 DEBUG    Main         KNX: 1.1.3 read 2/4/25 -- __init__.py:parse_telegram:203
    2013-12-28 23:45:59,871 DEBUG    Main         knx: 1.1.103 set 2/4/25 to 255 -- __init__.py:parse_telegram:190
    2013-12-28 23:45:59,877 DEBUG    Main         Item Raffstore.EG.Wohnen2.angle = 255 via KNX 1.1.103 2/4/25 -- item.py:__update:363
    2013-12-28 23:45:59,945 DEBUG    Main         KNX: 1.1.3 read 3/4/14 -- __init__.py:parse_telegram:203
    2013-12-28 23:45:59,967 DEBUG    Main         knx: 1.1.101 set 3/4/14 to 255 -- __init__.py:parse_telegram:190
    2013-12-28 23:45:59,973 DEBUG    Main         Item Raffstore.OG.Kind1.pos = 255 via KNX 1.1.101 3/4/14 -- item.py:__update:363
    2013-12-28 23:46:00,042 DEBUG    Main         KNX: 1.1.3 read 3/4/15 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:00,065 DEBUG    Main         knx: 1.1.101 set 3/4/15 to 255 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:00,071 DEBUG    Main         Item Raffstore.OG.Kind1.angle = 255 via KNX 1.1.101 3/4/15 -- item.py:__update:363
    2013-12-28 23:46:00,139 DEBUG    Main         KNX: 1.1.3 read 3/4/24 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:00,163 DEBUG    Main         knx: 1.1.101 set 3/4/24 to 255 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:00,168 DEBUG    Main         Item Raffstore.OG.Kind2.pos = 255 via KNX 1.1.101 3/4/24 -- item.py:__update:363
    2013-12-28 23:46:00,237 DEBUG    Main         KNX: 1.1.3 read 3/4/25 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:00,262 DEBUG    Main         knx: 1.1.101 set 3/4/25 to 255 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:00,273 DEBUG    Main         Item Raffstore.OG.Kind2.angle = 255 via KNX 1.1.101 3/4/25 -- item.py:__update:363
    2013-12-28 23:46:00,335 DEBUG    Main         KNX: 1.1.3 read 3/4/34 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:00,358 DEBUG    Main         knx: 1.1.101 set 3/4/34 to 255 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:00,367 DEBUG    Main         Item Raffstore.OG.Eltern.pos = 255 via KNX 1.1.101 3/4/34 -- item.py:__update:363
    2013-12-28 23:46:00,433 DEBUG    Main         KNX: 1.1.3 read 3/4/35 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:00,454 DEBUG    Main         knx: 1.1.101 set 3/4/35 to 255 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:00,463 DEBUG    Main         Item Raffstore.OG.Eltern.angle = 255 via KNX 1.1.101 3/4/35 -- item.py:__update:363
    2013-12-28 23:46:00,528 DEBUG    Main         KNX: 1.1.3 read 3/4/44 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:00,549 DEBUG    Main         knx: 1.1.101 set 3/4/44 to 255 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:00,558 DEBUG    Main         Item Raffstore.OG.Ankleide.pos = 255 via KNX 1.1.101 3/4/44 -- item.py:__update:363
    2013-12-28 23:46:00,623 DEBUG    Main         KNX: 1.1.3 read 3/4/45 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:00,644 DEBUG    Main         knx: 1.1.101 set 3/4/45 to 255 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:00,654 DEBUG    Main         Item Raffstore.OG.Ankleide.angle = 255 via KNX 1.1.101 3/4/45 -- item.py:__update:363
    2013-12-28 23:46:00,719 DEBUG    Main         KNX: 1.1.3 read 3/4/54 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:00,742 DEBUG    Main         knx: 1.1.102 set 3/4/54 to 255 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:00,754 DEBUG    Scheduler    1w-disc next time: 2013-12-28 23:56:00+01:00 -- scheduler.py:_next_time:289
    2013-12-28 23:46:00,762 DEBUG    Main         Item Raffstore.OG.Bad.pos = 255 via KNX 1.1.102 3/4/54 -- item.py:__update:363
    2013-12-28 23:46:00,816 DEBUG    Main         KNX: 1.1.3 read 3/4/55 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:00,839 DEBUG    Main         knx: 1.1.102 set 3/4/55 to 255 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:00,848 DEBUG    Main         Item Raffstore.OG.Bad.angle = 255 via KNX 1.1.102 3/4/55 -- item.py:__update:363
    2013-12-28 23:46:00,914 DEBUG    Main         KNX: 1.1.3 read 1/2/12 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:00,941 DEBUG    Main         KNX: 1.1.3 read 1/2/16 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:00,964 DEBUG    Main         knx: 1.1.12 set 1/2/12 to 17.31 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:00,973 DEBUG    Main         Item RTR.KG.Buegelzimmer.actual = 17.31 via KNX 1.1.12 1/2/12 -- item.py:__update:363
    2013-12-28 23:46:01,013 INFO     1w-disc      1-Wire: 28.401BC7040000 with sensors: T11, T10, T, T12, T9 -- __init__.py:_discovery:431
