ich habe mir mal c-move angeschaut das ist recht einfach damit kannst du den PC an der wand fernsteuern. Nur leider bockt das bei meinem neuen W10 Tablet gerade ein bischen.
import socket HOST = "192.168.178.37" PORT = 33333 DATA = "DisplayON".decode('hex') s = socket.socket(socket.AF_INET, socket.SOCK_DGRAM) s.sendto(DATA, (HOST, PORT)): 'str' object has no attribute 'id'
2017-03-23 21:42:26 ERROR SEND_UDP_PACKET_DISPLAY import socket
PORT = 33333
File "/mfs/core/lib/config.py", line 263, in __call__
exec(self.bytecode, self.locals)
File "<string>", line 4, in <module>
AttributeError: 'str' object has no attribute 'decode'
During handling of the above exception, another exception occurred:
File "/mfs/core/lib/scheduler.py", line 421, in _worker
obj(value, trigger)
File "/mfs/core/lib/config.py", line 274, in __call__
self.node.id, tb[1], tb[2], e, self.code))
AttributeError: 'str' object has no attribute 'id'
ich denke das mit den codes tut nicht... zumindest nicht in meiner CLI
>>> import codecs
>>> codecs.decode('DisplayON', 'hex_codec')
File "/usr/local/lib/python3.6/encodings/hex_codec.py", line 19, in hex_decode
return (binascii.a2b_hex(input), len(input))
binascii.Error: Odd-length string
The above exception was the direct cause of the following exception:
File "<stdin>", line 1, in <module>
binascii.Error: decoding with 'hex_codec' codec failed (Error: Odd-length string)
