Unknown Error
    [Webserver] Unknown Error
    Hi Zusammen,
    hab grad einen unschönen Effekt.
    Ich bekomme ständig einen "Unknown Error" in SV 2.9
    Anbei die LOG Datei von NGINX:
    [FONT="Helvetica"][SIZE=3]2019/05/17 12:41:57 [error] 512#512: *4269 FastCGI sent in stderr: "PHP message: PHP Warning:  file_get_contents([/SIZE][URL="http://192.168.178.1/cgi-bin/webcm"][U][SIZE=3][COLOR=#0000ff]http://192.168.178.1/cgi-bin/webcm[/COLOR][/SIZE][/U][/URL][SIZE=3]): failed to open stream: HTTP request failed! HTTP/1.0 404 Not Found[/SIZE][/FONT]
    [FONT="Helvetica"][SIZE=3] in /var/www/html/smartVISU2.9/lib/phone/service/fritz!box.php on line 37[/SIZE][/FONT]
    [FONT="Helvetica"][SIZE=3]PHP message: PHP Warning:  file_get_contents([/SIZE][URL="http://192.168.178.1/cgi-bin/webcm?getpage=../html/de/menus/menu2.html&errorpage=../html/de/menus/menu2.html&var:lang=de&var:pagename=foncalls&var:errorpagename=foncalls&var:menu=home&var:pagemaster=&var:activtype=pppoe"][U][SIZE=3][COLOR=#0000ff]http://192.168.178.1/cgi-bin/webcm?getpage=../html/de/menus/menu2.html&errorpage=../html/de/menus/menu2.html&var:lang=de&var:pagename=foncalls&var:errorpagename=foncalls&var:menu=home&var:pagemaster=&var:activtype=pppoe[/COLOR][/SIZE][/U][/URL][SIZE=3]): failed to open stream: HTTP request failed! HTTP/1.0 404 Not Found[/SIZE][/FONT]
    [FONT="Helvetica"][SIZE=3] in /var/www/html/smartVISU2.9/lib/phone/service/fritz!box.php on line 47[/SIZE][/FONT]
    [FONT="Helvetica"][SIZE=3]PHP message: PHP Warning:  Invalid argument supplied for foreach() in /var/www/html/smartVISU2.9/lib/phone/service/fritz!box.php on line 58" while reading response header from upstream, client: 192.168.178.201, server: domain_here, request: "GET /smartVISU2.9/lib/phone/service/fritz%21box.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/php/php7.0-fpm.sock:", host: "192.168.178.23", referrer: "[/SIZE][URL="http://192.168.178.23/smartVISU2.9/index.php"][U][SIZE=3][COLOR=#0000ff]http://192.168.178.23/smartVISU2.9/index.php[/COLOR][/SIZE][/U][/URL][SIZE=3]"[/SIZE][/FONT]
    [FONT="Helvetica"][SIZE=3]2019/05/17 12:41:58 [error] 512#512: *4273 FastCGI sent in stderr: "PHP message: PHP Warning:  file_get_contents([/SIZE][URL="http://smartvisu.de/download/check.php?local=2.9&hash=a5b7d6be12c36bbfcd3bc0a3d73062fes"][U][SIZE=3][COLOR=#0000ff]http://smartvisu.de/download/check.php?local=2.9&hash=a5b7d6be12c36bbfcd3bc0a3d73062fes[/COLOR][/SIZE][/U][/URL][SIZE=3]): failed to open stream: HTTP request failed! HTTP/1.1 500 Internal Server Error[/SIZE][/FONT]
    [FONT="Helvetica"][SIZE=3] in /var/www/html/smartVISU2.9/lib/base/check_update.php on line 26" while reading response header from upstream, client: 192.168.178.201, server: domain_here, request: "GET /smartVISU2.9/lib/base/check_update.php?local=2.9 HTTP/1.1", upstream: "fastcgi://unix:/var/run/php/php7.0-fpm.sock:", host: "192.168.178.23", referrer: "[/SIZE][URL="http://192.168.178.23/smartVISU2.9/index.php"][U][SIZE=3][COLOR=#0000ff]http://192.168.178.23/smartVISU2.9/index.php[/COLOR][/SIZE][/U][/URL][SIZE=3]"[/SIZE][/FONT]
