Gira HS Software 4.5 (Experte, QuadClient, Firmware 4.5)
    HS/FS Gira HS Software 4.5 (Experte, QuadClient, Firmware 4.5)
    I just saw the new Gira HS 4.5 software is available! Including new firmware, QuadClient, Experte..
    German Link: https://www.gira.de/service/download...d.html?id=1043
    NL Link: http://www.gira.com/nl_NL/service/do...d.html?id=1043
    Release Notes:
    QuadClient / QuadConfig
    New features
    Increased password security
    - Details on this can be found at the end of the document.
    Improvement
    Basic setting of design selection
    In the basic settings of QuadConfig the selection of active and inactive designs has been changed. From version 4.5.0:
    - Design 0 – active
    - Design 1 – inactive
    - Design 2 – active
    - Design 3 – inactive
    - Design 4 – active
    - Design 5 – active
    - Design 6 – active
    Project check
    - Revised project check even when QuadConfig is running.
    Example: Changes to a communication object in Expert are directly adopted in QuadConfig without the need to restart the program.
    - Messages in the message window (error, warning, info) are reliable and synchronous, i.e. no display of ("wrong positive") error messages whose cause has already been "rectified".
    Loading / saving projects
    - In rare cases it could occur that a project file was read incompletely – e.g. due to a defective function template having been loaded. Subsequent writing could then have led to data loss.
    - The read and write function for the project data was revised, the user will now be made aware of such errors. Written project data will only be adopted if successful.
    - In addition, log files can be opened from QuadConfig. In case of an error, these offer detailed information on the cause of the error.
    Function template 1-107 – Shutters Awnings Roof window
    - Inverse motion direction for roof windows can now be selected as a response.
    Function template 1-103 – Heating Plus (operationg mode switching)
    - "Presence button", "presence detector" selection options.
    - In the new "presence detector" mode, the buttons for operating mode switching are hidden.
    Corrections
    - Fixed: Timer - Astro function - pop-up for offset setting Sunset does not open.
    - Fixed: Function template 1-108 -Sensor with limit: It was not possible to specify negativenumbers as a limit.
    Expert Software
    New features
    Corrections
    - Fixed: All EIB telegrams via EIBnet/IP coming from the HS have been marked as repetitions.
    Zuletzt geändert von Roeller; 16.11.2016, 14:40.
    Donnerwetter, Gira hat es wirklich wahr gemacht!
      Einen echten Brüller findet man in dem Update nicht.
      Markus
        Ganz ehrlich.... und für dieses Megaupdate haben sie fast 1 Jahr gebraucht,
        echt traurig.
          Nichts was ich nicht auch schon angekündigt habe.
            Die Firmware scheint noch gleich zu sein, also nur Experte Software updaten?
              Firmware ist neu.
              Gruß Matthias
              - PN nur für PERSÖNLICHES!
                Ok, danke für die Info.
                  Gira App 4.2.2 wieder aus App Store verschwunden. Gibt es dafür einen Grund ?!
                  MfG
                  Matthbot
                    Hallo, habe mein "altes Projekt" importiert, wo finde ich die "Checkbox Passwortsicherheit"?
                    Möchte nicht alle Benutzerberechtigungen neu vergeben.
                      In einer der ersten Register unter Projekt
                      Der HomeServer Projektverwalter
                      -Bald nicht mehr nur für den HS sondern auch viele Weitere-
                      Kostenlos herunterladen unter:
                      www.SmartHomeTools.de
                        schon erste Erfahrungen?
                        Irgendwelche Showstopper schon entdeckt, oder läufts mindestens so stabil wie 4.4?
                        Markus
                          Läuft
                            Ich will mir demnächst den Home Server zulegen, jetzt lese ich gerade auf der Update Seite das der HS keine erweiterten Gruppenadressen unterstützt, d.h ich kann keine 3 Stufigen Adressen mit 0-31 Hauptgruppen verwenden?
                              Das machen viele Geräte nicht.
                              3 stufig geht von 0-15 als Hauptgruppe. Ehrlich gesagt, habe ich die erweiterten noch in keinem Projekt benötigt. Im privat Bereich vor allem nicht.