    2013-12-28 23:46:01,020 INFO     1w-disc      1-Wire: 28.A03CC6040000 with sensors: T11, T10, T, T12, T9 -- __init__.py:_discovery:431
    2013-12-28 23:46:01,028 INFO     1w-disc      1-Wire: 28.A83BC6040000 with sensors: T11, T10, T, T12, T9 -- __init__.py:_discovery:431
    2013-12-28 23:46:01,036 INFO     1w-disc      1-Wire: 28.682AC6040000 with sensors: T11, T10, T, T12, T9 -- __init__.py:_discovery:431
    2013-12-28 23:46:01,042 DEBUG    Main         KNX: 1.1.3 read 1/2/17 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:01,053 INFO     1w-disc      1-Wire: 28.448C80040000 with sensors: T11, T10, T, T12, T9 -- __init__.py:_discovery:431
    2013-12-28 23:46:01,061 INFO     1w-disc      1-Wire: 28.DC74C6040000 with sensors: T11, T10, T, T12, T9 -- __init__.py:_discovery:431
    2013-12-28 23:46:01,065 DEBUG    Main         knx: 1.1.12 set 1/2/16 to 18.0 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:01,075 DEBUG    Main         Item RTR.KG.Buegelzimmer.set = 18.0 via KNX 1.1.12 1/2/16 -- item.py:__update:363
    2013-12-28 23:46:01,080 INFO     1w-disc      1-Wire: 28.229CC6040000 with sensors: T11, T10, T, T12, T9 -- __init__.py:_discovery:431
    2013-12-28 23:46:01,093 INFO     1w-disc      1-Wire: 28.6A8E7F040000 with sensors: T11, T10, T, T12, T9 -- __init__.py:_discovery:431
    2013-12-28 23:46:01,101 INFO     1w-disc      1-Wire: 28.7A1080040000 with sensors: T11, T10, T, T12, T9 -- __init__.py:_discovery:431
    2013-12-28 23:46:01,109 INFO     1w-disc      1-Wire: 28.4E737F040000 with sensors: T11, T10, T, T12, T9 -- __init__.py:_discovery:431
    2013-12-28 23:46:01,117 INFO     1w-disc      1-Wire: 28.9136C6040000 with sensors: T11, T10, T, T12, T9 -- __init__.py:_discovery:431
    2013-12-28 23:46:01,125 INFO     1w-disc      1-Wire: 28.3900C7040000 with sensors: T11, T10, T, T12, T9 -- __init__.py:_discovery:431
    2013-12-28 23:46:01,132 INFO     1w-disc      1-Wire: 28.F97B80040000 with sensors: T11, T10, T, T12, T9 -- __init__.py:_discovery:431
    2013-12-28 23:46:01,143 DEBUG    Main         KNX: 1.1.3 read 1/2/15 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:01,148 INFO     1w-disc      1-Wire: 28.A36F7F040000 with sensors: T11, T10, T, T12, T9 -- __init__.py:_discovery:431
    2013-12-28 23:46:01,156 INFO     1w-disc      1-Wire: 28.0BD1C6040000 with sensors: T11, T10, T, T12, T9 -- __init__.py:_discovery:431
    2013-12-28 23:46:01,164 DEBUG    Main         knx: 1.1.12 set 1/2/17 to 3 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:01,170 DEBUG    Main         Item RTR.KG.Buegelzimmer.mode = 3 via KNX 1.1.12 1/2/17 -- item.py:__update:363
    2013-12-28 23:46:01,174 INFO     1w-disc      1-Wire: 28.57737F040000 with sensors: T11, T10, T, T12, T9 -- __init__.py:_discovery:431
    2013-12-28 23:46:01,188 INFO     1w-disc      1-Wire: 28.CF3CC6040000 with sensors: T11, T10, T, T12, T9 -- __init__.py:_discovery:431
    2013-12-28 23:46:01,196 INFO     1w-disc      1-Wire: 28.5F1E80040000 with sensors: T11, T10, T, T12, T9 -- __init__.py:_discovery:431
    2013-12-28 23:46:01,204 INFO     1w-disc      1-Wire: 81.584832000000 with sensors: BM -- __init__.py:_discovery:431
    2013-12-28 23:46:01,238 DEBUG    Main         KNX: 1.1.3 read 0/5/2 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:01,257 DEBUG    Main         knx: 1.1.12 set 1/2/15 to 1 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:01,263 DEBUG    Main         Item RTR.KG.Buegelzimmer.state = 1 via KNX 1.1.12 1/2/15 -- item.py:__update:363
    2013-12-28 23:46:01,327 DEBUG    Main         KNX: 1.1.3 read 1/2/2 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:01,350 DEBUG    Main         knx: 1.1.11 set 0/5/2 to 16.75 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:01,356 DEBUG    Main         Item RTR.KG.Lagerraum.actual = 16.75 via KNX 1.1.11 0/5/2 -- item.py:__update:363
    2013-12-28 23:46:01,428 DEBUG    Main         KNX: 1.1.3 read 1/2/6 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:01,451 DEBUG    Main         knx: 1.1.10 set 1/2/2 to 17.27 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:01,457 DEBUG    Main         Item RTR.KG.Buero.actual = 17.27 via KNX 1.1.10 1/2/2 -- item.py:__update:363
    2013-12-28 23:46:01,529 DEBUG    Main         KNX: 1.1.3 read 1/2/7 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:01,552 DEBUG    Main         knx: 1.1.10 set 1/2/6 to 18.0 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:01,557 DEBUG    Main         Item RTR.KG.Buero.set = 18.0 via KNX 1.1.10 1/2/6 -- item.py:__update:363
