- √ - Best Minipc to run smartVISU - Your thoughts
    I'm currently looking for an alternative to the Raspberry pi and the Beaglebone black to run Smarthome and SmartVISU.
    Kindly let me know you thoughts on the following ones:
    CUBOX
    CPU - 800MHz - 88AP510
    RAM - 1GB
    SD Card MicroSD
    USB 2 x 2.0
    eSATA 1 x 2.0 = 3Gbps SATAII
    Bluetooth 3.0
    Network 1 x 10/100/1000
    Streaming from fast Ethernet and playing Full HD less than 3 W.
    +-120 EUR
    The CuBox i From SolidRun | The Little Computer that can
    CuBox
    TonidoPlug 2
    CPU - 800MHz - Armada310 88F6283
    RAM - 512Mb + 512Mb NAND Flash
    Network - 1 x 10/100/1000
    Wifi - b/g/n
    SATA for 2.5" HDD or SSD
    TonidoPlug2 is based on Marvell Armada 310 chipset which draws only 1.2 watt
    +-120 EUR
    What is TonidoPlug2 Home Server?
    TonidoPlug2
    SheevaPlug
    CPU - 1.2GHz - Marvell Kirkwood 88F6281 SoC
    USB 1x2.0
    SD Card slot
    +-160EUR
    Sheeva Multi Boot
    MiraBox
    1.2Ghz Marvell Armada CPU ARMADA 370 ARM v7 compliant
    802.11b/g/n Wifi and Bluetooth 3.0
    1GB DDR3
    1 GB NAND Flash
    2 x 10/100/1000 Ethernet Ports
    2 x USB 3.0 host
    1 microsd card slot/reader
    +-150 USD
    MiraBox Java DevKit
    Wait for the new Intel Bay Trail NUC
    Bay Trail-M Powered Intel NUC Coming In Q1 2014 for $140 | PC Perspective
    Gruß Stephan
      As the "server" will be on 24/7/365 I'm looking for a low power consumption device.
      I guess "the new Intel Bay Trail NUC" power consumption will be far over 5-10W....
        Maybe this thread can help you:
        https://knx-user-forum.de/smarthome-...ehlung-ii.html
        Umgezogen? Ja! ... Fertig? Nein!
        Baustelle 2.0 !
          Another one... seems interesting : the "Utilite"
          Power consumption is 3-8W depending on devices in use, operating system and CPU/graphics load required by the application.
          $99 ARM-based PC runs either Ubuntu or Android
          "Utilite" has single- to quad-core Cortex-A9 chip and up to 512GB flash storage.
          "Utilite," won't be as cheap as a Raspberry Pi, but the specs justify the cost. With dimensions of 5.3” × 3.9” × 0.8”, Utilite comes with a Freescale i.MX6 system-on-chip with a single-, dual-, or quad-core ARM Cortex-A9 processor (which uses 3-8 watts of power). It will have up to 4GB of DDR3 1066MHz memory, up to 512GB of SSD storage, and a microSD slot allowing another 128GB.
          The PC can be purchased with either Ubuntu Linux or Android.
