Sorry that this is in English, but although I read German, writing is something else. Please feel free to answer in German, I'll manage...
I have a Daikin Altherma L/W heatpump and wanted to integrate this in my KNX system. Zennio has a KNX interface for this: KLIC-DA.
This interface connects in parallel to the command panel of the Daikin.
For the most part, the interface works. I can read and set the setpoint, read the current water temperature, etc.
However, reading the produced or consumed energy does not work. The problem apparently with this is that the machine needs some sort of trigger in order to update these values. Just polling is not enough. I have to use the command panel to read out these values on the machine and only then will I get an updated value through the Zennio.
Obviously, walking over to the machine to get a new reading is not what I had in mind.
I wonder if anyone has used the same interface and would be interested in their experience.
Thanks in advance.
Thanks in advance.
