I just saw the new Gira HS 4.5 software is available! Including new firmware, QuadClient, Experte..
German Link: https://www.gira.de/service/download...d.html?id=1043
NL Link: http://www.gira.com/nl_NL/service/do...d.html?id=1043
Release Notes:
QuadClient / QuadConfig
New features
Increased password security
- Details on this can be found at the end of the document.
Improvement
Basic setting of design selection
In the basic settings of QuadConfig the selection of active and inactive designs has been changed. From version 4.5.0:
- Design 0 – active
- Design 1 – inactive
- Design 2 – active
- Design 3 – inactive
- Design 4 – active
- Design 5 – active
- Design 6 – active
Project check
- Revised project check even when QuadConfig is running.
Example: Changes to a communication object in Expert are directly adopted in QuadConfig without the need to restart the program.
- Messages in the message window (error, warning, info) are reliable and synchronous, i.e. no display of ("wrong positive") error messages whose cause has already been "rectified".
Loading / saving projects
- In rare cases it could occur that a project file was read incompletely – e.g. due to a defective function template having been loaded. Subsequent writing could then have led to data loss.
- The read and write function for the project data was revised, the user will now be made aware of such errors. Written project data will only be adopted if successful.
- In addition, log files can be opened from QuadConfig. In case of an error, these offer detailed information on the cause of the error.
Function template 1-107 – Shutters Awnings Roof window
- Inverse motion direction for roof windows can now be selected as a response.
Function template 1-103 – Heating Plus (operationg mode switching)
- "Presence button", "presence detector" selection options.
- In the new "presence detector" mode, the buttons for operating mode switching are hidden.
Corrections
- Fixed: Timer - Astro function - pop-up for offset setting Sunset does not open.
- Fixed: Function template 1-108 -Sensor with limit: It was not possible to specify negativenumbers as a limit.
Expert Software
New features
Corrections
- Fixed: All EIB telegrams via EIBnet/IP coming from the HS have been marked as repetitions.
Release Notes:
New features
Improvement
- Design 0 – active
- Design 2 – active
- Design 4 – active
- Design 5 – active
- Design 6 – active
Project check
Corrections
Expert Software
New features
Corrections
