Gira G1 2077
    Gira G1 2077
    Dear
    In a project, two G1 devices (branded GIRA) used in DCS system as indoor station.
    Early system worked properly and G1 devices matched wireless network.
    After a while noticed the system faced a problem. The problem is G1 devices can't find wireless networks by searching button.
    On the other hand, I can't reset factory these G1 devcies. There is no menu in setting to do this.
    How can I fix this big problem?
    Regards
    To reset a G1, you have to use GPA (Gira Project Assistant).
      I Know it
      but how I can connect to GPA when G1 not assign to a network wireless?
      I need a hardware solution
        I used magnet but that not useful!
          There is no hardware solution unless you have an LAN connector.
            this product havn't lan connector
            only working with wireless !!
            2077 05
              You are wrong
              This gallery has 1 photos.
                With all respect but you are wrong
                  I am surprised that such a thing has such great company
                    G1 is available with three different types of connectors:
                    WLAN and 24V oder 230V
                    LAN with PoE
                    If you can't access it by WLAN any longer, all you can do is to get a PoE module and connect it with LAN and try to perform a factory reset.
                    Btw, if several G1 devices have the same problem with WLAN connection, maybe it is a good idea to check the WLAN side of your installation.
                      I know all it !!
                      but I bought this model and I haven't PoE or WLAN now!
                        I'm sorry but I find it vital
                        Can I open G1 and factory reset manually?
                        If you can...
                          I checked the WLAN side of my installation and not problem
                            i fix it!!
                            download a file (if you want i will send you that link) and copy in mini sd so rest the G1.
                            rest factory now