    [FONT="Helvetica"][SIZE=3]2019/05/17 12:41:58 [error] 512#512: *4267 FastCGI sent in stderr: "PHP message: PHP Warning:  file_get_contents([/SIZE][URL="https://p01-caldav.icloud.com/"][U][SIZE=3][COLOR=#0000ff]https://p01-caldav.icloud.com/[/COLOR][/SIZE][/U][/URL][SIZE=3]): failed to open stream: HTTP request failed! HTTP/1.1 401 Unauthorized[/SIZE][/FONT]
    [FONT="Helvetica"][SIZE=3] in /var/www/html/smartVISU2.9/lib/calendar/service/CalDav.php on line 43[/SIZE][/FONT]
    [FONT="Helvetica"][SIZE=3]PHP message: PHP Warning:  file_get_contents([/SIZE][URL="https://p01-caldav.icloud.com/"][U][SIZE=3][COLOR=#0000ff]https://p01-caldav.icloud.com/[/COLOR][/SIZE][/U][/URL][SIZE=3]): failed to open stream: HTTP request failed! HTTP/1.1 401 Unauthorized[/SIZE][/FONT]
    [FONT="Helvetica"][SIZE=3]PHP message: PHP Fatal error:  Uncaught Error: Call to a member function children() on null in /var/www/html/smartVISU2.9/lib/calendar/service/CalDav.php:79[/SIZE][/FONT]
    [FONT="Helvetica"][SIZE=3]Stack trace:[/SIZE][/FONT]
    [FONT="Helvetica"][SIZE=3]#0 /var/www/html/smartVISU2.9/lib/calendar/service/CalDav.php(184): calendar_caldav->get_calendar_urls('[/SIZE][URL="https://p01-cal/"][U][SIZE=3][COLOR=#0000ff]https://p01-cal[/COLOR][/SIZE][/U][/URL][SIZE=3]...', Array)[/SIZE][/FONT]
    [FONT="Helvetica"][SIZE=3]#1 /var/www/html/smartVISU2.9/lib/service.php(86): calendar_caldav->run()[/SIZE][/FONT]
    [FONT="Helvetica"][SIZE=3]#2 /var/www/html/smartVISU2.9/lib/calendar/service/iCloud.php(36): service->json()[/SIZE][/FONT]
    [FONT="Helvetica"][SIZE=3]#3 {main}[/SIZE][/FONT]
    [FONT="Helvetica"][SIZE=3]  thrown in /var/www/html/smartVISU2.9/lib/calendar/service/CalDav.php on line 79" while reading response header from upstream, client: 192.168.178.201, server: domain_here, request: "GET /smartVISU2.9/lib/calendar/service/iCloud.php?count=5&calendar= HTTP/1.1", upstream: "fastcgi://unix:/var/run/php/php7.0-fpm.sock:", host: "192.168.178.23", referrer: "[/SIZE][URL="http://192.168.178.23/smartVISU2.9/index.php"][U][SIZE=3][COLOR=#0000ff]http://192.168.178.23/smartVISU2.9/index.php[/COLOR][/SIZE][/U][/URL][SIZE=3]"[/SIZE][/FONT]
    [FONT="Helvetica"][SIZE=3]2019/05/17 12:41:59 [error] 512#512: *4276 FastCGI sent in stderr: "PHP message: PHP Warning:  file_get_contents([/SIZE][URL="https://p01-caldav.icloud.com/"][U][SIZE=3][COLOR=#0000ff]https://p01-caldav.icloud.com/[/COLOR][/SIZE][/U][/URL][SIZE=3]): failed to open stream: HTTP request failed! HTTP/1.1 401 Unauthorized[/SIZE][/FONT]
    Irgendwie hat SV wohl ein Problem mit Fritzbox und Calendar. Habe beide in der config schon auf OFFLINE gesetzt, was aber nichts geholfen hat. Die Fehlermeldungen kommen immer, egal ob on oder offline.
