ABB UK/S 32.2 practical experience
    KNX/EIB ABB UK/S 32.2 practical experience
    Someone has practical experience with the ABB UK/S 32.2 ?
    I've read the doc, but can't find any info about the size of the wires to be used (0,6?, 0,8?) nor about how to remove a wire.
    The doc on page 1 says
    Plug-in screw terminals
    but there are no screws
    Thank you for any hint.
    PS: maybe I don't have the right doc, I've a 49 page manual
    UKS_322_PH_EN_V1-0_2CDC510066D0201.pdf
    Hmm, I only have two (much worse) UK/S 32.1 for several things (17x heating-actuators with Finder SSR, remainer is windows, Status LEDs etc.)
    All with Xx0.6 Y(St)Y <100m if that answers your question..
    Makki
    -> Bitte KEINE PNs!
      Thank you for the reply.
      Did you manage to remove a wire from the device ? or is it once for ever
        no it isn't ... there are (very small) screws.
        Visualisierung, Rule/Logic-Engine, Integrationsplattform mit openhab (Supportforum)
          I removed the tomatoes from my eyes , but still can't see the screws.
          Do I need to remove the green terminal bar to access the screws ?
          Thank you
            the screws are hidden on the given picture. They appear if you pull out the "Steckerleisten".
              Thank you
              Based on your information, I did pull-out the "Steckerleisten".
              I'm very happy about ABB , but on a 50 page manual, there is not a word about this
                Thank you
                you are welcome!
