Hat schon jemand versucht die SteelSeries-Canvas mit smartvisu zu verheiraten. Ich könnte mir gut vorstellen, dass man damit eine nette Startseite gestalten kann...
Code auf Github
Code auf Github
* Displays a steelseries lcd
* @param unique id for this widget
* @param a gad/item
{% macro lcd(id, gad) %}
<canvas id="{{ id | replace({'.': '_'}) }}" data-widget="steelseries.lcd" data-item="{{ gad }}" width="50" height="50"></canvas>
<script>
var scroll = false;
var {{ id | replace({'.': '_'}) }};
function init() {
// Initialzing gauge
var sections = [steelseries.Section(0, 70, 'rgba(255, 0, 0, 1.0)'),
steelseries.Section(70, 95, 'rgba(255, 255, 0, 1.0)'),
steelseries.Section(95, 100, 'rgba(0, 255, 0, 1.0)') ];
{{ id | replace({'.': '_'}) }} = new steelseries.DisplaySingle('{{ id | replace({'.': '_'}) }}', {
width: 120,
height: 50,
section: sections
{{ id | replace({'.': '_'}) }}.setLcdColor(steelseries.LcdColor.SECTIONS);
init();
$(document).delegate('canvas[data-widget="steelseries.lcd"]', {
'update': function (event, response) {
// DEBUG: console.log("[basic.textinput] update '" + this.id + "':", response);
{{ id | replace({'.': '_'}) }}.setValue(parseFloat(response));
</script>
{% endmacro %}
* Displays a steelseries linear
* @param the gad for the value
* @param the gad for the threshold
* @param min value
* @param max value
* @param title
* @param unit
{% macro linear(id, gad_value, gad_threshold, minValue, maxValue, title, unit) %}
<canvas id="{{ id | replace({'.': '_'}) }}" data-widget="steelseries.lcd" data-item="{{ gad_value }}, {{ gad_threshold}}" width="320" height="140"></canvas>
<script>
function init() {
{{ id | replace({'.': '_'}) }} = new steelseries.Linear('{{ id | replace({'.': '_'}) }}', {
width: 320,
height: 140,
gaugeType: steelseries.GaugeType.TYPE2,
titleString: "{{ title }}",
unitString: "{{ unit }}",
{% if not gad_threshold %}thresholdVisible: false,{% endif %}
{% if minValue %}minValue: {{ minValue }},{% endif %}
{% if maxValue %}maxValue: {{ maxValue }},{% endif %}
lcdVisible: true
init();
{{ id | replace({'.': '_'}) }}.setValueAnimated(parseFloat(response[0]));
{{ id | replace({'.': '_'}) }}.setThreshold(parseFloat(response[1]));
</script>
{% endmacro %}
* Displays a steelseries linear bargraph
* @param min value
* @param max value
* @param title
* @param unit
{% macro linear_bargraph(id, gad_value, gad_threshold, minValue, maxValue, title, unit) %}
<script>
function init() {
{{ id | replace({'.': '_'}) }} = new steelseries.LinearBargraph('{{ id | replace({'.': '_'}) }}', {
width: 320,
height: 140,
lcdVisible: true
init();
</script>
{% endmacro %}
* Displays a steelseries radial
* @param min value
* @param max value
* @param title
* @param unit
{% macro radial(id, gad_value, gad_threshold, minValue, maxValue, title, unit) %}
<canvas id="{{ id | replace({'.': '_'}) }}" data-widget="steelseries.radial" data-item="{{ gad_value }}, {{ gad_threshold}}" width="201" height="201"></canvas>
<script>
function init() {
{{ id | replace({'.': '_'}) }} = new steelseries.Radial('{{ id | replace({'.': '_'}) }}', {
gaugeType: steelseries.GaugeType.TYPE4,
lcdVisible: true,
lcdDecimals: 1,
useOdometer: false
init();
$(document).delegate('canvas[data-widget="steelseries.radial"]', {
{{ id | replace({'.': '_'}) }}.setValue(parseFloat(response[0]));
{% if gad_threshold %}{{ id | replace({'.': '_'}) }}.setThreshold(parseFloat(response[1]));{% endif %}
</script>
{% endmacro %}
{% import "widgets/widget_steelseries.html" as steelseries %}
{{ steelseries.radial('steel.office.temperature.state ','office.temperature.state','office.temperature.plan', 0, 40, 'Temperatur Büro', '°C') }}
