Und: poste mal nen Screenshot
* A switch, build of two pics
* @param unique id for this widget
* @param a item
* @param the pic for the 'on' state (optional)
* @param the pic for the 'off' state (optional)
* @param value send for the 'on' state (optional, default 1)
* @param value send for the 'off' state (optional, default 0)
* [USER][/USER] param the color 'icon1' or e. g. '#f00' for red (default 'icon1' of the design)
{% macro switch(id, item, pic_on, pic_off, val_on, val_off, color) %}
{% set uid = uid(page, id) %}
{% if not pic_on or pic_on|slice(-4, 4) == '.svg' %}
<span id="{{ uid }}" data-widget="basic.switch" data-item="{{ item }}"
data-val-on="{{ val_on|default('1') }}" data-val-off="{{ val_off|default('0') }}"
data-pic-on="{{ pic_on|deficon('control_on_off.svg') }}" data-pic-off="{{ pic_off|deficon('control_on_off.svg') }}"
class="switch icon">
<a>
<img id="{{ uid }}-off" class="icon" src="{{ pic_off|deficon('control_on_off.svg') }}" />
{% if color is empty %}
<img id="{{ uid }}-on" class="icon icon1 hide" src="{{ pic_on|deficon('control_on_off.svg') }}" />
{% elseif color == 'icon1' %}
{% else %}
<img id="{{ uid }}-on" class="icon icon1 hide" style="stroke:{{ color }}; fill:{{ color }};" src="{{ pic_on|deficon('control_on_off.svg') }}" />
{% endif %}
</a>
</span>
{% else %}
<span id="{{ uid }}" data-widget="basic.switch.v1" data-item="{{ item }}"
data-pic-on="{{ pic_on|default(icon1~'control_on_off.png') }}" data-pic-off="{{ pic_off|default(icon0~'control_on_off.png') }}"
class="switch"><a><img class="icon" src="{{ pic_off|default(icon0~'control_on_off.png') }}" /></a>
</span>
{% endif %}
{% endmacro %}
* A switch with to states displayed as a button
* @param a item
* @param type: 'micro', 'mini', 'midi' (optional, default: mini)
* @param color: 'color' for on state e.g. '#f00' for red (optional, default: 'icon1' of design)
{% macro dual(id, item, pic_on, pic_off, val_on, val_off, type, color) %}
<a id="{{ uid(page, id) }}" data-widget="basic.dual" data-item="{{ item }}"
class="ui-{{ type|default('mini') }}" data-role="button" data-inline="true" data-iconpos="center">
{% else %}
{% endif %}
</a>
{% endmacro %}
* Standard dimmer with switching and dimming function
* @param name of the dimmer
* @param a item for switching
* @param a item for dimming
* @param the minimum value if the slider is moved to total left (optional, default 0)
* @param the maximum value if the slider is moved to total right (optional, default 255)
* @param step between two values (optional, default 5)
* @param pic_on: icon for on state (optional, default: light_light.svg)
* @param pic_off: icon for off state (optional, default: light_light.svg)
* @param color: 'color' for pic_on e.g. '#f00' for red (optional, default: 'icon1' of design)
{% macro dimmer(id, txt, item_switch, item_value, min, max, step, pic_on, pic_off, color) %}
{% import "basic.html" as basic %}
<div class="dimmer">
{{ basic.switch(id~'switch', item_switch, pic_on|default('light_light.svg'), pic_off|default('light_light.svg'), '', '', color) }}
<p>{{ txt|e }}</p>
{{ basic.slider(id~'slider', item_value, min, max, step) }}
</div>
{% endmacro %}
<div id="menu" class="menu">
<a id="menu-rooms" data-ajax="false" href="index.php">
<img class="icon" src="{{ page == 'index' ? icon1 : icon0 }}control_building_empty.svg"/></a>