    2013-12-28 23:46:01,586 DEBUG    ow           1w-sen next time: 2013-12-28 23:46:01+01:00 -- scheduler.py:_next_time:289
    2013-12-28 23:46:01,629 DEBUG    Main         KNX: 1.1.3 read 1/2/5 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:01,651 DEBUG    Main         knx: 1.1.10 set 1/2/7 to 3 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:01,656 DEBUG    Main         Item RTR.KG.Buero.mode = 3 via KNX 1.1.10 1/2/7 -- item.py:__update:363
    2013-12-28 23:46:01,725 DEBUG    Main         KNX: 1.1.3 read 2/2/2 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:01,745 DEBUG    Main         knx: 1.1.10 set 1/2/5 to 1 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:01,750 DEBUG    Main         Item RTR.KG.Buero.state = 1 via KNX 1.1.10 1/2/5 -- item.py:__update:363
    2013-12-28 23:46:01,815 DEBUG    Main         KNX: 1.1.3 read 2/2/6 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:01,839 DEBUG    Main         knx: 1.1.30 set 2/2/2 to 17.92 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:01,845 DEBUG    Main         Item RTR.EG.Flur.actual = 17.92 via KNX 1.1.30 2/2/2 -- item.py:__update:363
    2013-12-28 23:46:01,915 DEBUG    Main         KNX: 1.1.3 read 2/2/7 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:01,938 DEBUG    Main         knx: 1.1.30 set 2/2/6 to 18.0 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:01,945 DEBUG    Main         Item RTR.EG.Flur.set = 18.0 via KNX 1.1.30 2/2/6 -- item.py:__update:363
    2013-12-28 23:46:02,016 DEBUG    Main         KNX: 1.1.3 read 2/2/5 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:02,037 DEBUG    Main         knx: 1.1.30 set 2/2/7 to 3 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:02,043 DEBUG    Main         Item RTR.EG.Flur.mode = 3 via KNX 1.1.30 2/2/7 -- item.py:__update:363
    2013-12-28 23:46:02,111 DEBUG    Main         KNX: 1.1.3 read 2/2/12 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:02,131 DEBUG    Main         knx: 1.1.30 set 2/2/5 to 1 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:02,137 DEBUG    Main         Item RTR.EG.Flur.state = 1 via KNX 1.1.30 2/2/5 -- item.py:__update:363
    2013-12-28 23:46:02,206 DEBUG    Main         knx: 1.1.31 set 2/2/12 to 18.0 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:02,212 DEBUG    Main         Item RTR.EG.WC.actual = 18.0 via KNX 1.1.31 2/2/12 -- item.py:__update:363
    2013-12-28 23:46:02,282 DEBUG    Scheduler    1w-sen next time: 2013-12-28 23:47:02+01:00 -- scheduler.py:_next_time:289
    2013-12-28 23:46:02,286 DEBUG    Main         KNX: 1.1.3 read 2/2/16 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:02,314 DEBUG    Main         KNX: 1.1.3 read 2/2/17 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:02,341 DEBUG    Main         KNX: 1.1.3 read 2/2/15 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:02,369 DEBUG    Main         KNX: 1.1.3 read 0/5/6 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:02,391 DEBUG    Main         knx: 1.1.31 set 2/2/16 to 18.0 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:02,397 DEBUG    Main         Item RTR.EG.WC.set = 18.0 via KNX 1.1.31 2/2/16 -- item.py:__update:363
    2013-12-28 23:46:02,469 DEBUG    Main         KNX: 1.1.3 read 2/2/22 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:02,492 DEBUG    Main         knx: 1.1.31 set 2/2/17 to 3 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:02,496 DEBUG    1w-sen       Item Heizungsanlage.Heizraum.T4 = 58.6875 via 1-Wire /bus.0/28.3900C7040000/temperature None -- item.py:__update:363
    2013-12-28 23:46:02,501 DEBUG    Main         Item RTR.EG.WC.mode = 3 via KNX 1.1.31 2/2/17 -- item.py:__update:363
    2013-12-28 23:46:02,566 DEBUG    Main         KNX: 1.1.3 read 2/2/26 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:02,587 DEBUG    Main         knx: 1.1.38 set 2/2/22 to 21.96 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:02,593 DEBUG    Main         Item RTR.EG.KochenEssenWohnen.actual = 21.96 via KNX 1.1.38 2/2/22 -- item.py:__update:363
    2013-12-28 23:46:02,665 DEBUG    Main         KNX: 1.1.3 read 2/2/27 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:02,688 DEBUG    Main         knx: 1.1.38 set 2/2/26 to 19.0 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:02,694 DEBUG    Main         Item RTR.EG.KochenEssenWohnen.set = 19.0 via KNX 1.1.38 2/2/26 -- item.py:__update:363
