How to drive more current from a binary input ?
    [-] How to drive more current from a binary input ?
    Hello,
    I seem to remember a post about how to drive more current from a binary input, but can't find it back (lack of right keyword)
    I'm referring to those small binary input UP, which also have a wire to drive a LED. This drive is limitted to a few mA (5-10).
    The post I'm referring to, described a way, with extra components to drive more current.
    Thanks for a pointer.
    you can use that:
    Kemo Relaiskarte Bausatz 12 V/DC Ausgangsleistung 6 A/30 V/DC 1 Relaisausgang im Conrad Online Shop
    Conrad Order Nr.: 190363-62 4,95 Euro
    It works from 5mA on and has a Relais output.
    I run my electric door opener by that and it is working very good for 3 years now.
    You just have to solder 6 components together, but it is very simple and small.
    It is from KEMO Article No B197
    Andreas
    Alter Hof mit neuer Technik
      Hallo Andreas,
      Thank you
      I'm still a bit confused. I intend to use a Hager TX308, the specs say
      LED Ausgänge Eigenschaften
      I = 850 μA U = 1.8V DC
      So, this thing is only capable of driving 850µA ? usually, a LED is around 5-10mA.
      Should I use a very special LED ? or maybe I should buy another BE ?
      List of "supported LED"
      - HMLP-D101
      - L-793SRD-E
      - KR5005S
      - L-793SRC-C
        I use the Gira 7057 01 and they are working very well with the relay card, which I mentioned yesterday.
        Andreas
          Hello,
          Thanks for the pointer, but ...
          Cannot find this reference on the Gira site (nor on Eibmarkt)
          Keine Treffer für 7057 : 0
          Also, I wonder, if all 4 LED are On, 4x5=20mA, isn't that beyhond the specs of KNX ? (+/- 10mA/device)
            The name was #7057 01 in the ETS3 but the order Nr. is Gira 111900
            sorry for that.
            eibmarkt.com - Uni-Tasterschnittstelle 4fach 111900
            You can only use input 1 and 2 as outputs for LEDs.
            Andreas
              Thanks
              I see that the specs are almost the same as the TX308. I guess the output current is internally limited to max. 0.8 mA.
              I tried a standard LED, it works .... but it is hardly visible. Maybe I've to slect one of those modern bright LED.
              Thank you
