Hallo!
Ich bin ganz neu beim KMX welt.
Ich wollte es probieren und habe ich mich das folgende angeschlossen:
PC(ETS4) -> RespberryPi/ROT(SmartHome.py) -> Hager TXA111 -> Hager TXA204A
Beim Downloaden von Application in den TXA204A macht der ETS4 ein "Internal device error occurred".
2014-03-19 21:59:42,951 [17] INFO DevManagement - CompareMem($B6EC...$B6EC) 02
2014-03-19 21:59:43,308 [17] INFO NetworkBridgeFalcon - ReadMem(RCo$1103:01FA825C, $B6EC...$B6EC): S_OK
2014-03-19 21:59:43,310 [17] INFO DevManagement - ReadMem($B6EC...$B6EC) 03
2014-03-19 21:59:43,311 [17] WARN DevManagement - CompareMem($B6EC...$B6EC) verify failed at $B6EC: $03/$02
2014-03-19 21:59:43,312 [17] INFO DevManagement - CompareMem($B6EC...$B6EC) 02
2014-03-19 21:59:43,567 [17] INFO NetworkBridgeFalcon - ReadMem(RCo$1103:01FA825C, $B6EC...$B6EC): S_OK
2014-03-19 21:59:43,568 [17] INFO DevManagement - ReadMem($B6EC...$B6EC) 03
2014-03-19 21:59:43,569 [17] WARN DevManagement - CompareMem($B6EC...$B6EC) verify failed at $B6EC: $03/$02
2014-03-19 21:59:43,570 [17] INFO DevManagement - CompareMem($B6EC...$B6EC) 02
2014-03-19 21:59:43,972 [17] INFO NetworkBridgeFalcon - ReadMem(RCo$1103:01FA825C, $B6EC...$B6EC): S_OK
2014-03-19 21:59:43,974 [17] INFO DevManagement - ReadMem($B6EC...$B6EC) 03
2014-03-19 21:59:43,975 [17] WARN DevManagement - CompareMem($B6EC...$B6EC) verify failed at $B6EC: $03/$02
2014-03-19 21:59:43,976 [17] ERROR DevManagement - WriteLoadControl(3,3) failed
2014-03-19 21:59:43,979 [17] ERROR Adm1Interpreter - Load control 'AbsDataSeg 3 addr=$0700-0777, access=$00, memtype=$02, flags=$00' failed: HAWK_E_DEVICE_CONTROL_FAILED
2014-03-19 21:59:43,980 [17] INFO DevManagement - Disconnect(01.01.003)
2014-03-19 21:59:44,099 [17] INFO NetworkBridgeFalcon - FalconConnection!Close RCo$1103:01FA825C
2014-03-19 21:59:44,100 [17] INFO Adm1Interpreter - End Execute (hr=HAWK_E_DEVICE_CONTROL_FAILED)
2014-03-19 21:59:44,101 [17] INFO LoadDeviceTask - Download - Enter LoadDeviceTask::RunFinal(01.01.003, None)
2014-03-19 21:59:44,103 [17] INFO LoadDeviceTask - Setting Programming Flags ($1103): Addr=1, Cfg=1, Appl=0, Par=0, Grp=0, Img=null, Chksum=null
2014-03-19 21:59:44,325 [17] INFO LoadDeviceTask - Download - Leave LoadDeviceTask::RunFinal(01.01.003, None)
2014-03-19 21:59:44,327 [17] ERROR Knx.Ets.UI.Deagle.PendingOperation - Error during executing RunFinalPhase() method of object rr: An internal device error occurred.
Um was könnte diese Problem kommen?
Danke für die Hilfe!