    2013-12-28 23:46:02,766 DEBUG    Main         KNX: 1.1.3 read 2/2/25 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:02,785 DEBUG    Main         knx: 1.1.31 set 2/2/15 to 0 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:02,855 DEBUG    Main         KNX: 1.1.3 read 3/2/11 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:02,878 DEBUG    Main         knx: 1.1.35 set 0/5/6 to 18.69 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:02,884 DEBUG    Main         Item RTR.EG.Speiss.actual = 18.69 via KNX 1.1.35 0/5/6 -- item.py:__update:363
    2013-12-28 23:46:02,956 DEBUG    Main         KNX: 1.1.3 read 3/2/15 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:02,977 DEBUG    Main         knx: 1.1.38 set 2/2/27 to 2 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:02,983 DEBUG    Main         Item RTR.EG.KochenEssenWohnen.mode = 2 via KNX 1.1.38 2/2/27 -- item.py:__update:363
    2013-12-28 23:46:03,051 DEBUG    Main         KNX: 1.1.3 read 3/2/16 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:03,074 DEBUG    Main         knx: 1.1.51 set 3/2/11 to 18.41 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:03,080 DEBUG    Main         Item RTR.OG.Kind1.actual = 18.41 via KNX 1.1.51 3/2/11 -- item.py:__update:363
    2013-12-28 23:46:03,152 DEBUG    Main         KNX: 1.1.3 read 3/2/14 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:03,172 DEBUG    Main         knx: 1.1.38 set 2/2/25 to 0 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:03,189 DEBUG    1w-sen       Item Heizungsanlage.Heizraum.T5 = 33.8125 via 1-Wire /bus.0/28.0BD1C6040000/temperature None -- item.py:__update:363
    2013-12-28 23:46:03,242 DEBUG    Main         KNX: 1.1.3 read 3/2/21 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:03,264 DEBUG    Main         knx: 1.1.51 set 3/2/15 to 18.0 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:03,270 DEBUG    Main         Item RTR.OG.Kind1.set = 18.0 via KNX 1.1.51 3/2/15 -- item.py:__update:363
    2013-12-28 23:46:03,346 DEBUG    Main         knx: 1.1.52 set 3/2/21 to 18.53 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:03,352 DEBUG    Main         Item RTR.OG.Kind2.actual = 18.53 via KNX 1.1.52 3/2/21 -- item.py:__update:363
    2013-12-28 23:46:03,423 DEBUG    Main         KNX: 1.1.3 read 3/2/25 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:03,444 DEBUG    Main         knx: 1.1.51 set 3/2/16 to 3 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:03,450 DEBUG    Main         Item RTR.OG.Kind1.mode = 3 via KNX 1.1.51 3/2/16 -- item.py:__update:363
    2013-12-28 23:46:03,518 DEBUG    Main         KNX: 1.1.3 read 3/2/26 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:03,541 DEBUG    Main         knx: 1.1.52 set 3/2/25 to 18.0 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:03,547 DEBUG    Main         Item RTR.OG.Kind2.set = 18.0 via KNX 1.1.52 3/2/25 -- item.py:__update:363
    2013-12-28 23:46:03,619 DEBUG    Main         KNX: 1.1.3 read 3/2/24 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:03,639 DEBUG    Main         knx: 1.1.51 set 3/2/14 to 0 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:03,709 DEBUG    Main         KNX: 1.1.3 read 3/2/31 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:03,730 DEBUG    Main         knx: 1.1.52 set 3/2/26 to 3 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:03,737 DEBUG    Main         Item RTR.OG.Kind2.mode = 3 via KNX 1.1.52 3/2/26 -- item.py:__update:363
    2013-12-28 23:46:03,809 DEBUG    Main         KNX: 1.1.3 read 3/2/35 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:03,914 DEBUG    1w-sen       Item Heizungsanlage.Anschlussraum.PufferMitte = 41.3125 via 1-Wire /bus.0/28.A83BC6040000/temperature None -- item.py:__update:363
    2013-12-28 23:46:03,925 DEBUG    sh.gc        Garbage collector: collected 0 objects. -- smarthome.py:_garbage_collection:498
    2013-12-28 23:46:03,942 DEBUG    1w-sen       Triggering Heizungsanlage.Anschlussraum.AVGAnschlussraum - by: 1-Wire source: /bus.0/28.A83BC6040000/temperature dest: None value: {'source': 'Heizungsanlage.Anschlussraum -- scheduler.py:trigger:162
    2013-12-28 23:46:03,931 DEBUG    env_init     Item env.core.version = 1.0-21-g7f162e6 via Logic None None -- item.py:__update:363
    2013-12-28 23:46:03,934 DEBUG    Main         knx: 1.1.53 set 3/2/31 to 18.41 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:03,985 DEBUG    Main         Item RTR.OG.Eltern.actual = 18.41 via KNX 1.1.53 3/2/31 -- item.py:__update:363
    2013-12-28 23:46:03,954 DEBUG    env_loc      Item env.location.sunrise = 2013-12-29 08:09:05.717715+01:00 via Logic None None -- item.py:__update:363
