experte has stopped working
    HS/FS experte has stopped working
    I'm upgrading from 4.1 to 4.4, using a new PC with Windows 7, 64bit.
    Installation OK, import OK, but when trying to download my project, I get a pop-up saying
    Experte.exe
    A problem caused the program to stop working corretly
    Windows will close the program
    Is this a known problem related to the 64bit version ?
    I can use Experte from 2.2 to 4.5beta under Win7, 8, 10 both 32 and 64 bit without special modifications.
      Thanks for the quick reply.
      I'll start from scratch, with a tried and trusted 4.1, via RS232 as nothing else works anymore
      I guess the right sequence is:
      download Firmware with firmware update tool via RS232
      download the project with Experte, via the RS232 option
      correct ?
        I've tried several ways to upgrade, no luck yet.
        When using HS Transfer, I see a message
        Experte und Firmware passen nicht
        I understand the versions should match and I thought it was so, but something is wrong
        Can someone recommend the most basic and failsave way to upgrade a HS2 ?
          Your HS is on 4.1 and you want to go to 4.4?
            Yes
              Hi
              Here is how I do it:
              1.) Start Experte 4.1 => export Project to file (Archive with QC and Password)
              2.) Install Experte 4.4
              3.) Import saved Project into 4.4 Experte (check project for Errors !)
              4.) From 4.4 Experte start Firmware upload tool (via network to the running 4.1 HS)
              5.) Upload Projekt (using 4.4 Experte) to HS
              No need for RS232 anymore :-)
              Good Luck
                Hi EIBJ,
                Thanks for the reply.
                I think I've done the procedure according to your recommendation, but encountered some problems (version not match)
                I'll do it again, very carefully.
                Also, I didn't mention it, I want to change the HS IP address, I guess it is enough to change it in the project ? no other place to change it ?
                  I get a bunch of errors, although the project runs fine under 4.1
                  12 yellow sign
                  Interne Kommunikationsobjekte können nicht per bevehl abgevragt werden
                  22 red sign
                  What is the best way to get around those errors ?
                    It makes no sense to read internal objects by command ("Befehl"). The HS knows the state of these objects all the time: they are internal, created by the HS. Delete these commands, the are ueseless.
                      In my case, they are used within the GLE, some are input values
                      I thought those iKO are a good idea to bring some order in the structure
                      Mmm, don't know how to do that properly.
                      It looks like I've to rewrite the logic and, for each instance of an iKO, use a std KO instead of iKO.
                      Correct ?
                        Hi
                        As Matthias said, there is no need to "read" the IKO by command (Befehl) cause they already have the actual Value. They are HS Internal !
                        So you need to get rid of the "read command" and everything should be OK. Just double click on the RED Error line, Experte will bring you to the exact place there the error is.
                        If unsure post the experte screen here.
                        You need to get your project error free in order to complete 4.4 Upgrade, cause you have to upload your project with experte 4.4 to a HS running Firmware 4.4. Otherwise you will get the "version not match".
                        Did you check if your HS already has the new Firmware http://HS-IP/hslist => Enter List "debug" and your user and pw
                        in the output "SYSTEM Section" you should see a line
                        Version 4.4.0.151203
                        In this case 4.4.xxxxx. means 4.4 Firmware on HS. Then you have to fix your errors and upload.
                        Good Luck
                          OK
                          OK, understand
                          I've gathered a collection of FW, hoping to find the right combination. Now I understand it has to be an exact match
                          Oh, I've plenty, I've some spare for you, if you wish :-)
                          That's not possible anymore, the HS is totally screwed up, the only thing which still works is via RS232.
                          What is the right sequence for RS232 upload ?
                          the FW first then the Projekte or
                          Projekte first then FW ?
                            Sorry, I've an understanding problem, so i'll re-phrase my question
                            Suppose that in a GLE sheet, I write a block doing 2+3.
                            I found it simple to put the output into an iKO, say 100/7/41
                            In the Visu, I want to display the output of my calculation, i.e. displaying 100/7/41
                            What's wrong ?
                            I'm not doing any command (befehle) or any explicit read, but I guess it's no good
                            What is the recommended way to do the above ?
                              They way above is not the problem.
                              Your error codes says, that you are reading (Befehl Abfragen) an internal KO. Select that internal KO and check "Verweise".