          from $99 to $219 + Shipping $67,00 (Belgium)
          Order Utilite Direct | Utilite
          http://bitkistl.blogspot.co.at/2013/...-computer.html
          • Graphics Processing Unit supporting OpenGL ES 1.1 and 2.0, OpenVG 1.1, and OpenCL EP
          • Video Processing Unit supporting multi-stream 1080p H.264, VC1, RV10, and DivX decoding
          • HDMI 1.4 up to 1920×1200 @ 60Hz
          • DVI-D up to 1920×1200 @ 60Hz
          • Two Gigabit Ethernet ports
          • Wi-Fi 802.11b/g/n
          • Bluetooth 3.0
          • Stereo line-out and stereo line-in
          • S/PDIF (electrical through 3.5 mm jack)
          • Four USB2.0 high-speed ports, 480 Mbit/s
          • USB OTG port, 480 Mbit/s
          • Two RS232 serial ports, ultra mini serial connector
            MK802III LE (Linux Edition) Picuntu Linux Mini PC
            CPU - Rockchip RK3066 Dual Core (Cortex A9 Dual Core upto 1.6GHz)
            GPU - Mali 400 Supports Open GL ES 1.1 and 2.0 (open source driver)
            Memory (RAM) - 1GB
            Storage - 16GB Micro SD Card / 8GB Internal NAND FLASH
            System - Picuntu Linux (Ubuntu 12.10, Xubuntu)
            Networking - Wifi 802.11b/g/n
            Video - HDMI up to 1920x1080p
            Audio - HDMI
            USB - 1 x Full Size USB Host, 1 x Micro USB (for powering device and recovery)
            Other Hardware Features - PMU (for complete software shutdown), Easily accessible recovery switch.
            Power - 5V USB <1Amp
            Cloudsto MK802III LE - Mini ARM Linux PC
            best ubuntu mini pc on the market - YouTube
            £64.99
              what about the ouya ? 4,5W in gaming 1W standby and its possible to install debian on it.
              quadcore 1,7 Ghz Cortex A9
              nvidia geForce ULP
              1Gb DDR3
              1 usb
              8 GB eMMC
              lan/wlan/bluethooth
              $99.-
                About OUYA
                from Debian/Ubuntu now on Ouya - xda-developers
                "Kernel is booted from memory and Debian from USB stick or SD card.
                Known issues
                Not properly tested, so there is a bunch unknown issues.
                Low-power core doesn't work (kernel crash)
                USB stick and SD card are both flash and it seems that a lot of issues are coming from using flash storage (same for raspberry pi).
                  you know the cubieboard ?
                  its like raspi but with onboard sata and a little more power
                  CPU: 1GHz ARM cortex-A8 processor, NEON, VFPv3, 256KB L2 cache
                  GPU: Mali400, OpenGL ES GPU
                  RAM: 1GB DDR3 @480MHz
                  Flash: 4GB Nand Flash
                  Video output: HDMI 1080p, VGA, RCA Video, LVDS, LCD
                  USB: 2 * USB 2.0 Host
                  Memory extension: microSD Karten Slot
                  IO expansion: 2 * 48 Pin Header mit I2C, SPI, ADC, CVBS, VGA, LVDS LCD, RGB LCD, SPDIF
                  3.5mm Line-In jack
                  3.5mm Headphone jack
                  SATA Ports: 1
                  ~ 70 eur
                  and the cubietruck
                  Allwinner Tech SOC A20 ARM® Cortex™-A7 Dual-Core ARM® Mali400 MP2 Complies with OpenGL ES 2.0/1.1
                  2GB DDR3@480MHz
                  HDMI&VGA 1080P display output on-board
                  10M/100M/1G Ethernet
                  WIFI + BT wireless connection with antenna on-board
                  SATA 2.0 interface support 2.5’ HDD (for 3.5’ HDD, only need another 12V power input)
                  Storage solution NAND + MicroSD
                  2 x USB HOST, 1 x OTG, 1 x SPDIF, 1 x IR, 4 x LEDs, 1 x Headphone, 3 x Keys
                  Power DC5V@2.5A with HDD support Li-battery & RTC
                  54 extended pins including I2S, I2C, SPI, CVBS, LRADC x2,UART, PS2, PWM x2, TS/CSI, IRDA, LINEIN&FMIN&MICIN, TVIN x4 with 2.0 pitch connectors
                  PCB size 11cm *8cm*1.4mm
                  ~ 90 eur
                    Strangely I missed the Cubieboard
                    Seems to fit perfectly... I ordered a Cubieboard2 to try.
                    Thanks!
                      found it these days.
                      please update me when you got it an tested it, im also looking for something more solid to replace my pi.
                        how is the experience with the cubietruck ? worth a try ?