    2013-12-28 23:46:03,982 DEBUG    env_init     Item env.core.start = 2013-12-28 23:46:03.979036+01:00 via Logic None None -- item.py:__update:363
    2013-12-28 23:46:04,013 DEBUG    Heizungsanlage.Anschlussraum.AVGAnschlussraum Item Heizungsanlage.Anschlussraum.AVGAnschlussraum = 13.770833333333334 via Eval Heizungsanlage.Anschlussraum.PufferMitte None -- item.py:__update:363
    2013-12-28 23:46:04,021 DEBUG    Main         KNX: 1.1.3 read 3/2/36 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:04,070 DEBUG    Main         knx: 1.1.52 set 3/2/24 to 0 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:04,089 DEBUG    env_init     Item env.system.name = smarthome.local via Logic None None -- item.py:__update:363
    2013-12-28 23:46:04,113 DEBUG    Main         knx: 1.1.53 set 3/2/35 to 18.0 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:04,147 DEBUG    Main         Item RTR.OG.Eltern.set = 18.0 via KNX 1.1.53 3/2/35 -- item.py:__update:363
    2013-12-28 23:46:04,110 DEBUG    env_loc      Item env.location.sunset = 2013-12-29 16:25:31.631757+01:00 via Logic None None -- item.py:__update:363
    2013-12-28 23:46:04,143 DEBUG    env_init     Item env.system.start = 2013-12-28 19:20:02.138744+01:00 via Logic None None -- item.py:__update:363
    2013-12-28 23:46:04,169 DEBUG    Main         KNX: 1.1.3 read 3/2/34 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:04,252 DEBUG    env_loc      Item env.location.moonrise = 2013-12-29 04:24:19.433756+01:00 via Logic None None -- item.py:__update:363
    2013-12-28 23:46:04,265 DEBUG    Main         knx: 1.1.53 set 3/2/36 to 3 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:04,306 DEBUG    Main         Item RTR.OG.Eltern.mode = 3 via KNX 1.1.53 3/2/36 -- item.py:__update:363
    2013-12-28 23:46:04,346 DEBUG    Main         KNX: 1.1.3 read 3/2/41 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:04,375 DEBUG    env_loc      Item env.location.moonset = 2013-12-29 13:56:42.343015+01:00 via Logic None None -- item.py:__update:363
    2013-12-28 23:46:04,378 DEBUG    Main         knx: 1.1.53 set 3/2/34 to 0 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:04,425 DEBUG    Main         KNX: 1.1.3 read 3/2/45 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:04,452 DEBUG    env_loc      Item env.location.moonphase = 7 via Logic None None -- item.py:__update:363
    2013-12-28 23:46:04,477 DEBUG    Main         knx: 1.1.54 set 3/2/41 to 17.87 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:04,499 DEBUG    sh.gc        Object references: 9748 -- smarthome.py:_maintenance:490
    2013-12-28 23:46:04,542 DEBUG    Main         Item RTR.OG.Ankleide.actual = 17.87 via KNX 1.1.54 3/2/41 -- item.py:__update:363
    2013-12-28 23:46:04,580 DEBUG    Main         KNX: 1.1.3 read 3/2/46 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:04,606 DEBUG    Main         knx: 1.1.54 set 3/2/45 to 18.0 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:04,608 DEBUG    env_loc      Item env.location.night = True via Logic None None -- item.py:__update:363
    2013-12-28 23:46:04,627 DEBUG    Main         Item RTR.OG.Ankleide.set = 18.0 via KNX 1.1.54 3/2/45 -- item.py:__update:363
    2013-12-28 23:46:04,655 DEBUG    Main         KNX: 1.1.3 read 3/2/44 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:04,671 DEBUG    Main         knx: 1.1.54 set 3/2/46 to 3 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:04,667 DEBUG    1w-sen       Item Heizungsanlage.Anschlussraum.FBHRL = 23.875 via 1-Wire /bus.0/28.448C80040000/temperature None -- item.py:__update:363
    2013-12-28 23:46:04,662 DEBUG    Scheduler    env_loc next time: 2013-12-29 00:16:04+01:00 -- scheduler.py:_next_time:289
    2013-12-28 23:46:04,683 DEBUG    Main         Item RTR.OG.Ankleide.mode = 3 via KNX 1.1.54 3/2/46 -- item.py:__update:363
    2013-12-28 23:46:04,713 DEBUG    Main         KNX: 1.1.3 read 3/2/51 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:04,736 DEBUG    Main         knx: 1.1.54 set 3/2/44 to 1 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:04,749 DEBUG    Scheduler    sh.gc next time: 2013-12-29 02:04:00+01:00 -- scheduler.py:_next_time:289
    2013-12-28 23:46:04,771 DEBUG    Main         Item RTR.OG.Ankleide.state = 1 via KNX 1.1.54 3/2/44 -- item.py:__update:363
    2013-12-28 23:46:04,787 DEBUG    Main         knx: 1.1.55 set 3/2/51 to 19.5 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:04,797 DEBUG    Main         Item RTR.OG.Bad.actual = 19.5 via KNX 1.1.55 3/2/51 -- item.py:__update:363