    Jemand nen Ansatz?
    sind die einzelurls von dort wo der nginx läuft erreichbar? kannste ja via curl oder wget testen. bspw. http://192.168.178.1/cgi-bin/webcm oder https://p01-caldav.icloud.com/ bei letzterem scheint wohl login/passwort nicht mehr zu passen. vielleicht geändert?
    Zuletzt geändert von psilo; 17.05.2019, 17:37.
      Naja das Problem ist ja dass der Fehler auch kommt, wenn ich beide Plugins auf Offline habe. Deswegen bin ich maximal verwirrt!
        welche plugins denn??? achso die funktionen der smartvisu.. ich würde zur lösung trotzdem erstmal schauen, warum da kein netzwerkzugriff möglich ist kannst ja auch mal die kalender schnittstelle etc direkt aufrufen und im php analysieren was da los ist.. hast du in der config datei (config.ini) verifiziert, dass sie auch wirklich offline sind? vielleicht spinnt die gui ja und du nimmst sie garnicht wirklich offline.. oder das config file ist nicht beschreibbar etc.
        deine webcam hat zudem ja nichts damit zu tun, ob die erreichbar ist kannste so oder so mal verifizieren. (http://192.168.178.1/cgi-bin/webcm)
          Hab keine Webcam ….. ernsthaft? cgi-bin/webcm hat nichts mit ner WebCam zu tun ;-)
            nur dass das keine webcam ist, erübrigt nicht meine empfohlenen analyseschritte
              webcm hat auch nichts mit einer CAM zu tun
              Das ist nunmal das CGI Modul der Fritzbox
                Haben die neueren boxen das noch? Naja wie auch immer, offenbar verwendet er dann auch noch kein tr-064 fuer den zugriff..
                  ich kann diese Fehlermeldung auch bestätigen. Ich bekomme diesen auch. Gibt es dazu schon eine Lösung?
                  Der verwendetet Kalender ist Icloud
                  Gruß Manuel
                    Also ich hatte den Fehler verblüffender Weise weg ohne was zu tun.....mehrere Wochen....nu Isser wieder da :-(
                      Hallo, du kannst es ja mal hiermit probieren:
                      https://knx-user-forum.de/forum/supp...drücken/page2
                      Post 25
                      Ich habe damit bis jetzt keine negativen Erfahrungen gemacht.
                      ​​​​​​​Läuft trotzdem alles wie es soll nur ohne diese Meldungen.
                      EDIT: Das ist hier wohl ein anderes Problem. Habe ich oben irgendwie überlesen...
                      Zuletzt geändert von schuma; 04.07.2019, 11:27.
                        bei mir im browser log sehe ich 500er Meldungen vom ical.
                        das ich zwei iCloud Kalender auf meiner index Seite eingebunden haben, sehe ich dort zwei Stück:
                        hat sich dort etwa das API geändert ?
                        wenn ich die Meldungen wegclicke, stelle ich nach längerem Nichtbenutzen fest, dass dort mehrere Meldungen im Stundenrhythmus und zwar immer zur vollen Stunde anstehen; vielleicht ist das noch ein Hinweis für die Experten.
                        hinzugefügt:
                        die Stunde stammt wohl vom calendar.list widget
                        Zuletzt geändert von whe; 03.08.2019, 11:10.
                          Du scheinst zwei unabhängige Fehler zu haben. Einerseits iCloud, andererseits fritz!box.
                          Meine Antwort zur iCloud findet ihr unter https://knx-user-forum.de/forum/supp...38#post1394438
