I'm currently looking for an alternative to the Raspberry pi and the Beaglebone black to run Smarthome and SmartVISU.
Kindly let me know you thoughts on the following ones:
CUBOX
CPU - 800MHz - 88AP510
RAM - 1GB
SD Card MicroSD
USB 2 x 2.0
eSATA 1 x 2.0 = 3Gbps SATAII
Bluetooth 3.0
Network 1 x 10/100/1000
Streaming from fast Ethernet and playing Full HD less than 3 W.
+-120 EUR
The CuBox i From SolidRun | The Little Computer that can
CuBox
TonidoPlug 2
CPU - 800MHz - Armada310 88F6283
RAM - 512Mb + 512Mb NAND Flash
Network - 1 x 10/100/1000
Wifi - b/g/n
SATA for 2.5" HDD or SSD
TonidoPlug2 is based on Marvell Armada 310 chipset which draws only 1.2 watt
+-120 EUR
What is TonidoPlug2 Home Server?
TonidoPlug2
SheevaPlug
CPU - 1.2GHz - Marvell Kirkwood 88F6281 SoC
USB 1x2.0
SD Card slot
+-160EUR
Sheeva Multi Boot
MiraBox
1.2Ghz Marvell Armada CPU ARMADA 370 ARM v7 compliant
802.11b/g/n Wifi and Bluetooth 3.0
1GB DDR3
1 GB NAND Flash
2 x 10/100/1000 Ethernet Ports
2 x USB 3.0 host
1 microsd card slot/reader
+-150 USD
MiraBox Java DevKit
CUBOX
RAM - 1GB
SD Card MicroSD
USB 2 x 2.0
Bluetooth 3.0
+-120 EUR
CuBox
TonidoPlug 2
Wifi - b/g/n
+-120 EUR
TonidoPlug2
SheevaPlug
USB 1x2.0
SD Card slot
+-160EUR
Sheeva Multi Boot
MiraBox
1GB DDR3
1 GB NAND Flash
2 x USB 3.0 host
+-150 USD
MiraBox Java DevKit