    2013-12-28 23:46:04,815 DEBUG    Main         KNX: 1.1.3 read 3/2/55 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:04,831 DEBUG    Main         KNX: 1.1.3 read 3/2/56 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:04,837 DEBUG    Main         knx: 1.1.55 set 3/2/55 to 20.0 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:04,854 DEBUG    Main         Item RTR.OG.Bad.set = 20.0 via KNX 1.1.55 3/2/55 -- item.py:__update:363
    2013-12-28 23:46:04,864 DEBUG    Main         KNX: 1.1.3 read 3/2/54 -- __init__.py:parse_telegram:203
    2013-12-28 23:46:04,882 DEBUG    Main         knx: 1.1.55 set 3/2/56 to 1 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:04,894 DEBUG    Main         Item RTR.OG.Bad.mode = 1 via KNX 1.1.55 3/2/56 -- item.py:__update:363
    2013-12-28 23:46:04,987 DEBUG    Main         knx: 1.1.55 set 3/2/54 to 1 -- __init__.py:parse_telegram:190
    2013-12-28 23:46:04,993 DEBUG    Main         Item RTR.OG.Bad.state = 1 via KNX 1.1.55 3/2/54 -- item.py:__update:363
    2013-12-28 23:46:05,423 DEBUG    1w-sen       Item Heizungsanlage.Heizraum.T1 = 35.0 via 1-Wire /bus.0/28.F97B80040000/temperature None -- item.py:__update:363
    2013-12-28 23:46:05,435 DEBUG    1w-sen       Triggering Heizungsanlage.Anschlussraum.AVGHeizraum - by: 1-Wire source: /bus.0/28.F97B80040000/temperature dest: None value: {'source': 'Heizungsanlage.Heizraum.T1', -- scheduler.py:trigger:162
    2013-12-28 23:46:05,456 DEBUG    Heizungsanlage.Anschlussraum.AVGHeizraum Item Heizungsanlage.Anschlussraum.AVGHeizraum = 11.666666666666666 via Eval Heizungsanlage.Heizraum.T1 None -- item.py:__update:363
    2013-12-28 23:46:06,172 DEBUG    1w-sen       Item Heizungsanlage.Anschlussraum.FWgehend = 25.0 via 1-Wire /bus.0/28.A36F7F040000/temperature None -- item.py:__update:363
    2013-12-28 23:46:06,896 DEBUG    1w-sen       Item Heizungsanlage.Heizraum.T7 = 54.875 via 1-Wire /bus.0/28.401BC7040000/temperature None -- item.py:__update:363
    2013-12-28 23:46:06,915 DEBUG    1w-sen       Triggering Heizungsanlage.Anschlussraum.AVGHeizraum - by: 1-Wire source: /bus.0/28.401BC7040000/temperature dest: None value: {'source': 'Heizungsanlage.Heizraum.T7', -- scheduler.py:trigger:162
    2013-12-28 23:46:06,923 DEBUG    Heizungsanlage.Anschlussraum.AVGHeizraum Item Heizungsanlage.Anschlussraum.AVGHeizraum = 29.958333333333332 via Eval Heizungsanlage.Heizraum.T7 None -- item.py:__update:363
    2013-12-28 23:46:07,592 DEBUG    1w-sen       Item Heizungsanlage.Heizraum.FWgehend = 48.5 via 1-Wire /bus.0/28.229CC6040000/temperature None -- item.py:__update:363
    2013-12-28 23:46:08,297 DEBUG    1w-sen       Item Heizungsanlage.Heizraum.T8 = 34.25 via 1-Wire /bus.0/28.A03CC6040000/temperature None -- item.py:__update:363
    2013-12-28 23:46:09,024 DEBUG    1w-sen       Item Heizungsanlage.Heizraum.FWkommend = 29.375 via 1-Wire /bus.0/28.6A8E7F040000/temperature None -- item.py:__update:363
    2013-12-28 23:46:09,748 DEBUG    1w-sen       Item Aussenbereich.Temp = 4.75 via 1-Wire /bus.0/28.7A1080040000/temperature None -- item.py:__update:363
    2013-12-28 23:46:09,768 DEBUG    1w-sen       Triggering Aussenbereich.Temp.min - by: 1-Wire source: /bus.0/28.7A1080040000/temperature dest: None value: {'source': 'Aussenbereich.Temp', 'value' -- scheduler.py:trigger:162
    2013-12-28 23:46:09,780 DEBUG    1w-sen       Triggering Aussenbereich.Temp.max - by: 1-Wire source: /bus.0/28.7A1080040000/temperature dest: None value: {'source': 'Aussenbereich.Temp', 'value' -- scheduler.py:trigger:162
    2013-12-28 23:46:09,801 DEBUG    Main         knx: 1.1.3 set 0/4/3 to 01db -- __init__.py:parse_telegram:181
    2013-12-28 23:46:10,526 DEBUG    env_stat     Item env.core.memory = 17768448 via Logic None None -- item.py:__update:363
    2013-12-28 23:46:10,554 DEBUG    env_stat     Item env.system.load = 0.2 via Logic None None -- item.py:__update:363
    2013-12-28 23:46:10,561 DEBUG    1w-sen       Item Heizungsanlage.Anschlussraum.PufferUnten = 34.5625 via 1-Wire /bus.0/28.9136C6040000/temperature None -- item.py:__update:363
    2013-12-28 23:46:10,589 DEBUG    env_stat     Item env.location.moonlight = 17 via Logic None None -- item.py:__update:363
    2013-12-28 23:46:10,595 DEBUG    1w-sen       Triggering Heizungsanlage.Anschlussraum.AVGAnschlussraum - by: 1-Wire source: /bus.0/28.9136C6040000/temperature dest: None value: {'source': 'Heizungsanlage.Anschlussraum -- scheduler.py:trigger:162
