Hi Raymond
The function of the flow sensor / controller is based on the thermo dynamic principle.
Here you find a detailed description: http://www.ege-elektronik.com/PDF/Kataloge/E1.pdf
The interesting thing is that you can choose two different controllers for the same sensor, one with binary output and one with an analog output. This means you can adjust / measure the flow. These applications are very robust as they do not base up on moving parts.
I’m using this technology to check the flow of a high volume water pump to feed my waterfall; I will post this KNX controlled waterfall project soon.
Kind regards
Franco
Kind regards
Franco
