Wasserfluß erkennen
    Hi Raymond
    The function of the flow sensor / controller is based on the thermo dynamic principle.
    Here you find a detailed description: http://www.ege-elektronik.com/PDF/Kataloge/E1.pdf
    The interesting thing is that you can choose two different controllers for the same sensor, one with binary output and one with an analog output. This means you can adjust / measure the flow. These applications are very robust as they do not base up on moving parts.
    I’m using this technology to check the flow of a high volume water pump to feed my waterfall; I will post this KNX controlled waterfall project soon.
    Kind regards
    Franco
      Looks great, thank you for the pointer
      Hey !
      If I get you right, this would be a nice alternative to the classical "water-counter".
      Right
      In France, the counter has to be outside the house, so, usually no KNX connectivity (although there are some very specific radio wave solutions).
      This device could be installed inside the house, serial with the water pipe, instead of a full blown water counter ?
      Thank you.
        Hi Raymond
        I disagree; this product is a sensor only but not a meter – at least the parts I have installed.
        The output indicates liters per minutes, but not the effective usage in cubic meter.
        Kind regards
        Franco
          OK, I understand
          Which parts exactly have you installed ? there are so many on the website.
          Thank you for the info
            Good day Raymond
            My run-dry protection for the pump is done with the sensor STK421 and the amplifier SKM420GR, the relay is connected with a KNX binary input.
            This configuration is very easy to use for any flow detection, regardless of the volume and the diameter of the pipe, this because the STM420GR has a trimmer to adjust the trigger for the relay.
            The installation is very simple, just drill a hole into the pipe, cut a G1/4 tap, screw in the sensor and connect it to the amplifier. Unfortunately today we have an intensive rain, so I’m not motivated to go to open the pump shaft to take a picture for you, but I will think about when I publish the project.
            Due to the flexibility, robustness and ease to use, I recommended this solution for the initial request on this thread.
            Kind regards
            Franco
              Zitat von atlatus Beitrag anzeigen
              In Japan bin ich des öfteren. Da geht es nicht nur um ein Signal, sondern auch um so annehmlichkeiten wie Heizung, Bidet (natürlich mit warmen Wasser), Musik usw.
              Aha..
              Also könnte es doch fast sinnvoller sein, für das warme Wasser (in der Zirkulationsleitung) weit vorher zu sorgen, denn mit dem Durchflusssensor wirds erstmal reichlich kalt am Popo, ein BWM/PM im Bad, der nebenbei 50 andere Dinge steuert erscheint mir da sinnvoller
              Makki
              -> Bitte KEINE PNs!
                Macht es sinn bei jeder Spülung zu Entlüften?
                Noch Eleganter wärs doch, die Dauer der Entlüftung von der Dauer des Toilettenaufenthalts abhängig zu machen
                Wir haben das so gelöst: Wird der Bewegungsmelder auf der Toilette aktiviert so aktiviert sich (softwareseitig) ein sekundengenauer Betriebsstundenzähler. Dieser zählt die Zeitdauer (in Sekunden) bis der Bewegungsmelder nicht mehr aktiv ist. Danach läuft die Lüftung die doppelte Zeitspanne, die der Bewegungsmelder aktiv war.
                Grüße,
                Florian
                  Ich habe einen bewegungsmelder, der automatisch das Licht anschaltet, wenn jemand in die toilette kommt. und der schaltet zeitverzögert auch die Lüftung an/aus.
                  Man gewöhnt sich sehr schnell an diesen luxus...
                  gruss www.g-homeserver.com
                    Gibt es ein Limit?
                    Wenn ein Nachfolger noch während der Nachlaufzeit kommt, was dann? Werden verbleibende Nachlaufzeit und neu hinzukommende Nachlaufzeit addiert oder kann ein "Kurzzeitbesucher" den an sich noch langen Nachlauf einer "Dauerhockers" einfach so verkürzen?
                    Tessi
                      Zitat von Tessi Beitrag anzeigen
                      Gibt es ein Limit?
                      Ich habe mein Programm nun etwas adaptiert...
                      • Das Toilettenlicht leuchtet solange der Bewegungsmelder aktiv ist + 60 Sekunden (Ausschaltverzögerung)
                      • Die Entlüftung läuft die doppelte Zeit der Aktivität des Bewegungsmelders
                      • Kommt während der Entlüftungszeit noch ein "Beuscher" aufs Klo, so wird die Zeit nochmal dazuaddiert zur Laufzeit der Entlüftung
                      • Das Limit der Entlüftung sind 4 Minuten - dh. länger als 4 Minuten am Stück läuft die Entlüftung nicht, egal wie oft ein "Besucher" während der Entlüftungszeit kommt
                      Ich glaube das ist eine sehr effektive und intelligente Entlüftung. Hat noch jemand Verbesserungsvorschläge?
                      Ich habe das Programm hochgeladen (siehe Anhang). Das Programm lässt sich mit unserer Konfigurationssoftware simulieren (Hier kostenos zum Download verfügbar: LoxPLAN Download)
                      Schöne Grüße,
                      Florian