    2013-12-28 23:46:10,621 DEBUG    Heizungsanlage.Anschlussraum.AVGAnschlussraum Item Heizungsanlage.Anschlussraum.AVGAnschlussraum = 25.291666666666668 via Eval Heizungsanlage.Anschlussraum.PufferUnten None -- item.py:__update:363
    2013-12-28 23:46:10,873 DEBUG    Scheduler    env_stat next time: 2013-12-28 23:51:10+01:00 -- scheduler.py:_next_time:289
    2013-12-28 23:46:11,286 DEBUG    1w-sen       Item Heizungsanlage.Heizraum.T2 = 57.9375 via 1-Wire /bus.0/28.5F1E80040000/temperature None -- item.py:__update:363
    2013-12-28 23:46:11,295 DEBUG    1w-sen       Triggering Heizungsanlage.Anschlussraum.AVGHeizraum - by: 1-Wire source: /bus.0/28.5F1E80040000/temperature dest: None value: {'source': 'Heizungsanlage.Heizraum.T2', -- scheduler.py:trigger:162
    2013-12-28 23:46:11,316 DEBUG    Heizungsanlage.Anschlussraum.AVGHeizraum Item Heizungsanlage.Anschlussraum.AVGHeizraum = 49.270833333333336 via Eval Heizungsanlage.Heizraum.T2 None -- item.py:__update:363
    2013-12-28 23:46:11,991 DEBUG    1w-sen       Item Heizungsanlage.Heizraum.T6 = 29.25 via 1-Wire /bus.0/28.57737F040000/temperature None -- item.py:__update:363
    2013-12-28 23:46:12,720 DEBUG    1w-sen       Item Heizungsanlage.Anschlussraum.FWkommend = 48.125 via 1-Wire /bus.0/28.DC74C6040000/temperature None -- item.py:__update:363
    2013-12-28 23:46:13,396 DEBUG    1w-sen       Item Heizungsanlage.Heizraum.T3 = 53.75 via 1-Wire /bus.0/28.4E737F040000/temperature None -- item.py:__update:363
    2013-12-28 23:46:14,077 DEBUG    1w-sen       Item Heizungsanlage.Anschlussraum.PufferOben = 55.375 via 1-Wire /bus.0/28.CF3CC6040000/temperature None -- item.py:__update:363
    2013-12-28 23:46:14,095 DEBUG    1w-sen       Triggering Heizungsanlage.Anschlussraum.AVGAnschlussraum - by: 1-Wire source: /bus.0/28.CF3CC6040000/temperature dest: None value: {'source': 'Heizungsanlage.Anschlussraum -- scheduler.py:trigger:162
    2013-12-28 23:46:14,103 DEBUG    Heizungsanlage.Anschlussraum.AVGAnschlussraum Item Heizungsanlage.Anschlussraum.AVGAnschlussraum = 43.75 via Eval Heizungsanlage.Anschlussraum.PufferOben None -- item.py:__update:363
    2013-12-28 23:46:14,833 DEBUG    1w-sen       Item Heizungsanlage.Anschlussraum.FBHVL = 26.9375 via 1-Wire /bus.0/28.682AC6040000/temperature None -- item.py:__update:363
    2013-12-28 23:46:14,845 DEBUG    1w-sen       Triggering FBH - by: Item source: Heizungsanlage.Anschlussraum.FBHVL dest: None value: 26.9375 -- scheduler.py:trigger:162
    2013-12-28 23:46:14,862 DEBUG    1w-sen       1-Wire: sensor cycle takes 13.087527990341187 seconds -- __init__.py:_sensor_cycle:399
    2013-12-28 23:46:52,642 INFO     Main         Number of Threads: 7 -- smarthome.py:stop:348
    2013-12-28 23:46:52,647 INFO     Main         Stop Plugins -- plugin.py:stop:70
    2013-12-28 23:46:53,646 DEBUG    Main         KNX: closing socket 127.0.0.1:6720 -- connection.py:close:303
    2013-12-28 23:46:53,653 INFO     Main         SmartHome.py stopped -- smarthome.py:stop:372
    Init SmartHome.py 1.0-21-g7f162e6
    2013-12-28 23:47:05 INFO     Main         Start SmartHome.py 1.0-21-g7f162e6
    2013-12-28 23:47:05 INFO     Main         Init Scheduler
    2013-12-28 23:47:05 INFO     Main         Init Plugins
    2013-12-28 23:47:07 INFO     Main         Init Items
    2013-12-28 23:47:09 INFO     Main         Start Plugins
    2013-12-28 23:47:09 INFO     Main         Start Logics
    2013-12-28 23:47:09 INFO     Connections  1-Wire: connected to 127.0.0.1:4304
    2013-12-28 23:47:12 INFO     1w-disc      1-Wire: 28.401BC7040000 with sensors: T11, T10, T, T12, T9
    2013-12-28 23:47:12 INFO     1w-disc      1-Wire: 28.A03CC6040000 with sensors: T11, T10, T, T12, T9
    2013-12-28 23:47:12 INFO     1w-disc      1-Wire: 28.A83BC6040000 with sensors: T11, T10, T, T12, T9
    2013-12-28 23:47:12 INFO     1w-disc      1-Wire: 28.682AC6040000 with sensors: T11, T10, T, T12, T9
    2013-12-28 23:47:13 INFO     1w-disc      1-Wire: 28.448C80040000 with sensors: T11, T10, T, T12, T9
    2013-12-28 23:47:13 INFO     1w-disc      1-Wire: 28.DC74C6040000 with sensors: T11, T10, T, T12, T9
    2013-12-28 23:47:13 INFO     1w-disc      1-Wire: 28.229CC6040000 with sensors: T11, T10, T, T12, T9
    2013-12-28 23:47:13 INFO     1w-disc      1-Wire: 28.6A8E7F040000 with sensors: T11, T10, T, T12, T9
    2013-12-28 23:47:13 INFO     1w-disc      1-Wire: 28.7A1080040000 with sensors: T11, T10, T, T12, T9
    2013-12-28 23:47:13 INFO     1w-disc      1-Wire: 28.4E737F040000 with sensors: T11, T10, T, T12, T9
