Someone has a practical experience with the Elsner TH-UP Basic ?
In the bathroom, I've a push-button to switch on a ventilator. The ventilator has 2 speeds, this is done via 2 separate channels of a standard actuator (not a fan coil).
Now, I've installed the TH-UP Basic to automate the process.
I've configured humidity threshold 1 as 70% and threshold 2 as 85%
When the threshold 1 is reached, the ventilator switches on at speed 1 (low)
When the threshold 2 is reached, the ventilator switches on at speed 2 (high)
This seems to work, but once the ventilator is running, it doesn't stop anymore
. It's probably due to a bad setting of the hysterisis, I've RTFM but this doc is of no help, just showing the same text as in ETS, not a word of explanation about hysterisis. I've tried several values, no luck.
Would some one be so kind to post a working example, please ?
Thank you.
Pic1 shows the setting of the TH-UP, GA 0/6/169-175 are for the display in the Visu. GA 0/6/21 is the actuator channel switching the ventilator On/Off, GA 0/6/23 is the actuator switching the ventilator Low speed/high speed.
Pic2 shows the treshold setting.
Pic3 shows channel A & B of the actuator (A=On/Off, B=Low/High speed)
Thank you.