    2013-12-28 23:47:13 INFO     1w-disc      1-Wire: 28.9136C6040000 with sensors: T11, T10, T, T12, T9
    2013-12-28 23:47:13 INFO     1w-disc      1-Wire: 28.3900C7040000 with sensors: T11, T10, T, T12, T9
    2013-12-28 23:47:13 INFO     1w-disc      1-Wire: 28.F97B80040000 with sensors: T11, T10, T, T12, T9
    2013-12-28 23:47:13 INFO     1w-disc      1-Wire: 28.A36F7F040000 with sensors: T11, T10, T, T12, T9
    2013-12-28 23:47:13 INFO     1w-disc      1-Wire: 28.0BD1C6040000 with sensors: T11, T10, T, T12, T9
    2013-12-28 23:47:13 INFO     1w-disc      1-Wire: 28.57737F040000 with sensors: T11, T10, T, T12, T9
    2013-12-28 23:47:13 INFO     1w-disc      1-Wire: 28.CF3CC6040000 with sensors: T11, T10, T, T12, T9
    2013-12-28 23:47:13 INFO     1w-disc      1-Wire: 28.5F1E80040000 with sensors: T11, T10, T, T12, T9
    2013-12-28 23:47:13 INFO     1w-disc      1-Wire: 81.584832000000 with sensors: BM
    [Aussenbereich]
        [[Temp]]
            type = num
            visu = yes
            sqlite = yes
            knx_dpt = 9
            knx_send = 0/4/3
            knx_reply = 0/4/3
            ow_addr = 28.7A1080040000
            ow_sensor = T
            [[[min]]]
                visu = yes
                type = num
                eval = "sh.Aussenbereich.Temp.db('min', '24h')"
                eval_trigger = Aussenbereich.Temp
            [[[max]]]
                visu = yes
                type = num
                eval = "sh.Aussenbereich.Temp.db('max', '24h')"
    Hat jemand eine Idee?
    Vielen Dank im Voraus.
    MFG
    Tom
    sqlite = init
    Bei dem Item hilft
    Gesendet von unterwegs
      hab jetzt mal das init im Item eingefügt. Funktioniert leider noch nicht.
      HTML-Code:
      [Aussenbereich]
          [[Temp]]
              type = num
              visu = yes
              sqlite = yes
              knx_dpt = 9
              knx_send = 0/4/3
              knx_reply = 0/4/3
              ow_sensor = T
              [[[min]]]
                  visu = yes
                  sqlite = init
                  type = num
              [[[max]]]
                  visu = yes
                  sqlite = init
                  type = num
      MFG
      Tom
        24h warten oder Datenbank löschen ... vorher wurde beim Start wohl immer ne 0 gespeichert ... soweit die Vermutung
        Baustelle 2.0 !
          ...hab die Datenbank gelöscht. Der MAX Wert hat sich verändert, der MIN Wert zeigt immer noch 0,0 Grad an.
          Tom
            Hi Tom,
            ich war gestern Nacht in einem Vortrag, deswegen war ich etwas kurz angebunden. Sorry dafür.
            Das sqlite = init muss natürlich bei Temp stehen. Das sqlite bei min und max kann raus. Es bringt nichts.
            Nach einem Neustart und 24h sollte es dann passen. Ein löschen der DB hilft hier nicht.
            Bis bald
            Marcus
              Hi Marcus,
              hab`s jetzt mal abgeändert und neu gestartet. Jetzt warte ich mal ab....
              Vielen Dank für die schnelle Hilfe.
              Tom
                Ein Frage stellt sich mir aber dann doch noch...
                Wieso wird der MAX-Wert angezeigt (hat sich auch schon geändert) und der MIN-Wert noch nicht?
                MFG Tom
                  kurzes Update nach 24 Stunden. Der MIN-Wert wird leider immer noch nicht richtig angezeigt...hat vielleicht noch jemand eine Idee woran`s liegen könnte?
                  Dankeschön
                  MFG
                  Tom
                    kann dann ja fast nur ne fehlerhafte query sein ? denn auch nur bei einem wert in der db müsste min=max sein
                      kann es sein, dass der MIN-Wert nur korrekt angezeigt wird, wenn er sich unter 0 Grad befindet. Seitdem heute Abend die Temperatur unter 0 Grad gefallen ist, zeigt es mir auch die korrekten Werte an.
                      Tom
                        Nein das passt alles.
                        Bis bald
                        Marcus
                          Hallo Tom,
                          ich habe gestern Abend auch die Min-/Max - Anzeige bei mir in die Plots mit eingebaut. Nach genau 24 Stunden (mein eingestelltes Intervall) wird der Min-Wert korrekt ausgegeben. Von daher denke ich war es vorher einfach "noch nicht so weit". Ach ja, ich habe alles positive Werte und es klappt auch :-)
                          Dieter
                            Dann war ich wohl etwas zu ungeduldig, trotzdem vielen Dank für die Hilfe.
                            Tom
